Simple. Powerful. Compatible. The E580 is easy for IT to deploy, the hardware compatibility of multiple USB ports, and the energy efficiency of 8th Gen quad-core Intel processors delivering faster performance. Reliable. Repairable. Secure. The E580 makes IT maintenance easy, too. It's reliable - as shown by the series of rigorous tests it undergoes against shocks, drops, and other extremes.
The E580 is ready to tackle your tasks, thanks to the Intel Core processors, AMD Radeon discrete graphics, and more. With up to 1x1 AC Wi-Fi and full array of ports - including USB-C, USB 3.1, HDMI, and more - it will keep you connected to the internet and a variety of external devices.
The thin and light E580 was built for the road warrior. The ergonomic keyboard was engineered for comfort and accuracy. Its backlighting lets you use it in low-light surroundings and complete tasks despite the late hours. And with long hours of battery life, you'll get a lot of uninterrupted time without worrying about electrical outlets. Stay one step ahead, no matter where the job takes you.
Keeps IT departments as happy as their users
Simple. Powerful. Compatible. The E580 is easy for IT to deploy, the hardware compatibility of multiple USB ports, and the energy efficiency of 8th Gen quad-core Intel processors delivering faster performance. Reliable. Repairable. Secure. The E580 makes IT maintenance easy, too. It's reliable - as shown by the series of rigorous tests it undergoes against shocks, drops, and other extremes. -
Scratch items off your to-do list
The E580 is ready to tackle your tasks, thanks to the Intel Core processors, AMD Radeon discrete graphics, and more. With up to 1x1 AC Wi-Fi and full array of ports - including USB-C, USB 3.1, HDMI, and more - it will keep you connected to the internet and a variety of external devices. -
Working anywhere just got easier
The thin and light E580 was built for the road warrior. The ergonomic keyboard was engineered for comfort and accuracy. And with long hours of battery life, you'll get a lot of uninterrupted time without worrying about electrical outlets. Stay one step ahead, no matter where the job takes you. -
Don't forget to smile
The E580 offers superb video-conferencing experience, thanks to its dual-array microphone, HD webcam, large 15.6" IPS FHD display, and stereo speakers with Dolby Advanced Audio. Revel in the rich sound and visuals so clear, you'll feel like you're in the same room.
- Lenovo ThinkPad E580 - 15.6" - Intel Core i5 - 8250U - 4 GB RAM - 1 TB HDD - UK
- Product Type
- Notebook
- Operating System
- Win 10 Pro 64-bit
- Processor
- Intel Core i5 (8th Gen) - 8250U / 1.6 GHz, up to 3.4 GHz / 6 MB Cache
- Memory
- 4 GB DDR4 (1 x 4 GB)
- Storage
- 1 TB HDD / 5400 rpm
- Display
- 15.6" LED backlight 1920 x 1080 / Full HD
- Graphics
- Intel UHD Graphics 620
- Input Device
- TrackPoint, UltraNav
- Keyboard
- UK
- Numeric Keypad
- Integrated Webcam
- Networking
- 802.11a/b/g/n/ac, Bluetooth 4.1, Gigabit Ethernet
- Battery
- 3-cell - up to 13 hours
- Security
- Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader
- Black
- 36.9 cm x 25.2 cm x 1.995 cm
- 2.1 kg
- Localisation
- Manufacturer Selling Program
- TopSeller
- Environmental Standards
- ENERGY STAR Qualified
- Specific Absorption Rate (SAR)
- 0.579 W/kg (body) ¦ 0.579 W/kg (limb)
- Limited warranty - 1 year - pick-up and return
- Product Type
- Notebook
- Operating System
- Windows 10 Pro 64-bit Edition
Processor / Chipset
- CPU
- Intel Core i5 (8th Gen) 8250U / 1.6 GHz
- Max Turbo Speed
- 3.4 GHz
- Number of Cores
- Quad-Core
- Cache
- 6 MB
- 64-bit Computing
- Integrated memory controller
- RAM
- 4 GB (1 x 4 GB)
- Max RAM Supported
- 32 GB
- Technology
- DDR4 SDRAM
- Speed
- 2400 MHz
- Rated Speed
- 2400 MHz
- Form Factor
- SO-DIMM 260-pin
- Slots Qty
- 2
- Empty Slots
- 1
Storage
- Main Storage
- 1 TB HDD SATA 6Gb/s / 5400 rpm
Display
- 15.6" - IPS
- LCD Backlight Technology
- LED backlight
- Resolution
- 1920 x 1080 (Full HD)
- Widescreen
- Image Aspect Ratio
- 16:9
- Image Brightness
- 250 cd/m²
- Anti-glare
Audio & Video
- Graphics Processor
- Camera
- Yes - 720p
- Sound
- Stereo speakers, dual array microphone
- Codec
- CX11852
- High Definition Audio, Dolby Advanced Audio
Input
- Keyboard, TrackPoint, UltraNav
- Keyboard Layout
- UK
- Numeric Keypad
- Spill-resistant, multi-touch touchpad, buttonless touchpad
Communications
- Wireless
- Wireless Controller
- Intel Dual Band Wireless-AC 3165 - M.2 Card
- Network Interface
- Gigabit Ethernet
- Ethernet Controller
- Realtek R8111GUS
- Technology
- 3-cell Lithium Ion
- Capacity
- 45 Wh
- Run Time
- Up to 13 hours
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 65 Watt
Connections & Expansion
- Interfaces Details
- USB 3.1 Gen 1 ¦ USB 3.1 Gen 1 (Always On) ¦ USB 2.0 ¦ HDMI ¦ LAN ¦ USB-C 3.1 Gen 2 ¦ Headphone/microphone combo jack
- Memory Card Reader
- Yes (microSD)
Software
- Software Included
- Lenovo Companion, McAfee LiveSafe (30 days trial), PC Manager
- Black
- Case Material
- Aluminum, polycarbonate ABS
- Security
- Administrator password, hard drive password, power-on password, ThinkVantage Active Protection System
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- Included Accessories
- USB-C power adapter
- RoHS
- SAR Value
- 0.579 W/kg (body), 0.579 W/kg (limb)
- Localization
- TopSeller
- 2.1 kg
Sustainability Information
- TCO Certified
- ENERGY STAR Certified
