Lenovo ThinkPad Ultraslim USB DVD Burner
Quicklinx: 9PF5WS00 Mfr#: 4XA0E97775
ThinkPad UltraSlim USB DVD Burner – a small form factor external portable DVD and CD recordable drive that can be attached to Notebooks with USB2.0 port or USB3.0 port. The 9.5 mm UltraSlim engine (20% slimmer than previous the DVD Burner) with premium outlook means that the ThinkPad UltraSlim USB DVD Burner brings you the best user experience.
  • Compact design
    The Lenovo ThinkPad UltraSlim USB DVD Burner boasts an external enclosure type, making it a perfect fit for users who value portability and minimalistic setups.
  • Efficient performance
    With a 0.75 MB buffer size, this DVD writer ensures smooth and reliable performance for all your data storage and access needs.
Lenovo ThinkPad UltraSlim USB DVD Burner - DVD±RW (±R DL) / DVD-RAM drive - SuperSpeed USB 3.0 - external
DVD±RW (±R DL) / DVD-RAM drive - external
SuperSpeed USB 3.0
13.6 cm x 15.4 cm x 1.32 cm
235 g
Optical Storage
Pricing Type
Customer-replaceable Unit (CRU)
1-year warranty
SuperSpeed USB 3.0
13.6 cm
15.4 cm
1.32 cm
235 g
Optical Storage
Supported Media Formats
CD Text, CD Extra, CD-ROM XA, Photo CD, Video CD, CD-ROM
Supported Media Types
CD-ROM, CD-R, CD-RW, DVD-ROM, DVD-R, DVD-RAM, DVD-RW, DVD+RW, DVD+R, DVD+R DL, DVD-R DL
Access Time
160 ms (DVD), 140 ms (CD)
Buffer Size
0.75 MB
1 x USB 3.0 - 4 pin USB Type A
1 x USB cable
UL, TUV, VCCI, C-Tick, BSMI, FCC, KC
Pricing Type
Microsoft Windows 7 / Windows 8
Limited warranty - replacement - 1 year
5 - 85% (non-condensing)
