Lenovo ThinkPad Bluetooth Silent Mouse - Right and Left-handed
Quicklinx: G7JJWS00 Mfr#: 4Y50X88822
More than 50 In Stock
£23.88 ex VAT
£28.65 inc VAT
The ThinkPad Bluetooth Silent mouse takes a well-worn concept and turns it on its head, delivering a productivity device that doesn't get in the way of the busy professionals who use it. It sculpted to be comfortable to rest your palm on, with a low-profile, minimalist design that makes the mouse easy to carry and fit into pockets without bulging. Get more done with the blue optical sensor that allows you to work on most surfaces, revolutionary, distraction-free silent buttons, and on-the-fly adjustable DPI controls. Effortlessly pair with up to two devices at once and quickly switch between them with the push of a button, thanks to Bluetooth 5.0 and Microsoft Swift Pair technology.
  • Work Comfortably
    The ThinkPad Bluetooth Silent Mouse is sculpted to be comfortable to rest your palm on, with a low-profile, minimalist design that makes the mouse easy to carry and fit into pockets without bulging.
  • Get More Done
    Take your productivity to the max with a blue optical sensor that allows you to work on almost any surface, revolutionary, distraction-free silent buttons, and on-the-fly adjustable DPI controls.
  • Connect Conveniently
Lenovo ThinkPad Silent - mouse - Bluetooth 5.0 - black
Mouse
Wireless - Bluetooth 5.0
Orientation
Right and left-handed
5.8 cm x 10.7 cm x 2.9 cm
61 g
Movement Detection Technology
Blue optical
Buttons Qty
3
Movement Resolution
2400 dpi
Performance
Realtime sensitivity switching 800/1600/2400 dpi
Scrolling 2-way button, on-the-fly DPI switching, ambidextrous design, Swift Pair, low profile design
AA type
Package Type
Retail
1-year warranty
Mouse
Orientation
5.8 cm
10.7 cm
2.9 cm
61 g
Input Device
Wireless
Bluetooth 5.0
Blue optical
Buttons Qty
3
Movement Resolution
2400 dpi
Performance
1 AA battery
BSMI, CB, EMC, IC, MIC, FCC, ANATEL, cTUVus, WPC, KC, SRRC, NCC, EN 62471:2008, TRA, Subtel, IMDA, JRF, ictQATAR, TUV Mark
Package Type
Retail
AA type
Run Time (Up To)
12 months
Shipping Width
11 cm
Shipping Depth
4 cm
Shipping Height
7.8 cm
Shipping Weight
129 g
Limited warranty - 1 year
10 - 90%
