The ThinkCentre Tiny VESA Mount is a unique design specific to house the Tiny PC while featuring the universal VESA mount configuration. The VESA standard enables this mount to attach to anything that is VESA compatible for the utmost in mounting flexibility. This versatile mounting device can be used separately or combined with other options for secure mounting functionality.
- Lenovo Tiny VESA Mount - system mounting bracket
- Product Type
- System mounting bracket
- 18.4 cm x 4.3 cm x 18.4 cm
- 284 g
- 3-year warranty
- Designed For
- ThinkCentre M700; M715q 10M2 (tiny), 10M3 (tiny); M72e (tiny); M900 10FL, 10FM, 10FR (tiny), 10FS (tiny), 10NE; M92 (tiny); M92p (tiny); M93p (tiny)
- Product Type
- 18.4 cm
- 4.3 cm
- 18.4 cm
- 284 g
- CSA, UL, C-Tick, BSMI
- Limited warranty: replacement - 3 years
- 5 °C
- 35 °C
- Designed For
- Lenovo ThinkCentre M700 , Lenovo ThinkCentre M715q 10M2 (tiny), 10M3 (tiny) , Lenovo ThinkCentre M72e (tiny) , Lenovo ThinkCentre M900 10FL, 10FM, 10FR (tiny), 10FS (tiny), 10NE , Lenovo ThinkCentre M92 (tiny) , Lenovo ThinkCentre M92p (tiny) , Lenovo ThinkCentre M93p (tiny)
