Enjoy the full PC experience with added portability courtesy of the Lenovo ThinkPad L540. At 2.52kg, it’s ideally lightweight to carry with you for working on the go, while its powerful Intel Core i5 processor means you won’t have to compromise on performance.
With up to nine hours of battery life unplugged, you can work uninterrupted for the whole day, even when there are no power outlets nearby.
Access the internet from anywhere with the L540’s 802.11n wireless technology, which is WWAN upgradable.
For added security, the ThinkPad L540 comes with a security chip and fingerprint reader – putting you in control over its accessibility and ensuring your sensitive documents remain private.
With a 500GB hard drive, there’s also plenty of storage space for your files – which you can view in high definition on the LED backlight 15.6-inch display.
The integrated webcam and face-tracking technology deliver a superior conference call experience – handy if you’ve set up weekly calls with clients and other business associates.
ThinkPad technology at BT Shop prices? It’s a no-brainer.
Improved design changes
Improvements in LCD design and smaller internal antenna result in a reduced bezel size - actually 20% smaller than previous generations - yet ThinkPads deliver legendary reliability and meet or exceed rigorous military-specification standards. Plus these notebooks lie flat, at a 180-degree angle, adding enhanced flexibility for use and sharing. -
Security and manageability features
Intel vPro, Computrace, encrypted hard disk drive, BIOS port locking, Trusted Platform Module, and more, ensure your business-critical data is secure and easily managed. -
Long battery life
Enjoy all-day computing with longer hours unplugged on the standard battery - whether you're working on-the-go or simply enjoying downtime, you get more than a full day on a single charge. -
High resolution display
Enjoy visuals on a dazzling high resolution display, with HD being standard offering. The L540 offers a 15.6-inch antiglare HD (1366 x 768) or FHD (1920 x 1080) display. -
Hinge-based latching and Active Protection System
Thinner and stronger, ThinkPad laptops include hinge-based latching, which features a cleaner, modern easy-open design. Tension in the hinges keeps the cover closed during unexpected drops. Plus, Active Protection System (APS), which works with traditional magnetic HDDs, detects when the system is dropped and reacts by stopping the hard drive to protect your data. -
Integrated 720p HD webcam and dual noise-canceling microphones
Enjoy superior web conferencing on your L540, which includes a low-light sensitive 720p HD webcam with wide-angle viewing and face-tracking, dual noise-canceling microphones with configurations for crystal-clear private and conference mode VOIP meetings, plus, convenient multimedia keys for quick and easy access to microphone, speaker, and camera controls. -
Dolby speakers with Advanced Audio
This suite of audio technologies enables your ThinkPad to deliver a crisp, clear surround sound experience over its built-in stereo speakers. The technology increases audio clarity for VOIP applications, maximizes volume output without distortion, and improves dialog clarity when watching videos. -
Fast data transfer
Move data quickly between the L540 and other devices with SuperSpeed USB 3.0, which enables up to 10 times faster file transfer, allowing for lightning-fast copying of large media files, as well as seamless connections between audio- and video-related peripherals. -
Budget protection
Ensure cost-effective, worry-free enjoyment of your L540 with accidental damage protection, which keeps you covered in the event of accidental damage caused by drops or spills that occur under normal working conditions.
