ThinkPad UltraSlim USB DVD Burner – a small form factor external portable DVD and CD recordable drive that can be attached to Notebooks with USB2.0 port or USB3.0 port. The 9.5 mm UltraSlim engine (20% slimmer than previous the DVD Burner) with premium outlook means that the ThinkPad UltraSlim USB DVD Burner brings you the best user experience.
- Lenovo ThinkPad UltraSlim USB DVD Burner - DVD±RW (±R DL) / DVD-RAM drive - SuperSpeed USB 3.0 - external
- DVD±RW (±R DL) / DVD-RAM drive - external
- Interface
- 13.6 cm x 15.4 cm x 1.32 cm
- 235 g
- Optical Storage
- Pricing Type
- Customer-replaceable Unit (CRU)
- 1-year warranty
- Interface
- 13.6 cm
- 15.4 cm
- 1.32 cm
- 235 g
Optical Storage
- Supported Media Formats
- CD Text, CD Extra, CD-ROM XA, Photo CD, Video CD, CD-ROM
- Supported Media Types
- CD-ROM, CD-R, CD-RW, DVD-ROM, DVD-R, DVD-RAM, DVD-RW, DVD+RW, DVD+R, DVD+R DL, DVD-R DL
- Access Time
- 160 ms (DVD), 140 ms (CD)
- Buffer Size
- 0.75 MB
- 1 x USB 3.0 - 4 pin USB Type A
- Cables Included
- 1 x USB cable
- UL, TUV, VCCI, C-Tick, BSMI, FCC, KC
- Pricing Type
- OS Required
- Microsoft Windows 7 / Windows 8
- Limited warranty - replacement - 1 year
- 0 °C
- 40 °C
- 5 - 85% (non-condensing)
