The ThinkPad Pen Pro is similar in size and shape to an actual ink writing instrument. With 2,048 levels of pressure sensitivity, it is an ideal input solution to give users a precise content creation experience. Users will also enjoy easy access to right and left click buttons built into the shaft of the pen that provide additional tools for data interaction. Powered by an AAAA battery, the Pen Pro is designed to provide a premium pen experience with ThinkPad touchscreen-enabled devices.
There is a USB pen holder in the box so you can easily keep your pen attached to your ThinkPad system.
Enhanced precision
The Lenovo ThinkPad Active Capacitive Pen is designed with 2048 pressure levels on both pen and eraser, offering superior control and accuracy for a natural writing and drawing experience. -
Wide compatibility
Engineered for seamless integration, this active stylus is compatible with PC, ensuring a broad range of use across different devices and platforms. -
Optimal performance
Operates efficiently within a humidity range of 30 - 80% and temperature extremes from 5°C to 40°C, ensuring reliable performance in various environments.
 - Lenovo ThinkPad Active Capacitive Pen - active stylus
 - Active stylus
 - 0.95 cm x 0.95 cm x 14.062 cm
 - 18.5 g
 - 2048 pressure levels on both pen and eraser
- Battery
 - AAAA type
 - 1-year warranty
 - Active stylus
 - 0.95 cm
 - 0.95 cm
 - 14.062 cm
 - 18.5 g
Input Device
 - AAAA type
 - Limited warranty - replacement - 1 year
 - 5 °C
 - 40 °C
 - 30 - 80%
