Lenovo ThinkPad L13 G2 Intel Core i7-1165G7 16GB 512GB SSD 13.3" Windows 10 Professional 64-bit
Quicklinx: GBCTWS00 Mfr#: 20VH004FUK
  • Core i7
  • IEEE 802.11n
The ThinkPad L13 Gen 2 laptop delivers powerful next-gen performance and graphics. It's an easy travel companion. Rapid Charge keeps you unplugged longer, and speedy Wi-Fi 6 ensures a smooth experience, even on crowded platforms. Plus Modern Standby and call-control keys boost your productivity.
  • Breaks performance boundaries
    The ThinkPad L13 Gen 2 laptop features powerful processors and amazing graphics. You'll enjoy perfect CPU performance, immersive graphics, amazing AI acceleration, and wired and wireless connectivity to help you focus, create, and engage at another levels.
  • Breeze through your to-do list
    With a host of time-saving features, the ThinkPad L13 Gen 2 laptop will streamline your workflow and keep you productive. Modern Standby enables the system to wake and connect to the Internet instantaneously. And with just the touch of a button, you can easily answer, make, and disconnect from conference calls by using the F9-F11 function keys.
  • Focus on the task at hand
    Go where you need to go - and don't worry about electrical outlets. All-day battery life on the ThinkPad L13 Gen 2 laptop keeps you unplugged - but when you do need more juice, plug it in for just 60 minutes and Rapid Charge will yield up to 80%.
  • Connections keep you up and running
    Wi-Fi 6 lets you jump on crowded public platforms fast and enjoy smooth online experiences with greater bandwidth, stable network connectivity, and lower latency. And ports aplenty, including four USB ports - one with the Intel Thunderbolt 4 - an HDMI 2.0 port, and side-mechanical docking, keep you connected to what matters most, no matter where you are.
  • Business-class security
    The ThinkPad L13 Gen 2 business PC keeps your data and your device protected through an updated suite of built-in ThinkShield security solutions. The discrete Trusted Platform Module (dTPM) encrypts data making it more difficult to hack.
  • Tested to extremes
    Like all ThinkPad laptops, the L13 Gen 2 is tested against 12 military-grade requirements and more than 200 quality checks. From the Arctic wilderness to desert dust storms, from zero-gravity to spills and drops, you can trust these laptops to handle whatever life throws your way.
Lenovo ThinkPad L13 Gen 2 - 13.3" - Intel Core i7 - 1165G7 - 16 GB RAM - 512 GB SSD - UK
Notebook
Operating System
Win 10 Pro 64-bit - English
Intel Core i7 (11th Gen) - 1165G7 / 2.8 GHz, up to 4.7 GHz / 12 MB Cache
16 GB DDR4 (provided memory is soldered)
Storage
512 GB SSD - TCG Opal Encryption 2, NVMe
Display
13.3" LED backlight 1920 x 1080 / Full HD
Graphics
Intel Iris Xe Graphics
Input Device
TrackPoint, UltraNav
Keyboard
Keyboard Backlight
Integrated Webcam
802.11a/b/g/n/ac/ax, Bluetooth 5.1
Up to 12.25 hours
Dockable
Security
Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader, smart card reader
31.15 cm x 21.9 cm x 1.76 cm
1.39 kg
Manufacturer Selling Program
Lenovo TopSeller
Environmental Standards
ENERGY STAR Qualified EPEAT Gold
Limited warranty - 1 year - pick-up and return
Bundled Services
1 Year Lenovo Premier Support
Notebook
Operating System
Windows 10 Pro 64-bit Edition - English
Processor / Chipset
CPU
Intel Core i7 (11th Gen) 1165G7 / 2.8 GHz
Max Turbo Speed
4.7 GHz
Number of Cores
Quad-Core
Cache
12 MB
Integrated memory controller
RAM
16 GB (provided memory is soldered)
DDR4 SDRAM
Speed
3200 MHz
Rated Speed
1600 MHz
Storage
Main Storage
512 GB SSD M.2 2280 PCIe 3.0 x4 - TCG Opal Encryption 2, NVM Express (NVMe)
Display
13.3" - IPS
LCD Backlight Technology
LED backlight
Resolution
1920 x 1080 (Full HD)
Widescreen
Image Aspect Ratio
16:9
Image Brightness
250 cd/m²
Colour Gamut
45%
Anti-glare, 170° viewing angle
Audio & Video
Graphics Processor
Intel Iris Xe Graphics - up to
Camera
Yes - 720p
Camera Features
IR camera, ThinkShutter camera privacy
Sound
Stereo speakers, dual array microphone
Codec
Conexant CX11880
High Definition Audio, Dolby Audio Premium
Input
Keyboard, TrackPoint, UltraNav
Keyboard Backlight
Keyboard Layout
Spill-resistant, multi-touch touchpad, buttonless touchpad, Fn keys with Unified Communications controls
Communications
Wireless
Wireless Controller
Intel Wi-Fi 6 AX 201 - M.2 Card
Gigabit Ethernet via optional Ethernet (RJ-45) adapter, dual stream (2x2)
Lithium Ion
46 Wh
Run Time
Up to 12.25 hours
AC Adapter
Input
AC 100-240 V (50/60 Hz)
Output
65 Watt
Connections & Expansion
Interfaces Details
USB 3.2 Gen 1 (Always On) , USB 3.2 Gen 1 , USB-C 3.2 Gen 2 (supports DisplayPort Alt Mode) (Power Delivery) , USB4 (supports Thunderbolt 4, DisplayPort Alt Mode) (Power Delivery) , HDMI , Lenovo Ethernet extension connector , Headphone/microphone combo jack , Dock
Memory Card Reader
Yes (microSD)
Case Material
Aluminum, glass-fibre reinforced plastic
Dockable
Security
Administrator password, hard drive password, power-on password, RapidCharge, MIL-STD-810H tested
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
USB-C power adapter
RoHS
Localization
Lenovo TopSeller
1.39 kg
Sustainability Information
TCO Certified
EPEAT Compliant
EPEAT Gold
ENERGY STAR Certified
Bundled Services
Essential Accessories (3)
Get more from your purchase from one of our essential accessories
GBCT Lenovo 45W Standard AC Adapter (USB Type-C) Power Adapter In Stock £26.49
GBCT Lenovo ThinkPad Hybrid USB-C with USB-A Dock - Do In Stock £192.93
GBCT Kensington Security Cable Lock In Stock £23.59
Warranty Packs (1)
Protect your investment by taking out one of our great value warranty packs
GBCT Lenovo ThinkPad 3YR Onsite Epaq In Stock £162.07
Other bundles (8)
GBCT Lenovo HDMI to VGA Monitor Adapter In Stock £23.14
GBCT Lenovo Essential Wireless Keyboard and Mouse Combo - UK English 166 In Stock £27.12
GBCT Lenovo Professional Wireless Keyboard In Stock £52.99
GBCT Lenovo ThinkPad Ethernet Extension Adapter Gen 2 In Stock £24.46
GBCT Lenovo ThinkPad USB3.0 to Ethernet Adapter In Stock £16.03
GBCT Lenovo ThinkVision T27q-20 27" 2560x1440 4ms HDMI DisplayPort IPS LED Monitor In Stock £312.36
GBCT Lenovo ThinkPad Bluetooth Silent Mouse - Right and Left-handed In Stock £23.81
GBCT Lenovo Thinkvision MC50 Monitor Webcam In Stock £52.49
