With powerful processing and long battery life, the ThinkPad T470 is designed to enhance your productivity, anywhere. Easy to use, deploy, and service, this robust laptop has a host of cutting-edge technology, including fast storage, and secure fingerprint reading.
Performance you can count on
With the responsiveness and efficiency of a powerful processor, the Lenovo ThinkPad T470 lets you switch effortlessly between your favorite apps - increasing your productivity, creativity, or entertainment levels along the way. -
User-friendly, business-friendly
Easy to set up and roll out, the T470 is also quick to service, upgrade, and secure. From an everyday user to an IT technician, this business laptop is designed to make life (and work) easier for everyone. -
Make light work of long days
The T470 gives you greater flexibility and hours of power on a single charge. That's more than enough juice to help you burn the midnight oil or binge-watch your favorite show. -
For on-the-go productivity and entertainment
The T470 gives you portability, without sacrificing performance. Its stunning display delivers sharp, vibrant visuals - perfect for working on the go or kicking back to enjoy a movie. -
Stay connected, even when you're not
With super-fast connectivity, the T470 gives you prompt access to all your cloud data and apps - even if you are out of Wi-Fi range. -
Look sharp, sound sharper
The T470 has an HD web camera and dual-array microphones (with background noise reduction) as standard - ideal for whether you're on a call in a busy open-plan office or a bustling coffee shop.
- Lenovo ThinkPad T470 - 14" - Intel Core i7 - 7600U - vPro - 8 GB RAM - 256 GB SSD - UK
- Product Type
- Notebook
- Operating System
- Win 10 Pro 64-bit
- Platform Technology
- Intel vPro Platform
- Processor
- Intel Core i7 (7th Gen) - 7600U / 2.8 GHz, up to 3.9 GHz / 4 MB Cache
- Memory
- 8 GB DDR4 (1 x 8 GB)
- Storage
- 256 GB SSD - TCG Opal Encryption 2, NVMe
- Display
- 14" LED backlight 1920 x 1080 / Full HD
- Graphics
- Intel HD Graphics 620
- Input Device
- TrackPoint, UltraNav
- Keyboard
- UK
- Keyboard Backlight
- Integrated Webcam
- Networking
- 802.11a/b/g/n/ac, Bluetooth 4.1, Gigabit Ethernet
- Battery
- 3-cell - up to 13.9 hours
- Dockable
- Security
- Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader, smart card reader
- Black
- 33.66 cm x 23.25 cm x 1.995 cm
- 1.65 kg
- Localisation
- Manufacturer Selling Program
- TopSeller
- Environmental Standards
- - ENERGY STAR Qualified EPEAT Climate+
- Limited warranty - 3 years - on-site , Limited warranty - battery - 1 year
- Product Type
- Notebook
- Operating System
- Windows 10 Pro 64-bit Edition
Processor / Chipset
- CPU
- Intel Core i7 (7th Gen) 7600U / 2.8 GHz
- Max Turbo Speed
- 3.9 GHz
- Number of Cores
- Dual-Core
- Cache
- 4 MB
- 64-bit Computing
- Integrated memory controller
- RAM
- 8 GB (1 x 8 GB)
- Max RAM Supported
- 32 GB
- Technology
- DDR4 SDRAM
- Speed
- 2133 MHz
- Form Factor
- SO-DIMM 260-pin
- Slots Qty
- 2
- Empty Slots
- 1
Storage
- Main Storage
- 256 GB SSD M.2 PCIe - TCG Opal Encryption 2, NVM Express (NVMe)
Display
- 14" - IPS
- LCD Backlight Technology
- LED backlight
- Resolution
- 1920 x 1080 (Full HD)
- Widescreen
- Image Aspect Ratio
- 16:9
- Image Brightness
- 250 cd/m²
- Anti-glare
Audio & Video
- Graphics Processor
- Camera
- Yes - 720p
- Sound
- Stereo speakers, dual array microphone
- Codec
- Realtek ALC3268
- High Definition Audio
Input
- Keyboard, TrackPoint, UltraNav
- Keyboard Layout
- UK
- Spill-resistant, multi-touch touchpad, buttonless touchpad
Communications
- Wireless
- Wireless Controller
- Intel Dual Band Wireless-AC 8265 - M.2 Card
- Network Interface
- Gigabit Ethernet
- Ethernet Controller
- Intel I219-LM
Wireless Broadband (WWAN)
- Generation
- WWAN upgradable
- Technology
- 3-cell Lithium Ion
- Installed Qty
- 2
- Capacity
- 24 Wh
- Run Time
- Up to 13.9 hours
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 45 Watt
Connections & Expansion
- Interfaces Details
- 2 x USB 3.1 Gen 1/USB 3.0 , USB 3.1 Gen 1/USB 3.0 (Always On) , USB-C 3.1 Gen 2 (supports Thunderbolt 3, DisplayPort Alt Mode) (Power Delivery 2.0) , HDMI , LAN , Dock , Headphone/microphone combo jack
- Memory Card Reader
- Yes (SDXC UHS Card)
Software
- Software Included
- Lenovo Companion, Lenovo Settings
- Black
- Case Material
- Glass-fibre reinforced plastic, polyphenylene sulfide
- Dockable
- Security
- Administrator password, hard drive password, power-on password, Intel Active Management Technology (iAMT), MIL-STD-810G tested
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- Included Accessories
- Power adapter
- RoHS
- Localization
- TopSeller
- 1.65 kg
Sustainability Information
- TCO Certified
- EPEAT Compliant
- EPEAT Climate+
- ENERGY STAR Certified
