Lenovo ThinkCentre M920z AIO 23.8" Intel Core i5-9500 8GB 256GB SSD Windows 10 Professional 64-bit
Quicklinx: FPSQWS00 Mfr#: 10S6003JUK
  • Core i5
  • IEEE 802.11n
Make IT's jobs easier
The ThinkCentre M920z makes life easy for your IT team, keeping your enterprise data safe via embedded Trusted Platform Management (TPM) 2.0 data encryption, BIOS-based Smart USB protection, Windows Hello support, and an intrusion switch that sends alerts if someone attempts to open the chassis. It’s also quick and easy to deploy.
Gets your numbers up
Users can expect high responsiveness and seamless multitasking of even the most intensive tasks, thanks to the latest generation of Intel Core processor and PCIe SSD on selected models, not to mention the fast data transfers of its USB 3.1 Gen 2 and USB-C ports. Watch your employees’ productivity soar.
Keeps your data secure
Rest assured your data will stay safe, thanks to Trusted Platform Module (TPM) 2.0 data and password encryption. And its BIOS-based Smart USB Protection lets you configure the USB ports to respond only to specific devices, preventing unauthorized copying of files.
Save space…
The compact footprint of the M920z AIO means it will leave your workspace clutter-free and open for business. It’s also VESA-mountable and borderless, and can use an optional stand to save even more space.
…and save time
With the Keyboard Power On feature, you can switch on the M920z directly from its keyboard. Its Smart Webcam rotates 180 degrees horizontally and 50 degrees vertically, so a user can switch from front to rear camera mode and keep video conferences moving along.
Tested to extremes
The M920z is tested for durability against eight MIL-SPEC standards: low pressure (altitude); vibration; high temperature; low temperature; sand/dust; temperature shock; humidity; and shock. Yes, this AIO is reliable.
Easy on the eyes
The M920z display’s antiglare panel scatters light and stays flicker-free, reducing eye strain. Plus, its Eye Comfort and Low Blue Light certifications ensure your eyes will stay comfortable when working those long hours.
  • Stunning visuals
    Experience crystal-clear images on the 23.8-inch Full HD display, featuring a 1920 x 1080 native resolution, 250 cd/m2 brightness, and a 1000:1 contrast ratio. The anti-glare technology and Low Blue Light Mode ensure comfortable viewing for extended periods, while the Wide Viewing Angle keeps colors consistent from any perspective.
  • Powerful performance
    Powered by an Intel Core i5 processor with six cores, complemented by Intel UHD Graphics 630, this Lenovo ThinkCentre M920z AIO delivers smooth and efficient performance for a variety of tasks. The dual-channel memory architecture with DDR4 SDRAM at 2666 MHz enhances multitasking capabilities.
  • Enhanced audio experience
    Dolby Audio Premium and high definition audio standards, along with stereo speakers positioned on the right and left channels, offer an immersive sound experience. Whether it's for work or leisure, enjoy clear and rich audio.
  • Robust connectivity
    Equipped with five USB 3.1 Gen 1 ports, including one that supports SmartPower On, this all-in-one provides ample connectivity options for all your peripherals. The inclusion of M.2 card slots further expands its versatility.
  • Built for the environment
    This Lenovo ThinkCentre M920z AIO is not only ENERGY STAR certified but also meets the standards of Energy-Related Products (ErP) Lot 3, GREENGUARD, RoHS, TUV Rheinland Eye Comfort Certification, and TUV Rheinland Low Blue Light Certification, making it an environmentally friendly choice.
