The Lenovo ThinkPad 65 W AC adapter ensures convenient access to power whenever you need it. Compatible with post-2013 Lenovo notebooks with the rectangular "slim-tip" common power plug, it performs to the same specifications as the standard AC adapter shipped with compatible notebooks. The ThinkPad slim adapters are both compact and incredibly energy efficient, with Energy Star V (ES 2.0) technology. Each adapter is backed by a one-year limited warranty, providing renowned service and support from Lenovo.
Efficient charging
Designed specifically for Lenovo ThinkPad laptops, this 65W AC Adapter (Slim Tip) ensures your device receives the right amount of power for efficient charging. Its slim tip design makes it easy to connect, providing a secure and stable power source for your laptop. -
Portable design
With its external form factor, the Lenovo ThinkPad 65W AC Adapter is built for users on-the-go. Its compact size and lightweight construction mean it can easily be packed into a bag or briefcase, ensuring you can charge your laptop wherever you are, without the bulk.
- Lenovo ThinkPad 65W AC Adapter (Slim Tip) - power adapter - 65 watt - Lenovo Campus
- Power adapter - external
- 235 g
- Localisation
- Saudi Arabia, Europe
- Power Capacity
- 65 watt
- Manufacturer Selling Program
- Lenovo Campus
- 4.4 cm x 10.5 cm x 2.85 cm
- 1-year warranty
- Designed For
- ThinkPad T16 Gen 4 21QN
- Localisation
- Input Voltage Range
- AC 100 - 240 V
- Frequency Required
- 50/60 Hz
- Power Capacity
- 65 watt
- UL, C-Tick, BSMI, GOST, cUL, GS, NEMKO, NOM, CB, CCC, EMC, PSB, FCC, PSE Mark, ICES, MEPS, KC, CECP, EMI
- Lenovo Campus
- Limited warranty - replacement - 1 year
- 5 °C
- 40 °C
- 8 - 80% (non-condensing)
- 4.4 cm
- 10.5 cm
- 2.85 cm
- 235 g
- Designed For
- Lenovo ThinkPad T16 Gen 4 21QN
