Lenovo Thinkpad 13 20H1 Core i5-7200U 4GB 256GB 13.3" Win 10 Pro
Quicklinx: D109WS00 Mfr#: 20J1004DUK
  • Core i5
  • IEEE 802.11n
The ThinkPad 13 balances mobility and productivity for professionals, students, and educators. Built to deliver high durability, it can withstand the travails of the boardroom and the classroom - yet it's very light, and features a long battery life.
  • Tough enough for the military
    Tested against 12 military-grade requirements and passing more than 200 quality checks, ThinkPad 13 was designed to withstand work, travel, fun, and anything else you can throw at it.
  • Keep your hands on the keyboard - because you'll want to
    The legendary ThinkPad keyboard is so comfortable to use, you won't want to move your fingers off it - not even to use a mouse. So it's a good thing you won't have to, because this keyboard includes two pointing options - the world-famous TrackPoint and our intuitive, clickable TrackPad. Move your cursor, make selections, zoom in and out, and drag and drop easily and comfortably. These features are only two of the reasons our keyboard has won awards and the hearts of users across the world! It's accurate, ergonomic, and easy to see at any time, thanks to its two-stage adjustable soft-white backlight.
  • Easy to take with you - even without a charger
    At 3.17 lbs/1.44 kg and merely 0.75" - 0.77" thin / 19.1 mm - 19.8 mm, ThinkPad 13 is eminently portable. And it has all the battery power you need - up to 11 hours - to move from desk to meetings and elsewhere, and stay productive throughout the business day with plenty of charge left afterward.
  • Productivity never looked so good
    ThinkPad 13 has a 13.3" display that renders in Full High Definition (FHD), so even spreadsheets look beautiful. And with In-plane Switching (IPS) technology, they'll show in vibrant color and be visible from almost any angle.
  • Lose the Ethernet cable
    With support for 802.11 AC wireless signals, there's no need to be limited by the length of an Ethernet cable. Simply access the signal available from many wireless routers, and you're online in no time.
  • Plenty of ports
    Connect to just about any accessory you need, whether it's an external drive via speedy USB 3.0, a phone or other device via USB Type-C, or a TV or other monitor via HDMI. Whatever you have, plug it in and get started.
  • Docking with power
    A OneLink+ port enables you to transform ThinkPad 13 into a full-featured machine at your desk. Simply plug into the dock and you have instant access to superfast data transfers; high-quality, uncompressed video; and convenient accessories such as keyboard, mouse, printer, and up to two external displays. And the OneLink+ connector charges your battery while you're working.
Lenovo Thinkpad 13 (2nd Gen) - 13.3" - Intel Core i5 - 7200U - 8 GB RAM - 256 GB SSD - UK
Ultrabook
Operating System
Win 10 Pro 64-bit
Intel Core i5 (7th Gen) - 7200U / 2.5 GHz, up to 3.1 GHz / 3 MB Cache
8 GB DDR4 (1 x 8 GB)
Storage
256 GB SSD - TCG Opal Encryption 2, NVMe
Display
13.3" LED backlight 1920 x 1080 / Full HD
Graphics
Intel HD Graphics 620
Input Device
TrackPoint, UltraNav
Keyboard
Integrated Webcam
802.11a/b/g/n/ac, Bluetooth 4.1
3-cell - up to 14.56 hours
Dockable
Security
Trusted Platform Module (TPM 2.0) Security Chip
Silver
32.24 cm x 22.28 cm x 1.91 cm
1.44 kg
Manufacturer Selling Program
TopSeller
Environmental Standards
ENERGY STAR Qualified
Limited warranty - 1 year - pick-up and return
Ultrabook
Operating System
Windows 10 Pro 64-bit Edition
Processor / Chipset
CPU
Intel Core i5 (7th Gen) 7200U / 2.5 GHz
Max Turbo Speed
3.1 GHz
Number of Cores
Dual-Core
Cache
3 MB
64-bit Computing
Integrated memory controller
RAM
8 GB (1 x 8 GB)
Max RAM Supported
32 GB
DDR4 SDRAM
Speed
2133 MHz
Rated Speed
1067 MHz
SO-DIMM 260-pin
Slots Qty
2
Empty Slots
1
Storage
Main Storage
256 GB SSD M.2 PCIe - TCG Opal Encryption 2, NVM Express (NVMe)
Display
13.3" - IPS
LCD Backlight Technology
LED backlight
Resolution
1920 x 1080 (Full HD)
Widescreen
Image Aspect Ratio
16:9
Image Brightness
250 cd/m²
Anti-glare
Audio & Video
Graphics Processor
Intel HD Graphics 620 - up to
Camera
Yes - 720p
Sound
Stereo speakers, dual array microphone
Codec
Realtek ALC3268
High Definition Audio
Input
Keyboard, TrackPoint, UltraNav
Keyboard Layout
Multi-touch touchpad, buttonless touchpad
Communications
Wireless
Wireless Controller
Intel Dual Band Wireless-AC 8265 - M.2 Card
3-cell Lithium Ion
42 Wh
Run Time
Up to 14.56 hours
AC Adapter
Input
Output
45 Watt
Connections & Expansion
Interfaces Details
2 x USB 3.1 Gen 1/USB 3.0 , USB-C , OneLink+ connector , Headphone/microphone combo jack , HDMI , USB 3.1 Gen 1/USB 3.0 (Always On)
Memory Card Reader
4 in 1 (SD Card, MultiMediaCard, SDHC Card, SDXC Card)
Software
Software Included
Lenovo Companion, Lenovo Settings
Silver
Case Material
Aluminum
Dockable
Security
Administrator password, hard drive password, power-on password, MIL-STD-810G tested
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
Power adapter
RoHS
Localization
TopSeller
1.44 kg
Sustainability Information
TCO Certified
ENERGY STAR Certified
