Lenovo ThinkPad L480 Intel Core i5-8250U 8GB 1TB 14" Windows 10 Professional 64-bit
Quicklinx: FG7GWS00 Mfr#: 20LS0019UK
  • Core i5
  • IEEE 802.11n
You work hard to get the job done, no matter where the job takes you. The 14-inch ThinkPad L480 has the versatility, power, and portability to keep up - and to make your job easier. The perfect business partner!
  • Keeps IT departments as happy as their users
    Your IT staff will rest easy with the optional infrared camera and touch fingerprint reader, knowing they give the L480 greater security. And it's been fully redesigned for productivity, meaning IT won't have to listen to complaints about a slow laptop.
  • More connectivity, more productivity
    Whether you need to get online or use a peripheral device, the L480 can connect you. Extensive I/O ports such as USB Type-C, USB 3.0, and HDMI make it easy to plug in most peripheral devices, while Near Field Communication (NFC) technology gives you the luxury of wireless communication between your laptop and other nearby NFC devices. Dual Band AC (2x2) and Bluetooth 4.2 make wireless online connectivity a snap, but even if you're not near a router, integrated global mobile broadband LTE-A will keep you connected.
Lenovo ThinkPad L480 - 14" - Intel Core i5 - 8250U - 8 GB RAM - 1 TB HDD - UK
Notebook
Operating System
Win 10 Pro 64-bit
Intel Core i5 (8th Gen) - 8250U / 1.6 GHz, up to 3.4 GHz / 6 MB Cache
8 GB DDR4 (1 x 8 GB)
Storage
1 TB HDD / 5400 rpm
Display
14" LED backlight 1920 x 1080 / Full HD
Graphics
Intel UHD Graphics 620
Input Device
TrackPoint, UltraNav
Keyboard
Keyboard Backlight
Integrated Webcam
802.11a/b/g/n/ac, Bluetooth 4.1, Gigabit Ethernet
Up to 12.2 hours
Dockable
Security
Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader, smart card reader
33.5 cm x 23.5 cm x 2.25 cm
1.68 kg
Manufacturer Selling Program
Lenovo TopSeller
Environmental Standards
ENERGY STAR Qualified
Limited warranty - 1 year - pick-up and return
Notebook
Operating System
Windows 10 Pro 64-bit Edition
Processor / Chipset
CPU
Intel Core i5 (8th Gen) 8250U / 1.6 GHz
Max Turbo Speed
3.4 GHz
Number of Cores
Quad-Core
Cache
6 MB
64-bit Computing
Hyper-Threading Technology, integrated memory controller, Intel Turbo Boost Technology 2.0, Intel Smart Cache
RAM
8 GB (1 x 8 GB)
Max RAM Supported
32 GB
DDR4 SDRAM
Speed
2400 MHz
Rated Speed
1200 MHz
SO-DIMM 260-pin
Slots Qty
2
Empty Slots
1
Storage
Main Storage
1 TB HDD SATA 6Gb/s / 5400 rpm
Display
14" - IPS
LCD Backlight Technology
LED backlight
Resolution
1920 x 1080 (Full HD)
Widescreen
Image Aspect Ratio
16:9
Image Brightness
250 cd/m²
Anti-glare
Audio & Video
Graphics Processor
Intel UHD Graphics 620 - up to
Camera
Yes - 720p
Sound
Stereo speakers, dual array microphone
Codec
Realtek ALC3287
High Definition Audio, Dolby Audio
Input
Keyboard, TrackPoint, UltraNav
Keyboard Backlight
Keyboard Layout
Spill-resistant, multi-touch touchpad, buttonless touchpad
Communications
Wireless
Wireless Controller
Intel Dual Band Wireless-AC 8265 - M.2 Card
Network Interface
Gigabit Ethernet
Ethernet Controller
Intel I219-V
Lithium Ion
45 Wh
Run Time
Up to 12.2 hours
AC Adapter
Input
Output
45 Watt
Connections & Expansion
Interfaces Details
USB 3.1 Gen 1 , USB 3.1 Gen 1 (Always On) , 2 x USB-C 3.1 Gen 1 , HDMI , LAN , Headphone/microphone combo jack , Dock
Memory Card Reader
Yes (microSD)
Case Material
Polycarbonate ABS
Dockable
Security
Administrator password, hard drive password, power-on password, MIL-STD-810G tested
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
USB-C power adapter
RoHS
Localization
Lenovo TopSeller
1.68 kg
Sustainability Information
TCO Certified
ENERGY STAR Certified
Essential Accessories (5)
Get more from your purchase from one of our essential accessories
FG7G Lenovo 45W Standard AC Adapter (USB Type-C) Power Adapter In Stock £25.78
FG7G Lenovo 65W Standard AC Adapter USB-C In Stock £27.84
FG7G Lenovo USB-C 65W AC Adapter AC 100-240 V 65Watt for ThinkPad A275 In Stock £30.05
FG7G Lenovo ThinkPad Hybrid USB-C with USB-A Dock - Do In Stock £192.18
FG7G Kensington Security Cable Lock In Stock £24.13
Warranty Packs (1)
Protect your investment by taking out one of our great value warranty packs
FG7G Lenovo ThinkPad 3YR Onsite Epaq In Stock £164.06
Other bundles (2)
FG7G Lenovo HDMI to VGA Monitor Adapter In Stock £16.09
FG7G Lenovo ThinkPad USB3.0 to Ethernet Adapter In Stock £16.01
