Lenovo ThinkPad P71 Xeon E3-1505M 16GB 512GB SSD 17.3" Win 10 Pro
Quicklinx: D171WS00 Mfr#: 20HK0005UK
  • Xeon
  • IEEE 802.11n
The ThinkPad P71 redefines the concept of power with an Intel Xeon processor and NVIDIA Quadro graphics. Feature-packed with optional X-Rite PANTONE color calibration, Mil-Spec durability, blazing-fast connection speeds, and the highest capacity of storage and memory make this workstation your go-to PC for getting the job done.
  • Dazzling display
    Choose a 4K UHD display With IPS technology, and get vivid colors and nearly 180-degree viewing angles. X-Rite PANTONE color calibration yields greater image accuracy, more precise color matching, and a consistently true display. Dual Intel Thunderbolt 3 ports revolutionizes connection technology - simultaneously supporting high-resolution displays and high-performance data devices through a single, compact port. Your choice of 4 different NVIDIA Quadro graphics cards ensures there is a graphic solution to fit your need.
  • Impressive extras built in
    The ThinkPad P71 features Lenovo's award-winning keyboard, which is made better with a redesigned Touchpad. Full-sized and spill-resistant, the legendary ThinkPad ergonomic keyboard is renowned for its full array of keys, excellent feel, and TrackPoint pointing device. Flex performance cools with dual quiet fans for better performance and reliability. Because you demand proven performance and software stability, Lenovo ensures that more than 100 applications are ISV certified. For true mobility, configure your laptop with WWAN connectivity, so you can access 3G or 4G networks provided by a third-party cellular phone service company (subscription required).
  • Powerful performance
    PC performance has never been faster. Intel Core and Xeon processors with built-in security are designed to take your productivity, creativity, and 3D gaming to the next level. Intel vPro Technology makes enterprise-level manageability even more convenient and efficient. And with the ThinkPad you can empower yourself and your business to do great things across many devices securely anywhere, with anyone, and at any time. Fitting a variety of budgets, it's also very easy to use. So you can get more done right from the start.
  • Audio clarity from Dolby
    Dolby Home Theater maximizes volume output of the built-in stereo speakers without distortion - enjoy a crisp, clear, immersive surround sound experience with all the power and nuance of the cinema, and all the immediacy of live performance.
Lenovo ThinkPad P71 - 17.3" - Xeon E3-1505MV6 - 16 GB RAM - 512 GB SSD - UK
Notebook
Operating System
Win 10 Pro 64-bit
Intel Xeon E3-1505MV6 / 3 GHz (4 GHz) / 8 MB Cache
16 GB DDR4 (2 x 8 GB)
Storage
512 GB SSD TCG Opal Encryption 2, NVMe
Optical Drive
DVD-Writer
Display
17.3" LED backlight 3840 x 2160 / Ultra HD 4K
Graphics
NVIDIA Quadro P4000 / Intel HD Graphics P630
Video Memory
8 GB
Input Device
TrackPoint, UltraNav
Keyboard
Keyboard Backlight
Numeric Keypad
Integrated Webcam
802.11a/b/g/n/ac, Bluetooth 4.1, Gigabit Ethernet
Wireless Broadband (WWAN)
WWAN upgradable
8-cell - up to 14.25 hours
X-Rite Pantone colour calibration sensor
Dockable
Security
Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader, smart card reader
41.6 cm x 27.55 cm x 3.42 cm
3.3 kg
Manufacturer Selling Program
TopSeller
Environmental Standards
ENERGY STAR Qualified
Limited warranty - 3 years - on-site , Limited warranty - battery - 1 year
Notebook
Operating System
Windows 10 Pro 64-bit Edition
Processor / Chipset
CPU
Max Turbo Speed
4 GHz
Number of Cores
Quad-Core
Cache
8 MB
64-bit Computing
Chipset
Mobile Intel CM238 Express
Platform Technology
Integrated memory controller
RAM
16 GB (2 x 8 GB)
Max RAM Supported
64 GB
DDR4 SDRAM - ECC
Speed
2400 MHz
SO-DIMM 260-pin
Slots Qty
4
Empty Slots
2
Storage
Main Storage
512 GB SSD - (M.2) PCIe - TCG Opal Encryption 2, NVM Express (NVMe)
Optical Drive
DVD-Writer - tray
Display
17.3" - IPS
LCD Backlight Technology
LED backlight
Resolution
3840 x 2160 (Ultra HD 4K)
Widescreen
Image Aspect Ratio
16:9
Image Brightness
300 cd/m²
Anti-glare, 90% colour gamut
Audio & Video
Multi-GPU Configuration
1 single GPU card / integrated GPU
Graphics Processor
Video Memory
8 GB
Camera
Yes - 720p
Sound
Stereo speakers, dual array microphone
Codec
Realtek ALC3268
High Definition Audio
Input
Keyboard, TrackPoint, UltraNav
Keyboard Backlight
Keyboard Layout
Numeric Keypad
Spill-resistant, multi-touch touchpad
Communications
Wireless
Wireless Controller
Intel Dual Band Wireless-AC 8265 - M.2 Card
Network Interface
Gigabit Ethernet
Ethernet Controller
Intel I219-LM
Generation
WWAN upgradable
8-cell Lithium Ion
96 Wh
Run Time
Up to 14.25 hours
AC Adapter
Input
Output
230 Watt
Connections & Expansion
Slots
1 x ExpressCard/34 (1 free)
3 x USB 3.1 Gen 1/USB 3.0 , USB 3.1 Gen 1/USB 3.0 (Always On) , 2 x USB-C/Thunderbolt 3 , Mini DisplayPort , HDMI , LAN , Dock , Headphone/microphone combo jack
Memory Card Reader
4 in 1 (SD Card, MultiMediaCard, SDHC Card, SDXC Card, SDXC UHS-II Card)
Software
Software Included
Lenovo Companion, Lenovo Settings
Case Material
Glass-fibre, magnesium-aluminum alloy, polyphenylene sul?de
Integrated Options
Dockable
Security
Administrator password, hard drive password, power-on password, Intel Active Management Technology (iAMT), MIL-STD-810G tested
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
Power adapter
RoHS
Localization
TopSeller
3.3 kg
ENERGY STAR Certified
Essential Accessories (1)
Get more from your purchase from one of our essential accessories
D171 Lenovo Microsaver Security Cable Lock In Stock £34.29
Other bundles (1)
D171 Lenovo Optical 3-button W/Mouse USB In Stock £12.69
