You work hard to get the job done, no matter where the job takes you. The ThinkPad L580 has the versatility, power, and portability to keep up - and to make your job easier. The perfect business partner!
Stay one step ahead, no matter where you go
Lighter and thinner than the previous model, the L580 is easy to take home at the end of the day. The antiglare display is also easy on the eyes. With many hours of life in its battery, you'll get a lot of uninterrupted time without worrying about electrical outlets. And when you come back, the USB-C mechanical side docking makes it easy to reconnect at your desk. -
More connectivity, more productivity
Whether you need to get online or use a peripheral device, the L580 can connect you. Extensive I/O ports make it easy to plug in most peripheral devices, while Near Field Communication (NFC) technology gives you the luxury of wireless communication between your laptop and other nearby NFC devices.
- Lenovo ThinkPad L580 - 15.6" - Intel Core i5 - 8250U - 8 GB RAM - 256 GB SSD - UK
- Product Type
- Notebook
- Operating System
- Win 10 Pro 64-bit
- Processor
- Intel Core i5 (8th Gen) - 8250U / 1.6 GHz, up to 3.4 GHz / 6 MB Cache
- Memory
- 8 GB DDR4 (1 x 8 GB)
- Storage
- 256 GB SSD - TCG Opal Encryption 2, NVMe
- Display
- 15.6" LED backlight 1920 x 1080 / Full HD
- Graphics
- Intel UHD Graphics 620
- Input Device
- TrackPoint, UltraNav
- Keyboard
- UK
- Numeric Keypad
- Integrated Webcam
- Networking
- 802.11a/b/g/n/ac, Bluetooth 4.1, Gigabit Ethernet
- Battery
- Up to 12 hours
- Dockable
- Security
- Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader, smart card reader
- Black
- 37.65 cm x 25.45 cm x 2.295 cm
- 2 kg
- Localisation
- Manufacturer Selling Program
- Lenovo TopSeller
- Environmental Standards
- ENERGY STAR Qualified
- Limited warranty - 1 year - pick-up and return
- Product Type
- Notebook
- Operating System
- Windows 10 Pro 64-bit Edition
Processor / Chipset
- CPU
- Intel Core i5 (8th Gen) 8250U / 1.6 GHz
- Max Turbo Speed
- 3.4 GHz
- Number of Cores
- Quad-Core
- Cache
- 6 MB
- 64-bit Computing
- Integrated memory controller
- RAM
- 8 GB (1 x 8 GB)
- Max RAM Supported
- 32 GB
- Technology
- DDR4 SDRAM
- Speed
- 2400 MHz
- Rated Speed
- 1200 MHz
- Form Factor
- SO-DIMM 260-pin
- Slots Qty
- 2
- Empty Slots
- 1
Storage
- Main Storage
- 256 GB SSD M.2 PCIe - TCG Opal Encryption 2, NVM Express (NVMe)
Display
- 15.6" - IPS
- LCD Backlight Technology
- LED backlight
- Resolution
- 1920 x 1080 (Full HD)
- Widescreen
- Image Aspect Ratio
- 16:9
- Image Brightness
- 250 cd/m²
- Anti-glare
Audio & Video
- Graphics Processor
- Intel UHD Graphics 620 - up to
- Camera
- Yes - 720p
- Sound
- Stereo speakers, dual array microphone
- Codec
- Realtek ALC3287
- High Definition Audio, Dolby Audio
Input
- Keyboard, TrackPoint, UltraNav
- Keyboard Layout
- UK
- Numeric Keypad
- Spill-resistant, multi-touch touchpad, buttonless touchpad
Communications
- Wireless
- Wireless Controller
- Intel Dual Band Wireless-AC 8265 - M.2 Card
- Network Interface
- Gigabit Ethernet
- Ethernet Controller
- Intel I219-V
- Technology
- Lithium Ion
- Capacity
- 45 Wh
- Run Time
- Up to 12 hours
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 65 Watt
Connections & Expansion
- Interfaces Details
- USB 3.1 Gen 1 , USB 3.1 Gen 1 (Always On) , 2 x USB-C 3.1 Gen 1 , HDMI , LAN , Dock , Headphone/microphone combo jack
- Memory Card Reader
- Yes (microSD)
- Black
- Case Material
- Polycarbonate ABS
- Dockable
- Security
- Administrator password, hard drive password, power-on password, RapidCharge, MIL-STD-810G tested
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- Included Accessories
- USB-C power adapter
- RoHS
- Localization
- Lenovo TopSeller
- 2 kg
Sustainability Information
- TCO Certified
- ENERGY STAR Certified
Essential Accessories (5)
Get more from your purchase from one of our essential accessories
Lenovo 45W Standard AC Adapter (USB Type-C) Power Adapter | In Stock | £25.88 |
Lenovo 65W Standard AC Adapter USB-C | In Stock | £29.45 |
Lenovo USB-C 65W AC Adapter AC 100-240 V 65Watt for ThinkPad A275 | In Stock | £29.42 |
Lenovo ThinkPad Hybrid USB-C with USB-A Dock - Do | In Stock | £192.44 |
Kensington Security Cable Lock | In Stock | £23.53 |
Warranty Packs (1)
Protect your investment by taking out one of our great value warranty packs
Lenovo ThinkPad 3YR Onsite Epaq | In Stock | £162.07 |
Other bundles (5)
Lenovo HDMI to VGA Monitor Adapter | In Stock | £23.08 |
Lenovo 2m HDMI Cable | In Stock | £16.94 |
Lenovo Essential Wireless Keyboard and Mouse Combo - UK English 166 | In Stock | £27.07 |
Lenovo Professional Wireless Keyboard | In Stock | £52.87 |
Lenovo ThinkPad USB3.0 to Ethernet Adapter | In Stock | £16.00 |
