The ThinkPad 90 W AC adapter performs to the same specifications as the standard 90 W AC adapter supplied with older ThinkPad systems. Designed for the older-generation ThinkPads with round-barrel adapter tips, it is ideal as a replacement or spare system charger. Each adapter is backed by an official one-year Lenovo warranty, offering renowned service and support from IBM.
- Lenovo ThinkPad 90W AC Adapter - power adapter - 90 Watt
- Power adapter - external
- 0.5 kg
- Localisation
- United Kingdom
- Output Voltage
- 20 V
- Power Capacity
- 90 Watt
- 5.6 cm x 13.5 cm x 2.7 cm
- 1-year warranty
- Localisation
- United Kingdom
- Output Voltage
- 20 V
- Power Capacity
- 90 Watt
- Cables Included
- Power cable
- VCCI, C-Tick, BSMI, GOST, cUL, NEMKO, NOM, CCC, PSB, FCC
- Limited warranty - 1 year
- 5.6 cm
- 13.5 cm
- 2.7 cm
- 0.5 kg
