The Lenovo ThinkPad Pen Pro for Yoga 260 with 2,048 levels of pressure sensitivity is an ideal input solution to give the user a precise content-creation experience. Users will also enjoy easy access to right and left click buttons built into the shaft of the pen that provide additional tools for data interaction. This pen is unique to the ThinkPad X1 Yoga in that it can be stored in the system pen slot made specifically for that pen. The pen will recharge while being stored and allows the user up to 130 minutes (active use) of battery life off a single charge.
- Lenovo ThinkPad Pen Pro-3 - active stylus
- Active stylus
- 0.65 cm 12.67 cm
- 5.5 g
- Buttons Qty
- 2
- Designed For
- ThinkPad X1 Yoga (1st Gen) 20FQ, 20FR; X390 20SC, 20SD
- Active stylus
- 0.65 cm
- 12.67 cm
- 5.5 g
Input Device
- Buttons Qty
- 2
- Pressure Levels
- 2048
- Designed For
- Lenovo ThinkPad X1 Yoga (1st Gen) 20FQ, 20FR , Lenovo ThinkPad X390 20SC, 20SD
