The ThinkPad P14s i, Lenovo's most mobile workstation, strikes the balance between power and mobility, all within a compact 14-inch chassis. Perfect for highly mobile power users, the P14s i is designed with ultimate portability and performance in mind, featuring the latest Intel Core processors, NVIDIA professional graphics, and integrated X-Rite factory color calibration for outstanding out-of-the-box color accuracy. Built with an advanced suite of ThinkShield security features and comprehensive MIL-STD testing for ultimate durability, the P14s i has you protected from every angle - allowing students, engineers, and designers the freedom to innovate anytime, anywhere.
Ultramobile, ultrapowerful
Engineered for ultramobile power users, the ThinkPad P14s Gen 2 (14" AMD) is fueled by AMD Ryzen PRO processors with up to 8 cores. Professional-grade integrated AMD Radeon graphics with 4GB vRAM give you an extra kick for intensive tasks like renderings. -
Bright, accurate colours
Select models of the ThinkPad P14s Gen 2 (14" AMD) come equipped with a 4K UHD (3840 x 2160) display for vibrant, precise images and video. This 500-nit display option offers increased brightness, while integrated X-Rite Factory Colour Calibration assures pin-point colour accuracy. -
Thin, light,& versatile
The ThinkPad P14s Gen 2 (14" AMD) packs massive power into its slim and portable 1.47kg body. It also gives you robust connectivity options for an extra edge-including two USB Type-C ports, along with HDMI and USB 3.2 connectors. -
Goodbye lag time
Make lag time a thing of the past with up to 2TB of fast NVMe SSD storage and up to 48GB 3200MHz memory. The P14s Gen 2 (14" AMD) also includes ISV certifications from major vendors like AutoCAD, Revit, SolidWorks, and more. -
Built tough
To ensure it runs in extreme conditions, we test the ThinkPad P14s Gen 2 (14" AMD) against 12 military-grade requirements and more than 200 quality checks. From the Arctic wilderness to desert dust storms, from zero gravity to accidental spills and drops, it won't let you down. -
Private& secure
The ThinkPad P14s Gen 2's updated suite of built-in ThinkShield features safeguards your device and your data. A fingerprint reader assures secure login. Discrete Trusted Platform Module (dTPM) encrypts your business-critical data and works in conjunction with Windows 10 security features. And its ThinkPad Webcam Privacy Shutter lets you physically close the camera to keep the outside world out.
- Lenovo ThinkPad P14s Gen 2 - 14" - AMD Ryzen 7 Pro - 5850U - AMD PRO - 16 GB RAM - 512 GB SSD - UK
- Product Type
- Mobile workstation
- Operating System
- Win 10 Pro 64-bit (downgrade from Windows 11 Pro) + Windows 11 Pro Licence - English
- Platform Technology
- AMD PRO
- Processor
- AMD Ryzen 7 Pro 5850U / 1.9 GHz, up to 4.4 GHz / 16 MB Cache
- Memory
- 16 GB DDR4 (provided memory is soldered)
- Storage
- 512 GB SSD - TCG Opal Encryption 2, NVMe
- Display
- 14" LED backlight 1920 x 1080 / Full HD
- Graphics
- AMD Radeon Graphics
- Input Device
- Keyboard, TrackPoint, UltraNav
- Keyboard
- UK
- Keyboard Backlight
- Integrated Webcam
- Networking
- 802.11a/b/g/n/ac/ax, Bluetooth 5.2, Gigabit Ethernet
- Battery
- Up to 15.8 hours
- Dockable
- Security
- Discrete Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader, smart card reader
- Black
- 32.9 cm x 22.7 cm x 1.79 cm
- 1.46 kg
- Localisation
- Manufacturer Selling Program
- Lenovo TopSeller
- Environmental Standards
- ENERGY STAR Qualified EPEAT Gold
- Limited warranty - 3 years - pick-up and return , Limited warranty - battery - 1 year
