Lenovo Thinkpad Pro Dock 65W
Quicklinx: 9GC2WS00 Mfr#: 40a10065uk
Expect nothing short of an outstanding value. Completely re-designed for a new generation of ThinkPads, snap into the ThinkPad Pro Dock with an included ThinkPad AC Adapter and get connected to power, your Local Area Network/Internet and workplace accessories such as up two external displays, keyboard, mouse and printer so you can get more done faster. One of the dock's USB ports also supports always-on mobile device charging, which means that you can charge your mobile phone or tablet, even when your notebook is away. Our unique physical alignment guarantees perfect notebook-dock alignment every time. Comes with ThinkPad AC adapter to charge your notebook.
  • Versatile connectivity
    Equipped with a variety of video interfaces including DP, DVI, and VGA, the Lenovo ThinkPad Pro Dock allows for multiple display setups, ensuring compatibility with a wide range of monitors and projectors for seamless integration into any workspace.
  • Comprehensive compatibility
    The dock is designed to meet global standards, boasting compliance with BSMI, CB, DOC, FCC, GOST, KCC, NOM, UL, UkrSEPRO, and VCCI. This wide range of certifications ensures the dock's reliability and compatibility across different regions and devices.
  • Enhanced productivity
    Featuring a 4-pin USB Type-A connector and support for USB 2.0, the dock facilitates the connection of peripheral devices, enhancing productivity by enabling efficient multitask and easy access to external storage devices, keyboards, and mice.
Lenovo ThinkPad Pro Dock - port replicator - VGA, DVI, DP
Port replicator
Video Interfaces
VGA, DVI, DP
34.5 cm x 16.25 cm x 5.56 cm
910 g
United Kingdom
Power adapter - external AC 120/230 V (50/60 Hz) 65 Watt Power Provided
1-year warranty
Port replicator
34.5 cm
16.25 cm
5.56 cm
910 g
United Kingdom
3 x USB 2.0 - 4 pin USB Type A , 3 x SuperSpeed USB 3.0 - 9 pin USB Type A , 1 x display / video - DisplayPort - 20 pin DisplayPort , 1 x display / video - DVI-Digital - 24+1 pin digital DVI , 1 x display / video - VGA - 15 pin HD D-Sub (HD-15) , 1 x network - 10Base-T/100Base-TX/1000Base-T - RJ-45 , 1 x docking / port replicator , 1 x audio - headphones/microphone - mini-phone stereo 3.5 mm
Security lock slot (cable lock sold separately), "Always On" USB port
Plug and Play, UL, VCCI, BSMI, GOST, NOM, CB, DOC, FCC, KCC, UkrSEPRO
Power Provided
65 Watt
Limited warranty - 1 year
5 °C
43 °C
9GC2 C2G 2m DisplayPort Male to HD Male Adapter Cable - Black In Stock £20.80
9GC2 C2G 3m DisplayPort Cable with Latches M/M - Black In Stock £13.45