- Lenovo ThinkPad L540 - 15.6" - Core i5 4210M - 4 GB RAM - 500 GB HDD - UK
- Product Type
- Notebook
- Operating System
- Win 7 Pro 64-bit (downgrade from Windows 10 Pro 64-bit) + Windows 10 Pro 64-bit Licence
- Processor
- Intel Core i5 (4th Gen) 4210M / 2.6 GHz (3.2 GHz) / 3 MB Cache
- Memory
- 4 GB DDR3L (1 x 4 GB)
- Storage
- 500 GB HDD / 7200 rpm
- Optical Drive
- DVD-Writer
- Display
- 15.6" LED backlight 1366 x 768 / HD
- Graphics
- Intel HD Graphics 4600
- Input Device
- TrackPoint, UltraNav
- Keyboard
- UK
- Numeric Keypad
- Integrated Webcam
- Networking
- 802.11b/g/n, Bluetooth 4.0, Gigabit Ethernet
- Battery
- 6-cell - up to 9 hours
- Dockable
- Security
- Trusted Platform Module (TPM 1.2) Security Chip, fingerprint reader
- 37.7 cm x 24.7 cm x 3.405 cm
- 2.52 kg
- Localisation
- Manufacturer Selling Program
- TopSeller
- Environmental Standards
- ENERGY STAR Qualified
- Limited warranty - 1 year - pick-up and return
- Product Type
- Notebook
- Operating System
- Microsoft Windows 7 Professional 64-bit Edition (available through downgrade rights from Windows 10 Pro 64-bit) + Windows 10 Pro 64-bit Licence
Processor / Chipset
- CPU
- Max Turbo Speed
- 3.2 GHz
- Number of Cores
- Dual-Core
- Cache
- 3 MB
- 64-bit Computing
- Chipset
- Mobile Intel HM86
- Hyper-Threading Technology, integrated memory controller, Intel Turbo Boost Technology 2.0, Intel Smart Cache
- RAM
- 4 GB (1 x 4 GB)
- Max RAM Supported
- 16 GB
- Technology
- DDR3L SDRAM
- Speed
- 1600 MHz / PC3L-12800
- Rated Speed
- 1600 MHz
- Form Factor
- SO-DIMM 204-pin
- Slots Qty
- 2
- Empty Slots
- 1
Storage
- Main Storage
- 500 GB HDD SATA 6Gb/s / 7200 rpm
- Optical Drive
- DVD-Writer - tray
Display
- 15.6"
- LCD Backlight Technology
- LED backlight
- Resolution
- 1366 x 768 (HD)
- Widescreen
- Image Aspect Ratio
- 16:9
- Image Brightness
- 220 cd/m²
- Anti-glare
Audio & Video
- Graphics Processor
- Camera
- Yes - 720p
- Camera Features
- Face tracking
- Sound
- Stereo speakers, two microphones
- Codec
- Realtek ALC3232
- High Definition Audio, Dolby Advanced Audio v2
Input
- Keyboard, TrackPoint, UltraNav
- Keyboard Layout
- UK
- Numeric Keypad
- Spill-resistant, multi-touch touchpad
Communications
- Wireless
- Wireless Controller
- Intel Wireless-N 7260 - M.2 Card
- Network Interface
- Gigabit Ethernet
- Ethernet Controller
- Intel I217-V
Wireless Broadband (WWAN)
- Generation
- WWAN upgradable
- Technology
- 6-cell Lithium Ion
- Capacity
- 48 Wh
- Run Time
- Up to 9 hours
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 65 Watt
Connections & Expansion
- Slots
- 1 x ExpressCard/54 (1 free)
- USB 3.0 , 3 x USB 2.0 , VGA , Mini DisplayPort , LAN , Headphone/microphone combo jack , Dock
- Memory Card Reader
- 4 in 1 (SD Card, MultiMediaCard, SDHC Card, SDXC Card)
Software
- Software Included
- Cyberlink PowerDVD, CyberLink PowerProducer, CyberLink Power2Go, ThinkVantage Rescue and Recovery, ThinkVantage System Update, Norton Internet Security (30 days subscription), ThinkVantage Product Recovery, Lenovo Solution Center, Lenovo Cloud Storage by SugarSync, PC Device Stage
- Case Material
- Polycarbonate ABS
- Dockable
- Security
- Security lock slot (cable lock sold separately), administrator password, hard drive password, power-on password, ThinkVantage Active Protection System, 1 USB 3.0 (Always On), MIL-STD-810G tested
- Included Accessories
- Power adapter
- RoHS
- Localization
- TopSeller
- 2.52 kg
- ENERGY STAR Certified
