Lenovo ThinkPad T/R 14W 9 Cell High Capacity
Quicklinx: 57PVWS00 Mfr#: 43R2499
Increase your unplugged computing time. This high-capacity battery has an extended area on the back edge and fits in the standard ThinkPad T & R Series 14W notebook battery slots. Its compatible design allows it to be in a system connected to the ThinkPad Advanced Dock, Advanced Mini-Dock, and Essential Port Replicator. Battery life and recharge times vary based on many factors including screen brightness, applications, features, power management, battery conditioning, and other customer preferences. (For battery life, go to lenovo.com/alldaycomputing)
Compatible with T400, R400, T61 14 W, R60/R61 14 W.
Lenovo - laptop battery - Li-Ion - 7800 mAh
Laptop battery
0.52 kg
High capacity - Lithium Ion 9-cell - 7800 mAh
22.5 cm x 7.7 cm x 3.3 cm
1-year warranty
ThinkPad R400; R61; R61i; R61u; T400; T61; T61u
Laptop battery
High capacity
9-cell Lithium Ion
Voltage Provided
10.8 V
7800 mAh
UL, C-Tick, cUL, ACA
Limited warranty - replacement - 1 year
5 °C
35 °C
8 - 95%
22.5 cm
7.7 cm
3.3 cm
0.52 kg
Lenovo ThinkPad R400 2782, 2783, 2784, 2786, 2787, 7438, 7439, 7440, 7443, 7445, 7446 , Lenovo ThinkPad R61 7642, 7643, 7644, 7645, 7646, 7647, 7648, 7650, 7732, 7733, 7734, 7735, 7736, 7737, 7738, 7742, 7743, 7744, 7751, 7753, 7754, 7755, 8928, 8929, 8936, 8937, 8947 , Lenovo ThinkPad R61i 7732 , Lenovo ThinkPad R61u 7733, 7743 , Lenovo ThinkPad T400 2764, 2765, 2766, 2767, 2768, 2769, 2773, 6473, 6474, 6475, 7417, 7420, 7425, 7434 , Lenovo ThinkPad T61 1959, 6377, 6378, 6379, 6480, 6481, 7658, 7659, 7660, 7661, 7662, 7663, 7664, 7665 , Lenovo ThinkPad T61u 7659, 7663
