14? business laptop 13 th Gen Intel Core vPro U& P Series
Enhanced video conferencing with FHD camera, Dolby Audio,& Dolby Voice with AI noise suppression technology
Remarkable Intel& NVIDIA graphics options
4G WWAN& WiFi 6E options to always stay connected
Microsoft 11 Secured-core PC options
Comprised of recycled materials& sustainable packaging.
Powerful performance whenever you need it
Powered by Intel vPro with 13 th Gen Intel Core U or P series processors and remarkable graphics options, including NVIDIA GeForce, the ThinkPad L14 Gen 4 laptop will inspire productivity. Plus, with optional battery choices up to 57Whr for true all-day power, this device is a high-performing partner for the work-from-anywhere workforce. -
Everywhere connectivity
With the ThinkPad L14 Gen 4 laptop, you can choose 4G LTE WWAN* connectivity to keep up and running like a smartphone. When combined with WiFi 6E** coverage, it keeps you online virtually anywhere. Plus, you can stay online, yet keep your health in the forefront-Glance software alerts you about your posture and reminds you to look away from the screen to refocus your eyes.* Optional WWAN availability varies by region and must be configured at time of purchase; it requires a network service provider.** 6GHz WiFi 6E operation is dependent on the support of the operating system, routers/APs/gateways that support WiFi 6E, along with the regional regulatory certifications and spectrum allocation -
Smarter security
The ThinkPad L14 Gen 4 laptop boasts a power button that's activated by a fingerprint reader. What's more, ThinkShield hardware and software components with integrated discrete Trusted Platform Module (dTPM), the added security of Windows 11, Microsoft 11 Secured-core PC, and the Intel vPro platform deliver protection from every angle. -
Reliability you can count on
We use the US Department of Defense's MIL-STD 810H standards to create a balance of reliability and durability for our ThinkPad laptops. We test against 12 standards and more than 200 quality checks to ensure they run in extreme conditions. These tests cover harsh variables like Arctic wilderness and desert dust storms, including temperature, pressure, humidity, vibration, and more. -
Flexible procurement
Consider a ?exible approach to IT procurement, Lenovo Device as a Service (DaaS). Designed to free up time and capital, it combines devices, service support, and software into fixed monthly payments. And by taking care of lifecycle management, it enables your IT resources to focus on what they do best.
- Lenovo ThinkPad L14 Gen 4 - 14" - Intel Core i7 - 1355U - 16 GB RAM - 512 GB SSD - UK
- Product Type
- Notebook - 180-degree hinge design
- Operating System
- Win 11 Pro - English
- Processor
- Intel Core i7 (13th Gen) - 1355U / 1.7 GHz, up to 5 GHz / 12 MB Cache
- Memory
- 16 GB DDR4 (1 x 16 GB)
- Storage
- 512 GB SSD - TCG Opal Encryption 2, NVMe
- Display
- 14" 1920 x 1080 / Full HD
- Graphics
- Intel Iris Xe Graphics
- Input Device
- TrackPoint, UltraNav
- Keyboard
- UK
- Keyboard Backlight
- Integrated Webcam
- Networking
- 802.11a/b/g/n/ac/ax, Bluetooth 5.1, Gigabit Ethernet
- Security
- Discrete Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader, smart card reader
- Thunder black
- 32.54 cm x 21.7 cm x 1.983 cm
- 1.4 kg
- Localisation
- Manufacturer Selling Program
- Lenovo TopSeller
- Environmental Standards
- TCO Certified Notebooks 9, ENERGY STAR Qualified EPEAT Gold
- Base warranty - 1 year - pick-up and return , Extended warranty - 1 year - on-site - response time: next business day
- Bundled Services
- 1 Year Lenovo Premier Support
- Product Type
- Operating System
- Windows 11 Pro - English
Processor / Chipset
- CPU
