Lenovo ThinkPad T495S Ryzen 5 PRO 16GB 256GB SSD 14" Windows 10 Professional 64-bit
Quicklinx: F92XWS00 Mfr#: 20QJ000CUK
Display Size: 14in
Processor Model: 3500U
Operating System: Windows 10 Pro 64-bit Edition
Installed Memory: 16GB
Hard Drive Capacity: 256GB
  • IEEE 802.11n
41 in stock
£1,010.64 ex VAT
£1,212.76 inc VAT
The ThinkPad T495s laptop makes it easy to take your work with you, featuring lightweight portability and heavyweight performance. It means you can work longer, faster, and more efficiently. This laptop also has all-day battery life, a bottom-load, and a backlit keyboard. This ThinkPad T495s means business.
  • Premium performance
    The ThinkPad T495s combines the advanced processor with fast graphics, for high CPU frequency and great GPU performance. Experience maximum efficiency and premium audio and video that won't drain your battery.
  • Choose how you see it
    ThinkPad T495s display features a Full HD IPS low-power screen for enhanced battery life, and a touchscreen. Its super-slim bezel design will keep your eyes where they belong - on the screen.
  • This laptop listens
    With Cortana Premium, you can command your ThinkPad T495s from across the room. The integrated dual 360-degree far-field microphones ensure your voice carries its weight. Wake your device with a simple phrase. Quickly find files and calendar events. Even put your system into standby mode to improve battery performance with a single command.
  • Plenty of life between charges
    The ThinkPad T495s delivers a long-lasting battery life. If you're running low, rapid-charging technology provides 80% capacity in extremely short time.
  • Keep others out of your business
    Protect your ThinkPad T495s laptop's data with a multi-prong defense. Discrete Trusted Platform Module (dTPM 2.0) encrypts your data and passwords. The touch fingerprint reader work with Windows Hello for a more secure, biometric login. Avoid spying eyes with PrivacyGuard - an exclusive electronic-shield technology that blocks screen from all angles other than head-on. ThinkShutter, a physical cover that ensures your camera sees you only when you want it to.
Lenovo ThinkPad T495s - 14" - Ryzen 5 Pro 3500U - 16 GB RAM - 256 GB SSD - UK
Notebook
Operating System
Win 10 Pro 64-bit - English
AMD Ryzen 5 Pro 3500U / 2.1 GHz (3.7 GHz) / 4 MB Cache
16 GB DDR4 (provided memory is soldered)
Storage
256 GB SSD TCG Opal Encryption 2, NVMe
Optical Drive
No optical drive
Display
14" LED backlight 1920 x 1080 / Full HD
Graphics
AMD Radeon Vega 10
Input Device
TrackPoint, UltraNav
Keyboard
Keyboard Backlight
Integrated Webcam
802.11a/b/g/n/ac, Bluetooth 5.0
Wireless Broadband (WWAN)
WWAN upgradable
Up to 16.4 hours
Dockable
Security
Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader, smart card reader
32.9 cm x 22.615 cm x 1.67 cm
1.33 kg
Manufacturer Selling Program
TopSeller
Environmental Standards
ENERGY STAR Qualified
Limited warranty - 3 years - pick-up and return , Limited warranty - battery - 1 year
Notebook
Operating System
Windows 10 Pro 64-bit Edition - English
Processor / Chipset
CPU
Max Turbo Speed
3.7 GHz
Number of Cores
Quad-Core
Cache
L3 - 4 MB
64-bit Computing
Integrated memory controller
RAM
16 GB (provided memory is soldered)
DDR4 SDRAM
Speed
2400 MHz
Rated Speed
2666 MHz
Storage
Main Storage
256 GB SSD - (M.2 2280) PCIe - TCG Opal Encryption 2, NVM Express (NVMe)
Display
14" - IPS
LCD Backlight Technology
LED backlight
Resolution
1920 x 1080 (Full HD)
Widescreen
Image Aspect Ratio
16:9
Image Brightness
400 cd/m²
Anti-glare, 72% colour gamut, Low Power
Audio & Video
Graphics Processor
AMD Radeon Vega 10
Camera
Yes - 720p
Camera Features
IR camera, ThinkShutter camera privacy
Sound
Stereo speakers, dual array microphone
Codec
Realtek ALC3287
High Definition Audio, Dolby Audio Premium
Input
Keyboard, TrackPoint, UltraNav
Keyboard Backlight
Keyboard Layout
Spill-resistant, multi-touch touchpad, buttonless touchpad
Communications
Wireless
Wireless Controller
Intel Dual Band Wireless-AC 9260
Gigabit Ethernet via optional Ethernet (RJ-45) adapter
DASH
Generation
WWAN upgradable
Lithium Ion
57 Wh
Run Time
Up to 16.4 hours
AC Adapter
Input
Output
65 Watt
Connections & Expansion
USB 3.1 Gen 2 , USB 3.1 Gen 1 (Always On) , 2 x USB-C 3.1 Gen 2/DisplayPort (Power Delivery) , HDMI , Lenovo Ethernet extension connector , Headphone/microphone combo jack
Memory Card Reader
Yes (microSD)
Case Material
Carbon fibre reinforced plastic, magnesium-aluminum alloy
Dockable
Security
Administrator password, hard drive password, power-on password, RapidCharge, MIL-STD-810G tested
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
USB-C power adapter
RoHS
Localization
TopSeller
1.33 kg
ENERGY STAR Certified
Software applications
Lenovo ThinkPad T495S Ryzen 5 PRO 16GB 256GB SSD 14 Bundle deal on Lenovo ThinkPad T495S Ryzen 5 PRO 16GB 256GB SSD 14" Windows 10 Professional 64-bit
£1,193.65
saving £8.33
£1,109.81
F92X Lenovo Optical 3-button W/Mouse USB In Stock £13.75
Display Size: 14in
Optical Storage: None
Graphics: AMD Radeon Vega 10
Hard Drive Type: SSD
Touchscreen: No
Type: Laptop
Brand: Lenovo
Price Range Ex VAT: 1000 - 1500
