Lenovo ThinkPad 135W AC Adapter (Slim tip) - UK
Quicklinx: 9SDYWS00 Mfr#: 4X20E50566
Device Type: Laptop
Type: Power Adapter
Device Screen Size: [N/A]
Colour: Black
More than 50 In Stock
£80.32 ex VAT
£96.38 inc VAT
Get power when and where you need it, with the ThinkPad 135 W AC adapter. Keep one in the office, one at home and another in your carrying case for convenient access to power. Just plug it into an available wall socket to deliver AC power to your compatible ThinkPad laptop and recharge the system battery. ThinkPad AC adapters are compact, energy-efficient (Energy Star V (ES 2.0) rating) and backed by a one-year warranty Performs to the same specifications as the standard AC adapter that is supplied with ThinkPad laptops, so it is a perfect replacement or spare. The ThinkPad 135 W AC adapter is only compatible with ThinkPad laptops with a rectangular "slim tip" common power plug. It is not compatible with ThinkPad laptops with the round, barrel-type power plug.
Lenovo ThinkPad 135W AC Adapter (Slim Tip) - power adapter - 135 Watt
Power adapter - external
500 g
Saudi Arabia, Hong Kong, Myanmar, Malaysia, Singapore, Malta, United Kingdom, Ireland
Input Voltage
AC 100-240 V
Power Capacity
135 Watt
6.5 cm x 14.5 cm x 3 cm
Environmental Standards
ENERGY STAR
1-year warranty
ThinkPad T540p 20BE, 20BF
Input Voltage
AC 100-240 V
Frequency Required
50/60 Hz
Power Capacity
135 Watt
Power cable
UL, C-Tick, BSMI, GOST, cUL, GS, NEMKO, NOM, CB, CCC, EMC, PSB, FCC, PSE Mark, ICES, MEPS, KC, CECP
Sustainability Information
ENERGY STAR
Limited warranty - 1 year
5 °C
8 - 80% (non-condensing)
6.5 cm
14.5 cm
3 cm
500 g
Lenovo ThinkPad T540p 20BE, 20BF
Device Type: Laptop
Type: Power Adapter
Colour: Black
Brand: Lenovo
