The Lenovo ThinkPad Pen Pro for Yoga 260 with 2,048 levels of pressure sensitivity is an ideal input solution to give the user a precise content-creation experience. Users will also enjoy easy access to right and left click buttons built into the shaft of the pen that provide additional tools for data interaction. This pen is unique to the ThinkPad Yoga260 in that it can be stored in the system pen slot made specifically for that pen. The pen will recharge while being stored and allows the user up to 130 minutes (active use) of battery life off a single charge.
- Lenovo ThinkPad Pen Pro-2 - active stylus
- Active stylus
- 7.3 cm x 4.3 cm x 21.9 cm
- 100 g
- 2 side buttons, 2048 pressure levels on both pen and eraser
- 1-year warranty
- Designed For
- ThinkPad X380 Yoga; ThinkPad Yoga 260 20FD, 20FE, 20GS
- Active stylus
- 7.3 cm
- 4.3 cm
- 21.9 cm
- 100 g
Input Device
- Limited warranty - replacement - 1 year
- 5 °C
- 40 °C
- 30 - 80%
- Designed For
- Lenovo ThinkPad X380 Yoga , Lenovo ThinkPad Yoga 260 20FD, 20FE, 20GS
