The Tiny-in-One 27 is designed to enhance productivity. With facial recognition and a webcam privacy cover, this 27" monitor is security minded.
Completely practical
Thanks to an RGB IR camera with dual microphones, video calls are seamless and crystal clear. In addition, the Tiny-in-One 27 has plenty of ports, all conveniently situated for you to recharge and connect your other devices. -
Eye catching and eye friendly
The Tiny-in-One 27 isn't just easy on the eye. Your eyes will tire far less with this monitor compared with other displays. It also has an anti-glare filter to help make your viewing more comfortable. -
Move along, nothing to steal here
The Tiny-in-One 27 is fitted with a lock slot. So you can secure it to a desk or something equally sturdy or immovable, thereby deterring anyone from walking off with your device.
- Lenovo ThinkCentre Tiny-in-One 27 - LED monitor - 27"
- LED-backlit LCD monitor - 27"
- USB 3.1 Gen 1 hub, dual array microphone, RGBIR camera
- Aspect Ratio
- 16:9
- Native Resolution
- 2560 x 1440 at 60 Hz
- Pixel Pitch
- 0.2331 mm
- Brightness
- 350 cd/m²
- Contrast Ratio
- 1000:1
- Response Time
- 6 ms, 4 ms (overdrive), 14 ms (default)
- Colour Gamut
- 99% sRGB
- Input Connectors
- HDMI, DisplayPort
- Height, pivot (rotation), swivel, tilt
- Screen Coating
- Anti-glare (25%)
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- 61.4 cm x 32.9 cm x 44.425 cm
- 7.95 kg
- Localisation
- English / United Kingdom
- Environmental Standards
- TCO Certified Displays 8, TCO Certified Edge Displays, ENERGY STAR Qualified EPEAT Silver
- FCC Class B certified, VESA DPMS, VESA FPMPMI, RoHS, ISO 9241-307, WEEE, UL Environmental SPC Gold, VOC, TUV Rheinland Eye Comfort Certification, VESA DDCCi
- 3-year warranty
- Display Type
- Diagonal Size
- 27"
- Built-in Devices
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.2331 mm
- Pixel Per Inch
- 109
- Brightness
- 350 cd/m²
- Contrast Ratio
- 1000:1
- Colour Gamut
- 99% sRGB
- Response Time
- Horizontal Viewing Angle
- +89 / -89
- Vertical Viewing Angle
- +89 / -89
- Screen Coating
- Anti-glare (25%)
- Backlight Technology
- WLED
- 3-side NearEdgeless, 99% sRGB colour gamut
- Black
- 61.4 cm x 32.9 cm x 44.425 cm - with stand
- 7.95 kg
Audio
- Speakers - stereo
- Output Power / Channel
- 2 Watt
- DisplayPort/USB 3.0/power (undetachable 3-in-1 cable) , Headphone/microphone combo jack , USB 3.1 Gen 1 upstream (Type B) , 2 x USB 3.1 Gen 1 downstream , DisplayPort , HDMI
Mechanical
- Tilt Angle
- -5/+35
- Swivel Angle
- 90
- Rotation Angle
- -5/+90
- Height Adjustment
- 110 mm
- VESA Mounting Interface
- 100 x 100 mm
- Security lock slot (cable lock sold separately), 88% efficiency power supply, Tiny PC dock
- Mounting Kit
- Optional
- Localisation
- Security Slot Type
- Kensington security slot
- Input Voltage
- Power Consumption (Typical)
- 37 Watt
- Power Consumption Stand by
- 0.5 Watt
- Power Consumption Sleep
- 0.5 Watt
- Dimensions & Weight Details
- With stand (lowest position) - width: 61.4 cm - depth: 32.9 cm - height: 44.425 cm - weight: 7.95 kg , With stand (highest position) - width: 61.4 cm - depth: 32.9 cm - height: 55.425 cm - weight: 7.95 kg , Without stand - width: 61.4 cm - depth: 7.389 cm - height: 41.31 cm - weight: 4.91 kg
Sustainability Information
- TCO Certified
- EPEAT Compliant
- EPEAT Silver
- ENERGY STAR Certified
- ENERGY STAR Version
- 7.0
- Limited warranty - 3 years
