Work or play - you decide. The Lenovo Miix 510 is the 2-in-1 PC that adapts to every moment. With its sleek design, amazing watchband hinges, and high performance - you can rely on the Miix 510 to power you through any situation.
Design That Stands Out
With a premium one-piece aluminum design, the Miix 510 is bound to attract attention. This detachable 2-in-1 easily transitions from tablet to laptop to support you wherever you go-and looks great too. -
Unique Watchband Hinges
Made from 280 individual pieces of stainless steel, the hinges provide strength and flexibility. Adjustable up to 150°, they help you find your perfect viewing angle for watching videos, typing, or using the touchscreen. -
Everything You Need To Stay Productive
With the blazing-fast performance and built-in security of up to the latest Gen Intel Core i7 processors, the Miix 510 is ready to take your productivity and creativity to the next level. Now, you can power through tasks like creating/editing documents and photos, plus so much more. It also features a 12.2" FHD+ touchscreen in addition to the power and agility of a regular laptop PC. -
Do Great Things With Windows 10 Home
Enjoy the best of what Windows 10 Home has to offer: from fast start-ups, to the expanded Start menu and all-new browser, to Cortana-your very own digital personal assistant. -
Open Programs and Files in a Flash
Miix 510 features the latest Solid State Drive (SSD) technology, enabling it to boot up within seconds and open files/apps in a flash. What's more, since SSDs have no spinning parts, you'll benefit from a virtually silent machine with the durability to withstand accidents, such as dropping your laptop bag! -
Simplicity with Accuracy
No space to use a mouse? The integrated precision touchpad can be adjusted to respond to the lightest of touches or the firmest of clicks. -
Be Creative With Lenovo Active Pen
Draw, sign documents, take notes, and more-the optional Lenovo Active Pen is sensitive to every detail. -
Time to Relax
Whether you're watching movies, playing games or simply browsing the web, you'll love the flexibility of switching between a handheld tablet and a full productivity keyboard. And with Dolby enabled stereo speakers, everything sounds better. -
Snap Photos, Then Edit
Enjoy taking high-quality photos with the rear-facing 5MP camera. Then edit them in a snap by reattaching the keyboard-or use the optional Lenovo Active Pen to select them. -
All-day Battery Life
Miix 510 keeps you connected all day long with up to 8 hours of battery life. -
Always Online
With optional LTE, you can stay online even when you are away from WiFi. -
Talking With Others is Easier
Whether voice or video calls, Miix 510 is optimized for VoIP with a 2 MP HD webcam, and dual array mics with noise cancellation technology that reduces background noise and interference.
- Lenovo IdeaPad Miix 510-12IKB - 12.2" - Intel Core i5 - 7200U - 8 GB RAM - 256 GB SSD - UK
- Product Type
- Tablet - with detachable keyboard
- Operating System
- Win 10 Pro 64-bit
- Processor
- Intel Core i5 (7th Gen) - 7200U / 2.5 GHz, up to 3.1 GHz / 3 MB Cache
- Memory
- 8 GB DDR4 (provided memory is soldered)
- Storage
- 256 GB SSD
- Display
- 12.2" LED backlight touchscreen 1920 x 1200 / WUXGA
- Graphics
- Intel HD Graphics 620
- Input Device
- Keyboard, digitizer, touchpad, digital pen
- Keyboard
- UK
- Keyboard Backlight
- Integrated Webcam
- Networking
- 802.11a/b/g/n/ac, Bluetooth 4.1
- Battery
- 2-cell - up to 7.5 hours
- Platinum silver
- Dimensions (WxDxH) - tablet
- 30 cm x 20.5 cm x 0.99 cm
- 880 g
- Localisation
- Environmental Standards
- - EPEAT Climate+
- Limited warranty - 1 year - pick-up and return
- Product Type
- Operating System
- Windows 10 Pro 64-bit Edition
Processor / Chipset
- CPU
- Intel Core i5 (7th Gen) 7200U / 2.5 GHz
- Max Turbo Speed
- 3.1 GHz
- Number of Cores
- Dual-Core
- Cache
- 3 MB
- 64-bit Computing
- Integrated memory controller
- RAM
- 8 GB (provided memory is soldered)
- Technology
- DDR4 SDRAM
- Speed
- 2133 MHz
Storage
- Main Storage
- 256 GB SSD PCIe
Display
- 12.2" - IPS
- LCD Backlight Technology
- LED backlight
- Touchscreen
- Yes (multi-touch)
- Resolution
- 1920 x 1200 (WUXGA)
- Widescreen
- Image Aspect Ratio
- 16:10
- Image Brightness
- 320 cd/m²
- Corning Gorilla glass
Audio & Video
- Graphics Processor
- Camera
- Resolution
- 5 Megapixel (rear), 2 Megapixel (front)
- Camera Features
- Rear camera with auto focus
- Sound
- Stereo speakers, microphone
Input
- Keyboard Layout
- UK
Communications
- Wireless
- Technology
- 2-cell Lithium Ion
- Capacity
- 39 Wh
- Run Time
- Up to 7.5 hours
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 45 Watt, 20 V, 2.25 A
Connections & Expansion
- Interfaces Details
- USB 3.0 (Always On) , USB-C , Headphone/microphone combo jack
- Memory Card Reader
- Yes (microSD)
- Platinum silver
- Administrator password, power-on password
- Included Accessories
- Power adapter, keyboard, active pen, pen holder
- Localization
- 880 g
- Dimensions (WxDxH) / Weight Details
- 30 cm x 20.5 cm x 0.99 cm / 880 g - tablet , 30 cm x 20.5 cm x 1.59 cm / 1.25 kg - tablet with keyboard , 30.39 cm x 21.91 cm x 0.6 cm / 380 g - keyboard dock
Sustainability Information
- TCO Certified
- EPEAT Compliant
- EPEAT Climate+
