Thanks to the ThinkShutter, optional touch fingerprint reader and IR camera, the ThinkPad L490 is designed with security in mind. It's also very configurable and will make your employees' lives easier with up to a 12-hour battery life and seamless performance.
With long hours of battery, the ThinkPad L490 will last all day. When running low on power, rapid-charging technology will give you 80% battery capacity in just 60 minutes.
The ThinkPad L490 comes with plenty of ports, including HDMI and USB-C. When you're out and about, stay online even when there's no Wi-Fi.
One less thing to worry about
Thanks to the ThinkShutter, optional touch fingerprint reader and IR camera, the ThinkPad L490 is designed with security in mind. It's also very configurable and will make your employees' lives easier with up to a 12-hour battery life and seamless performance. -
Designed to go places
With long hours of battery, the ThinkPad L490 will last all day. When running low on power, rapid-charging technology will give you 80% battery capacity in just 60 minutes. -
One well-connected machine
The ThinkPad L490 comes with plenty of ports, including HDMI and USB-C. When you're out and about, stay online even when there's no Wi-Fi. -
Log in easily & securely
Why type a password? Thanks to the optional touch fingerprint reader and infrared camera, logging in is quick and secure - via advanced biometric technology and Windows Hello facial software. Plus, with ThinkShutter, you can close the webcam when it's not in use. -
Technology you can count on
Like all ThinkPad laptops, the ThinkPad L490 is tested against 12 military-grade requirements and more than 200 quality checks to ensure it runs in extreme conditions. From desert dust storms to the Arctic wilderness, from spills and drops to zero gravity, you can rely on the ThinkPad L490 to handle anything that comes your way.
- Lenovo ThinkPad L490 - 14" - Core i5 8365U - vPro - 8 GB RAM - 256 GB SSD - UK
- Product Type
- Notebook
- Operating System
- Win 10 Pro 64-bit - English
- Platform Technology
- Intel vPro Platform
- Processor
- Intel Core i5 (8th Gen) 8365U / 1.6 GHz (4.1 GHz) / 6 MB Cache
- Memory
- 8 GB DDR4 (1 x 8 GB)
- Storage
- 256 GB SSD - TCG Opal Encryption 2, NVMe
- Display
- 14" LED backlight 1920 x 1080 / Full HD
- Graphics
- Intel UHD Graphics
- Input Device
- TrackPoint, UltraNav
- Keyboard
- UK
- Keyboard Backlight
- Integrated Webcam
- Networking
- 802.11a/b/g/n/ac, Bluetooth 5.0, Gigabit Ethernet
- Battery
- Up to 12 hours
- Dockable
- Security
- Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader, smart card reader
- Black
- 33.5 cm x 23.5 cm x 2.25 cm
- 1.69 kg
- Localisation
- Environmental Standards
- ENERGY STAR Qualified
- Limited warranty - 3 years - on-site
- Product Type
- Notebook
- Operating System
- Windows 10 Pro 64-bit Edition - English
Processor / Chipset
- CPU
- Max Turbo Speed
- 4.1 GHz
- Number of Cores
- Quad-Core
- Cache
- 6 MB
- 64-bit Computing
- Integrated memory controller
- RAM
- 8 GB (1 x 8 GB)
- Max RAM Supported
- 64 GB
- Technology
- DDR4 SDRAM
- Speed
- 2400 MHz
- Rated Speed
- 2666 MHz
- Form Factor
- SO-DIMM 260-pin
- Slots Qty
- 2
- Empty Slots
- 1
Storage
- Main Storage
- 256 GB SSD M.2 2280 PCIe 3.0 x2 - TCG Opal Encryption 2, NVM Express (NVMe)
Display
- 14" - IPS
- LCD Backlight Technology
- LED backlight
- Resolution
- 1920 x 1080 (Full HD)
- Widescreen
- Image Aspect Ratio
- 16:9
- Image Brightness
- 250 cd/m²
- Colour Gamut
- 45%
- Anti-glare, 170° viewing angle
Audio & Video
- Graphics Processor
- Camera
- Yes - 720p
- Camera Features
- ThinkShutter camera privacy
- Sound
- Stereo speakers, dual array microphone
- Codec
- Realtek ALC3287
- High Definition Audio, Dolby Advanced Audio
Input
- Keyboard, TrackPoint, UltraNav
- Keyboard Layout
- UK
- Spill-resistant, multi-touch touchpad, buttonless touchpad
Communications
- Wireless
- Wireless Controller
- Intel Dual Band Wireless-AC 9260 - M.2 Card
- Network Interface
- Gigabit Ethernet
- Technology
- Lithium Ion
- Capacity
- 45 Wh
- Run Time
- Up to 12 hours
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 65 Watt
Connections & Expansion
- USB 3.1 Gen 1 (Always On) , USB-C 3.1 Gen 1 (supports DisplayPort Alt Mode) (Power Delivery) , USB-C 3.1 Gen 2 (supports DisplayPort Alt Mode) (Power Delivery) , HDMI , LAN , Headphone/microphone combo jack , Dock , USB 3.1 Gen 1
- Memory Card Reader
- Yes (microSD)
- Black
- Case Material
- Polycarbonate ABS
- Dockable
- Security
- Administrator password, hard drive password, power-on password, RapidCharge
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- Included Accessories
- USB-C power adapter
- RoHS
- Localization
- 1.69 kg
- ENERGY STAR Certified
Essential Accessories (4)
Get more from your purchase from one of our essential accessories
Lenovo 65W Standard AC Adapter USB-C | In Stock | £29.56 |
Lenovo USB-C 65W AC Adapter AC 100-240 V 65Watt for ThinkPad A275 | In Stock | £29.56 |
Lenovo ThinkPad Hybrid USB-C with USB-A Dock - Do | In Stock | £193.91 |
Kensington Security Cable Lock | In Stock | £23.65 |
Warranty Packs (1)
Protect your investment by taking out one of our great value warranty packs
Lenovo 5WS0A22893 Upgrade To 5 Years Onsite Warranty | In Stock | £195.07 |
Other bundles (5)
Lenovo ThinkPad USB 3.0 Secure HDD-500GB | In Stock | £143.11 |
Lenovo Professional Wireless Keyboard | In Stock | £54.36 |
Lenovo ThinkPad Ethernet Extension Adapter Gen 2 | In Stock | £25.36 |
Lenovo ThinkPad USB3.0 to Ethernet Adapter | In Stock | £16.07 |
Lenovo Essential Wired Keyboard and Mouse Combo - UK English | In Stock | £25.39 |
