You work hard to get the job done, no matter where the job takes you. The 13.3" ThinkPad L380 has the versatility, power, and mobility to keep up - and to make your job easier. It's ultraportable, with the latest processor and graphics, excellent memory and storage capacity, and robust security features. The perfect business partner!
Keeps IT departments as happy as their users
Your IT staff will rest easy with the optional touch fingerprint reader and discrete TPM 2.0 chip, knowing they give the L380 greater security. And it's been fully redesigned for mobility, meaning IT won't have to listen to complaints about a heavy laptop. That mobility is enhanced by its RapidCharge function. The L380 will make your employees' jobs easier, a favor they will return to your IT department. -
More connectivity, more productivity
Whether you need to get online or use a peripheral device, the L380 can connect you. Extensive I/O ports such as USB Type-C, USB 3.0, and HDMI make it easy to plug in most peripheral devices, while Near Field Communication (NFC) technology gives you the luxury of wireless communication between your laptop and other nearby NFC devices. And its Dual Band AC (2x2) and Bluetooth 4.2 make wireless online connectivity a snap.
- Lenovo ThinkPad L380 - 13.3" - Intel Core i5 - 8250U - 8 GB RAM - 256 GB SSD - UK
- Product Type
- Notebook
- Operating System
- Win 10 Pro 64-bit
- Processor
- Intel Core i5 (8th Gen) - 8250U / 1.6 GHz, up to 3.4 GHz / 6 MB Cache
- Memory
- 8 GB DDR4 (1 x 8 GB)
- Storage
- 256 GB SSD - TCG Opal Encryption 2, NVMe
- Display
- 13.3" LED backlight 1920 x 1080 / Full HD
- Graphics
- Intel UHD Graphics 620
- Input Device
- TrackPoint, UltraNav
- Keyboard
- UK
- Integrated Webcam
- Networking
- 802.11a/b/g/n/ac, Bluetooth 4.1
- Battery
- Up to 16.1 hours
- Security
- Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader
- Black
- 32.18 cm x 22.42 cm x 1.88 cm
- 1.46 kg
- Localisation
- Manufacturer Selling Program
- TopSeller
- Environmental Standards
- ENERGY STAR Qualified
- Specific Absorption Rate (SAR)
- 0.948 W/kg (body) , 0.948 W/kg (limb)
- Limited warranty - 1 year - pick-up and return
- Product Type
- Notebook
- Operating System
- Windows 10 Pro 64-bit Edition
Processor / Chipset
- CPU
- Intel Core i5 (8th Gen) 8250U / 1.6 GHz
- Max Turbo Speed
- 3.4 GHz
- Number of Cores
- Quad-Core
- Cache
- 6 MB
- 64-bit Computing
- Integrated memory controller
- RAM
- 8 GB (1 x 8 GB)
- Max RAM Supported
- 32 GB
- Technology
- DDR4 SDRAM
- Speed
- 2400 MHz
- Rated Speed
- 2400 MHz
- Form Factor
- SO-DIMM 260-pin
- Slots Qty
- 2
- Empty Slots
- 1
Storage
- Main Storage
- 256 GB SSD M.2 PCIe - TCG Opal Encryption 2, NVM Express (NVMe)
Display
- 13.3" - IPS
- LCD Backlight Technology
- LED backlight
- Resolution
- 1920 x 1080 (Full HD)
- Widescreen
- Image Aspect Ratio
- 16:9
- Image Brightness
- 250 cd/m²
- Anti-glare
Audio & Video
- Graphics Processor
- Camera
- Yes - 720p
- Sound
- Stereo speakers, dual array microphone
- Codec
- Realtek ALC3287
- High Definition Audio, Dolby Audio
Input
- Keyboard, TrackPoint, UltraNav
- Keyboard Layout
- UK
- Spill-resistant, multi-touch touchpad, buttonless touchpad
Communications
- Wireless
- Wireless Controller
- Intel Dual Band Wireless-AC 8265 - M.2 Card
- Gigabit Ethernet via optional Ethernet (RJ-45) adapter
- Technology
- Lithium Ion
- Capacity
- 45 Wh
- Run Time
- Up to 16.1 hours
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 65 Watt
Connections & Expansion
- Interfaces Details
- USB 3.1 Gen 1 , USB 3.1 Gen 1 (Always On) , 2 x USB-C 3.1 Gen 1 , HDMI , Headphone/microphone combo jack , Lenovo Ethernet extension connector
- Memory Card Reader
- Yes (microSD)
- Black
- Case Material
- Aluminum, glass-fibre reinforced plastic
- Security
- Administrator password, hard drive password, power-on password, RapidCharge, MIL-STD-810G tested
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- Included Accessories
- USB-C power adapter
- RoHS
- SAR Value
- 0.948 W/kg (body), 0.948 W/kg (limb)
- Localization
- TopSeller
- 1.46 kg
Sustainability Information
- TCO Certified
- ENERGY STAR Certified