- Intel Core i7 (13th Gen) 1355U / 1.7 GHz
- Max Turbo Speed
- 5 GHz
- Number of Cores
- 10-core
- Cache
- 12 MB
- Integrated memory controller
- RAM
- 16 GB (1 x 16 GB)
- Max RAM Supported
- 64 GB
- Technology
- DDR4 SDRAM
- Speed
- 3200 MHz
- Rated Speed
- 1600 MHz
- Form Factor
- SO-DIMM 260-pin
- Slots Qty
- 2
- Empty Slots
- 1
Storage
- Main Storage
- 512 GB SSD M.2 2242 PCIe 4.0 x4 - TCG Opal Encryption 2, NVM Express (NVMe)
Display
- 14" - IPS
- Resolution
- 1920 x 1080 (Full HD)
- Widescreen
- Image Aspect Ratio
- 16:9
- Image Brightness
- 250 cd/m²
- Colour Gamut
- 45% NTSC
- Anti-glare, 170° viewing angle
Audio & Video
- Graphics Processor
- Max Monitors Supported
- 3 external monitor(s)
- Video System Features
- Functions as Intel UHD graphics (for single-channel memory)
- Camera
- Yes - 1080p
- Camera Features
- Privacy shutter, Windows Hello, fixed focus, hybrid FHD/IR camera
- Sound
- Stereo speakers, dual array microphone
- Codec
- Realtek ALC3287
- High Definition Audio, Dolby Audio
- Audio Features
- Input: Dolby Voice
Input
- Keyboard, TrackPoint, UltraNav
- Keyboard Layout
- UK
- Spill-resistant, multi-touch touchpad, Fn keys with Unified Communications controls
Communications
- Wireless
- Wireless Controller
- Intel Wi-Fi 6 AX 201 - M.2 Card
- Network Interface
- Gigabit Ethernet
- Ethernet Controller
- Intel I219-V
- Wake-on-LAN (WOL), dual stream (2x2)
Wireless Broadband (WWAN)
- Generation
- 4G upgradable
- Technology
- Lithium polymer
- Capacity
- 57 Wh
AC Adapter
- Input
- AC 100-240 V (50/60 Hz)
- Output
- 65 Watt
Connections & Expansion
- Interfaces Details
- USB 3.2 Gen 1 , USB 3.2 Gen 1 (Always On) , USB-C 3.2 Gen 2 (supports DisplayPort 1.4 Alt Mode) (Power Delivery 3.0) , USB4 (supports Thunderbolt 4, DisplayPort 1.4 Alt Mode) (Power Delivery 3.0) , HDMI (4K support) , LAN , Headphone/microphone combo jack
- Memory Card Reader
- Yes (microSD)
- Thunder black
- Case Material
- Polycarbonate ABS (bottom), polycarbonate ABS (top)
- Security
- Administrator password, power-on password, RapidCharge, MIL-STD-810H tested, self-healing BIOS, NVMe password
- Theft/Intrusion Protection
- Security Slot Type
- Kensington nano security slot
- Included Accessories
- USB-C power adapter
- RoHS, Energy-Related Products (ErP) Lot 6, TCG Certified, Energy-Related Products (ErP) Lot 26
- Localization
- Lenovo TopSeller
- 1.4 kg
Sustainability Information
- TCO Certified
- - TCO Certified Notebooks 9
- EPEAT Compliant
- EPEAT Gold
- ENERGY STAR Certified
- Bundled Services
- 5 °C
- 35 °C
- 8 - 95%
Essential Accessories (6)
Get more from your purchase from one of our essential accessories
Lenovo 3M 14.0W Privacy Filter | In Stock | £37.80 |
Lenovo 45W Standard AC Adapter (USB Type-C) Power Adapter | In Stock | £26.49 |
Lenovo 65W Standard AC Adapter USB-C | In Stock | £28.46 |
Lenovo USB-C 65W AC Adapter AC 100-240 V 65Watt for ThinkPad A275 | In Stock | £29.48 |
Lenovo ThinkPad Hybrid USB-C with USB-A Dock - Do | In Stock | £192.93 |
Lenovo 65W USB-C DC Travel Adapter | In Stock | £41.27 |
Warranty Packs (1)
Protect your investment by taking out one of our great value warranty packs
Lenovo ThinkPad 3YR Onsite Epaq | In Stock | £162.07 |
Other bundles (8)
Lenovo USB Soundbar for Display | In Stock | £30.11 |
Lenovo HDMI to VGA Monitor Adapter | In Stock | £23.14 |
Lenovo Essential Wireless Keyboard and Mouse Combo - UK English 166 | In Stock | £27.12 |
Lenovo Professional Wireless Keyboard | In Stock | £52.99 |
Lenovo ThinkPad USB3.0 to Ethernet Adapter | In Stock | £16.03 |
Lenovo ThinkPad Bluetooth Silent Mouse - Right and Left-handed | In Stock | £23.81 |
Lenovo USB-C Cable 1M | In Stock | £15.76 |
Lenovo Thinkvision MC50 Monitor Webcam | In Stock | £52.49 |
