Expect nothing short of outstanding value with the ThinkPad Pro 90W Dock. Snap your system into the ThinkPad Pro Dock and enjoy all of the connectivity options you could ever need. This Lenovo ThinkPad docking station comes with a ThinkPad AC Adapter which can power and charge your ThinkPad notebook. The Pro 90W Dock connects your ThinkPad to a power supply, the Internet, up to 2 external displays, a keyboard, mouse and a printer. One of the dock's 3 USB 2.0 ports allows you to charge your mobile phone or tablet, even when your notebook is elsewhere. The USB 2.0 ports are perfect for connecting all of your most frequently used workplace accessories, from mice to keyboards to printers. This ThinkPad docking station also offers 3 USB 3.0 ports for connecting memory keys and external hard drives. The dock is driver-free yet offers a superior level of video quality. It comes with 10/1000 Gigabit Ethernet connectivity, 1x DisplayPort 1.2 (for exclusive use with DVI-D), 1x DVI-D (for exclusive use with DisplayPort), 1x VGA port and 1x Stereo/Mic Combo Audio Port. The cable lock slot allows you to secure the dock to your desk or workspace while the eject button offers quick, effective, one-step notebook removal.
Versatile connectivity
Equipped with a variety of video interfaces including DP, DVI, and VGA, the Lenovo ThinkPad Pro Dock allows for multiple display setups, ensuring compatibility with a wide range of monitors and projectors for seamless integration into any workspace. -
Comprehensive compatibility
The dock is designed to meet global standards, boasting compliance with BSMI, CB, DOC, FCC, GOST, KCC, NOM, UL, UkrSEPRO, and VCCI. This wide range of certifications ensures the dock's reliability and compatibility across different regions and devices. -
Enhanced productivity
Featuring a 4-pin USB Type-A connector and support for USB 2.0, the dock facilitates the connection of peripheral devices, enhancing productivity by enabling efficient multitask and easy access to external storage devices, keyboards, and mice.
- Lenovo ThinkPad Pro Dock - port replicator - VGA, DVI, DP
- Product Type
- Port replicator
- Video Interfaces
- VGA, DVI, DP
- 34.5 cm x 16.25 cm x 5.56 cm
- 910 g
- Localisation
- Indonesia, Europe
- Power
- Power adapter AC 120/230 V (50/60 Hz) 90 Watt Power Provided
- Product Type
- Port replicator
- 34.5 cm
- 16.25 cm
- 5.56 cm
- 910 g
- Localisation
- Indonesia, Europe
- 3 x USB 2.0 - 4 pin USB Type A , 3 x SuperSpeed USB 3.0 - 9 pin USB Type A , 1 x audio / video - DisplayPort - 20 pin DisplayPort , 1 x display / video - DVI-Digital - 24+1 pin digital DVI , 1 x display / video - VGA - 15 pin HD D-Sub (HD-15) , 1 x network - 10Base-T/100Base-TX/1000Base-T - RJ-45 , 1 x docking / port replicator , 1 x audio - headphones/microphone - mini-phone stereo 3.5 mm
- Included Accessories
- 2 x security keys
- Security lock slot (cable lock sold separately), 1 USB 2.0 (Always On)
- UL, VCCI, BSMI, GOST, NOM, CB, DOC, FCC, KCC, UkrSEPRO, AS/NZS
- Power Device
- Power adapter
- Voltage Required
- AC 120/230 V (50/60 Hz)
- Power Provided
- 90 Watt
- 5 °C
- 43 °C
