Lenovo ThinkCentre Tiny-in-One 27" 2560x1440 4ms HDMI DisplayPort LED Monitor
Quicklinx: GTQ3WS00 Mfr#: 11JHRAT1UK
Diagonal Size: 27in
Max Resolution: 2560 x 1440
Response Time: 4ms
Speakers: Speaker(s)
Interfaces: DisplayPort, HDMI
16 In Stock
£249.32 ex VAT
£299.18 inc VAT
The Tiny-in-One 27 is designed to enhance productivity. With facial recognition and a webcam privacy cover, this 27" monitor is security minded.
  • Completely practical
    Thanks to an RGB IR camera with dual microphones, video calls are seamless and crystal clear. In addition, the Tiny-in-One 27 has plenty of ports, all conveniently situated for you to recharge and connect your other devices.
  • Eye catching and eye friendly
    The Tiny-in-One 27 isn't just easy on the eye. Your eyes will tire far less with this monitor compared with other displays. It also has an anti-glare filter to help make your viewing more comfortable.
  • Move along, nothing to steal here
    The Tiny-in-One 27 is fitted with a lock slot. So you can secure it to a desk or something equally sturdy or immovable, thereby deterring anyone from walking off with your device.
Lenovo ThinkCentre Tiny-in-One 27 - LED monitor - 27"
LED-backlit LCD monitor - 27"
USB 3.1 Gen 1 hub, dual array microphone, RGBIR camera
Aspect Ratio
16:9
Native Resolution
2560 x 1440 at 60 Hz
Pixel Pitch
0.2331 mm
Brightness
350 cd/m²
Contrast Ratio
1000:1
Response Time
6 ms, 4 ms (overdrive), 14 ms (default)
Colour Gamut
99% sRGB
Input Connectors
HDMI, DisplayPort
Display Position Adjustments
Screen Coating
Anti-glare (25%)
Voltage
61.4 cm x 32.9 cm x 44.425 cm
7.95 kg
English / United Kingdom
Environmental Standards
TCO Certified Displays 8, TCO Certified Edge Displays, ENERGY STAR Qualified EPEAT Silver
FCC Class B certified, VESA DPMS, VESA FPMPMI, RoHS, ISO 9241-307, WEEE, UL Environmental SPC Gold, VOC, TUV Rheinland Eye Comfort Certification, VESA DDCCi
3-year warranty
Display Type
Diagonal Size
27"
Built-in Devices
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2331 mm
Pixel Per Inch
109
Brightness
350 cd/m²
Contrast Ratio
1000:1
Colour Gamut
99% sRGB
Response Time
Horizontal Viewing Angle
+89 / -89
Vertical Viewing Angle
+89 / -89
Screen Coating
Anti-glare (25%)
Backlight Technology
WLED
3-side NearEdgeless, 99% sRGB colour gamut
61.4 cm x 32.9 cm x 44.425 cm - with stand
7.95 kg
Audio
Speakers - stereo
Output Power / Channel
2 Watt
DisplayPort/USB 3.0/power (undetachable 3-in-1 cable) , Headphone/microphone combo jack , USB 3.1 Gen 1 upstream (Type B) , 2 x USB 3.1 Gen 1 downstream , DisplayPort , HDMI
Mechanical
Tilt Angle
-5/+35
Swivel Angle
90
Rotation Angle
-5/+90
Height Adjustment
110 mm
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), 88% efficiency power supply, Tiny PC dock
Mounting Kit
Optional
Security Slot Type
Kensington security slot
Input Voltage
Power Consumption (Typical)
37 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption Sleep
0.5 Watt
Dimensions & Weight Details
With stand (lowest position) - width: 61.4 cm - depth: 32.9 cm - height: 44.425 cm - weight: 7.95 kg , With stand (highest position) - width: 61.4 cm - depth: 32.9 cm - height: 55.425 cm - weight: 7.95 kg , Without stand - width: 61.4 cm - depth: 7.389 cm - height: 41.31 cm - weight: 4.91 kg
Sustainability Information
TCO Certified
EPEAT Compliant
EPEAT Silver
ENERGY STAR Certified
ENERGY STAR Version
7.0
Limited warranty - 3 years
Diagonal Size: 27in
Response Time: 4ms
Interfaces: HDMI
Brand: Lenovo
