Lenovo ThinkPad P1 Core i7-8750H 16GB 256GB SSD 15.6" Windows 10 Pro
Quicklinx: F18HWS00 Mfr#: 20MD0001UK
  • Core i7
  • IEEE 802.11n
Is it better to be powerful or mobile? With the new ThinkPad P1, the answer is... both. No need to choose. It's thinnest and lightest mobile workstation ever at 18.4mm and 1.7 kg. But it still delivers on power with 8th Gen Intel Xeon and Core processors, NVIDIA Quadro graphics, and massive memory and storage options.
  • Raw power
    Count on the ThinkPad P1 mobile workstation when it comes to mission-critical systems and performance. The latest Intel Xeon and Core processing and cutting-edge NVIDIA Quadro graphics make this slim powerhouse pack a punch.
  • ISV certified
    The ThinkPad P1 has been tested and proven to render key heavy-lifting applications seamlessly. And don't just take word for it: the P1 boasts dozens of the major independent software vendor (ISV) certifications.
  • Workstation power has never looked so good
    Boasting Think's signature black finish and encased in carbon fiber and magnesium alloy, the P1 has the style to match the power inside. And at a mere 18.4 mm thin, no one will mistake this machine for anything less than an ultra-premium must-have.
  • Girded for the toughest ordeals
    The P1 has endured 12 military-grade requirements and more than 200 quality checks to ensure it runs in extreme conditions. From the arctic wilderness to desert dust storms, from zero-gravity to spills and drops, you can trust this mobile workstation to handle whatever life throws your way.
  • Thin in size, thick with features
    It's not just power the ThinkPad P1 packs into its slim chassis. Its robust connectivity - including multiple Thunderbolt ports, as well as more traditional connectors like USB 3.0 and HDMI - put other ultrathin mobile workstations to shame.
Lenovo ThinkPad P1 - 15.6" - Intel Core i7 - 8750H - 16 GB RAM - 256 GB SSD - UK
Mobile workstation
Operating System
Win 10 Pro 64-bit
Intel Core i7 (8th Gen) - 8750H / 2.2 GHz, up to 4.1 GHz / 9 MB Cache
16 GB DDR4 (2 x 8 GB)
Storage
256 GB SSD - TCG Opal Encryption 2, NVMe
Display
15.6" LED backlight 1920 x 1080 / Full HD
Graphics
NVIDIA Quadro P1000 / Intel UHD Graphics 630
Video Memory
4 GB GDDR5 SDRAM
Input Device
Keyboard, TrackPoint, UltraNav
Keyboard
Keyboard Backlight
Integrated Webcam
802.11a/b/g/n/ac, Bluetooth 5.0, Gigabit Ethernet
Up to 13.87 hours
Security
Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader, smart card reader
36.18 cm x 24.57 cm x 1.84 cm
1.7 kg
Manufacturer Selling Program
Lenovo TopSeller
Environmental Standards
ENERGY STAR Qualified
0.193 W/kg (body) , 0.193 W/kg (limb)
Limited warranty - 3 years - on-site , Limited warranty - battery - 1 year
Mobile workstation
Operating System
Windows 10 Pro 64-bit Edition
Processor / Chipset
CPU
Intel Core i7 (8th Gen) 8750H / 2.2 GHz
Max Turbo Speed
4.1 GHz
Number of Cores
6-core
Cache
9 MB
64-bit Computing
Chipset
Mobile Intel CM246
Hyper-Threading Technology, integrated memory controller, Intel Turbo Boost Technology 2.0, Intel Smart Cache
RAM
16 GB (2 x 8 GB)
Max RAM Supported
64 GB
DDR4 SDRAM - non-ECC
Speed
2666 MHz
Rated Speed
1333 MHz
SO-DIMM 260-pin
Slots Qty
2
Empty Slots
0
Storage
Main Storage
256 GB SSD M.2 PCIe - TCG Opal Encryption 2, NVM Express (NVMe)
Display
15.6" - IPS
LCD Backlight Technology
LED backlight
Resolution
1920 x 1080 (Full HD)
Widescreen
Image Aspect Ratio
16:9
Image Brightness
300 cd/m²
Colour Gamut
72%
Anti-glare
Audio & Video
Multi-GPU Configuration
1 single GPU card / integrated GPU
Graphics Processor
NVIDIA Quadro P1000 / Intel UHD Graphics 630 - up to
Video Memory
4 GB GDDR5 SDRAM
Camera
Yes - 720p
Camera Features
ThinkShutter camera privacy
Sound
Stereo speakers, dual array microphone
Codec
Realtek ALC3286
High Definition Audio, Dolby Audio Premium, Dolby Atmos
Input
Keyboard Backlight
Keyboard Layout
Spill-resistant, multi-touch touchpad, buttonless touchpad
Communications
Wireless
Wireless Controller
Intel Wireless-AC 9560 - M.2 Card
Network Interface
Gigabit Ethernet
Ethernet Controller
Intel I219-V
Lithium Ion
80 Wh
Run Time
Up to 13.87 hours
AC Adapter
Input
Output
135 Watt
Connections & Expansion
Interfaces Details
USB 3.1 Gen 1 (Always On) , USB 3.1 Gen 1 , 2 x USB-C (supports Thunderbolt 3, DisplayPort Alt Mode) (Power Delivery) , HDMI , Lenovo Ethernet extension connector , Headphone/microphone combo jack , LAN (on supplied cable)
Memory Card Reader
Yes (SD Card, SDHC Card, SDXC UHS-II Card)
Case Material
Aluminum, glass-fibre reinforced plastic, carbon fibre reinforced plastic
Security
Administrator password, hard drive password, power-on password, RapidCharge, MIL-STD-810G tested
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
Power adapter, ThinkPad Ethernet Extension cable
RoHS
Localization
Lenovo TopSeller
1.7 kg
Sustainability Information
TCO Certified
ENERGY STAR Certified