- Product Type
- Operating System
- Windows 10 Pro 64-bit Edition (available through downgrade rights from Windows 11 Pro) + Windows 11 Pro Licence - English
Processor / Chipset
- CPU
- Max Turbo Speed
- 4.4 GHz
- Number of Cores
- 8-core
- Cache
- L3 - 16 MB
- AMD PRO
- Integrated memory controller
- RAM
- 16 GB (provided memory is soldered)
- Max RAM Supported
- 48 GB
- Technology
- DDR4 SDRAM - non-ECC
- Speed
- 3200 MHz
- Rated Speed
- 1600 MHz
- Form Factor
- SO-DIMM 260-pin
- Slots Qty
- 1
- Empty Slots
- 1
Storage
- Main Storage
- 512 GB SSD M.2 2280 - TCG Opal Encryption 2, NVM Express (NVMe)
Display
- 14" - IPS
- LCD Backlight Technology
- LED backlight
- Resolution
- 1920 x 1080 (Full HD)
- Widescreen
- Image Aspect Ratio
- 16:9
- Image Brightness
- 400 cd/m²
- Colour Gamut
- 72% NTSC
- Anti-glare, 170° viewing angle, Low Power
Audio & Video
- Graphics Processor
- AMD Radeon Graphics - up to
- Max Monitors Supported
- 3 external monitor(s)
- Camera
- Yes - 720p
- Camera Features
- Privacy shutter, IR camera, fixed focus
- Sound
- Stereo speakers, dual array microphone
- Codec
- Realtek ALC3287
- High Definition Audio, Dolby Audio
Input
- Keyboard Layout
- UK
- Spill-resistant, multi-touch touchpad, Fn keys with Unified Communications controls
Communications
- Wireless
- Network Interface
- Gigabit Ethernet
- Ethernet Controller
- Realtek RTL8111H
- Wake-on-LAN (WOL), dual stream (2x2)
Wireless Broadband (WWAN)
- Generation
- 4G upgradable
- Technology
- Lithium polymer
- Capacity
- 50 Wh
- Run Time
- Up to 15.8 hours
AC Adapter
- Input
- AC 100-240 V (50/60 Hz)
- Output
- 65 Watt
Connections & Expansion
- Interfaces Details
- USB 3.2 Gen 1 (Always On) , USB 3.2 Gen 1 , 2 x USB-C 3.2 Gen 2 (supports DisplayPort Alt Mode) (Power Delivery) , HDMI , Headphone/microphone combo jack , LAN , Dock
- Memory Card Reader
- Yes (microSD)
- Black
- Case Material
- Polycarbonate ABS, glass-fibre, magnesium alloy, polyphenylene sulfide, polyamide, Talc15
- Dockable
- Security
- Administrator password, power-on password, MIL-STD-810H tested, self-healing BIOS, NVMe password
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- Included Accessories
- USB-C slim power adapter
- RoHS
- Localization
- Lenovo TopSeller
- 1.46 kg
Sustainability Information
- TCO Certified
- EPEAT Compliant
- EPEAT Gold
- ENERGY STAR Certified
- 5 °C
- 35 °C
- 8 - 95%
Essential Accessories (6)
Get more from your purchase from one of our essential accessories
Lenovo 3M 14.0W Privacy Filter | In Stock | £37.80 |
Lenovo 45W Standard AC Adapter (USB Type-C) Power Adapter | In Stock | £25.94 |
Lenovo 65W Standard AC Adapter USB-C | In Stock | £28.46 |
Lenovo USB-C 65W AC Adapter AC 100-240 V 65Watt for ThinkPad A275 | In Stock | £29.48 |
Lenovo ThinkPad Hybrid USB-C with USB-A Dock - Do | In Stock | £193.72 |
Kensington Security Cable Lock | In Stock | £23.58 |
Other bundles (9)
Lenovo USB Soundbar for Display | In Stock | £29.96 |
Lenovo HDMI to VGA Monitor Adapter | In Stock | £23.12 |
Lenovo Essential Wireless Keyboard and Mouse Combo - UK English 166 | In Stock | £27.12 |
Lenovo Professional Wireless Keyboard | In Stock | £52.98 |
Lenovo ThinkPad Ethernet Extension Adapter Gen 2 | In Stock | £24.46 |
Lenovo ThinkPad USB3.0 to Ethernet Adapter | In Stock | £16.03 |
Lenovo ThinkVision T27q-20 27" 2560x1440 4ms HDMI DisplayPort IPS LED Monitor | In Stock | £312.36 |
Lenovo ThinkPad Bluetooth Silent Mouse - Right and Left-handed | In Stock | £23.81 |
Lenovo ThinkVision T24t-20 23.8" 4ms HDMI DisplayPort USB-C IPS LED Monitor | In Stock | £189.67 |
