Lenovo ThinkPad Battery 68+ (6 cell)
Quicklinx: 9GC8WS00 Mfr#: 0C52862
The Lenovo ThinkPad Battery 68+ is compatible with the W550, T440, T440s, L450, T450s, T450, T550, X250 and X240 systems. This 6-cell battery utilises Lithium-Ion technology and allows you to stay unplugged for longer, providing the longest possible battery life. The battery can provide power for approximately 72 watt hours and is rechargeable. A safe flow of power is ensured by the over-discharge protection, which prevents damage due to incorrect voltage. Each one is safeguarded with a chip that authenticates with Lenovo systems.
*Battery life differs due to a multitude of factors, including features, battery conditioning, power management, applications, screen brightness and other customer preferences.
Lenovo ThinkPad Battery 68+ - laptop battery - Li-Ion - 6.6 Ah
Laptop battery
335 g
Lithium Ion 6-cell - 6.6 Ah
20.67 cm x 6.4 cm x 2.39 cm
1-year warranty
ThinkPad A275; L450; L460; L470; P50s; T440; T440s; T450; T450s; T460; T460p; T470p; T550; T560; W550s; X12 Detachable; X240; X250; X260; X270
Laptop battery
6-cell Lithium Ion
Voltage Provided
10.8 V
6.6 Ah
UL, C-Tick, cUL, ACA
Limited warranty - 1 year
5 °C
35 °C
8 - 95%
20.67 cm
6.4 cm
2.39 cm
335 g
Lenovo ThinkPad A275 20KC, 20KD , Lenovo ThinkPad L450 20DS, 20DT , Lenovo ThinkPad L460 20FU, 20FV , Lenovo ThinkPad L470 20JU, 20JV , Lenovo ThinkPad P50s 20FK, 20FL , Lenovo ThinkPad T440 20B6, 20B7 , Lenovo ThinkPad T440s 20AQ, 20AR , Lenovo ThinkPad T450 20BU, 20BV , Lenovo ThinkPad T450s 20BW, 20BX , Lenovo ThinkPad T460 20FM , Lenovo ThinkPad T460p 20FW, 20FX , Lenovo ThinkPad T470p 20J6, 20J7 , Lenovo ThinkPad T550 20CJ, 20CK , Lenovo ThinkPad T560 20FH, 20FJ , Lenovo ThinkPad W550s 20E1, 20E2 , Lenovo ThinkPad X12 Detachable 20UV, 20UW , Lenovo ThinkPad X240 20AL, 20AM , Lenovo ThinkPad X250 20CL, 20CM , Lenovo ThinkPad X260 20F5, 20F6 , Lenovo ThinkPad X270 20HM, 20HN, 20K5, 20K6