Lenovo ThinkCentre M920z AIO - all-in-one Core i5 9500 3 GHz - vPro - 8 GB - SSD 256 GB - LED 23.8" - UK
Personal computer - all-in-one
Platform Technology
Intel vPro Platform
Intel Core i5 (9th Gen) 9500 / 3 GHz (up to 4.4 GHz, (6-core)
Cache Memory
9 MB
Cache Per Processor
9 MB
RAM
8 GB (installed) / 32 GB (max) - DDR4 SDRAM
Storage Controller
SATA
Hard Drive
SSD 256 GB - PCI Express - M.2 2280 - TCG Opal Encryption, NVM Express (NVMe)
Optical Storage
DVD-Writer
Card Reader
3 in 1
Monitor
23.8" - LED - 1920 x 1080 (Full HD) - 16:9
Graphics Controller
Camera
1GbE, 802.11a, 802.11b/g/n, Wi-Fi 5, Bluetooth 5.0
Keyboard
OS Provided
Windows 10 Pro 64-bit Edition
Software Included
Cyberlink PowerDVD, CyberLink Power2Go, Lenovo Vantage, Linkedin
Business black
54.2 cm x 25.2 cm x 36.3 cm
8.94 kg
Manufacturer Selling Program
Lenovo TopSeller
Environmental Standards
ENERGY STAR Qualified
Limited warranty - 3 years - on-site
Platform Technology
Intel vPro Platform
Personal computer
Product Form Factor
All-in-one - with UltraFlex III Stand
Built-in Devices
Stereo speakers
Embedded Security
Trusted Platform Module (TPM 2.0) Security Chip
Business black
Processor / Chipset
CPU
Clock Speed
3 GHz
Max Turbo Speed
4.4 GHz
Number of Cores
6-core
CPU Qty
1
Max CPU Qty
1
Chipset Type
Intel Q370
Cache Memory
Installed Size
9 MB
Cache Per Processor
9 MB
RAM
Installed Size
DDR4 SDRAM
Effective Memory Speed
2666 MHz
Rated Memory Speed
1333 MHz
SO-DIMM 260-pin
Slots
2 (Total) / 1 (empty)
Dual channel memory architecture
Configuration Features
1 x 8 GB
Hard Drive
SSD - M.2 2280
1 x 256 GB
Interface Type
PCI Express
Storage Controller
1 x SATA
Optical Storage
DVD-Writer - SATA
Card Reader
3 in 1 card reader
Monitor
Monitor Type
LED
Diagonal Size
23.8"
Native Resolution
Widescreen Display
Image Aspect Ratio
16:9
Image Brightness
250 cd/m²
Image Contrast Ratio
1000:1
Monitor Features
Anti-glare, Low Blue Light Mode, Wide Viewing Angle, borderless
Graphics Controller
Graphics Processor
Video Interfaces
DisplayPort
Audio Output
High Definition Audio, Dolby Audio Premium
Speakers Included
2 x right / left channel
Camera
Camera
Resolution
1080p
180° rotating function, built-in 2 microphones, LED indicator
Input Device
Mouse, keyboard
Keyboard
USB
Localization & Layout
Mouse
USB
Interface (Bus) Type
M.2 Card
Ethernet Controller
Intel I219-LM
Wireless LAN Supported
Wireless NIC
Intel Wireless-AC 9560
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, Bluetooth 5.0
Wake on LAN (WoL)
Slots
2 (total) / 0 (free) x M.2 Card
5 x USB 3.1 Gen 1 (1 front, 4 rear) (one of them supports SmartPower On) , 1 x LAN (Gigabit Ethernet) , 1 x DisplayPort input/output combo , 1 x USB 3.1 Gen 2 (1 in front) (one of them is Always On and fast-charging) , 1 x USB-C 3.1 Gen 1 (1 in front) , 1 x headphones/microphone (1 in front)
Theft/Intrusion Protection
Security lock slot (cable lock sold separately), chassis intrusion switch
Security Slot Type
Kensington security slot
VESA Mounting Interface
100 x 100 mm
RoHS, GREENGUARD, TUV Rheinland Low Blue Light Certification, Energy-Related Products (ErP) Lot 3, TUV Rheinland Eye Comfort Certification, TUV Rheinland Ultra Low Noise Certification
Lenovo TopSeller
Power supply
Power Provided
150 Watt
Efficiency
90%
Operating System / Software
OS Provided
Windows 10 Pro 64-bit Edition English
Software
Sustainability Information
ENERGY STAR Certified
ENERGY STAR Version
7.0
54.2 cm
25.2 cm
36.3 cm
8.94 kg
FPSQ Lenovo Essential Wireless Keyboard and Mouse Combo - UK English 166 In Stock £27.09
FPSQ Lenovo Professional Wireless Keyboard In Stock £52.93
FPSQ Lenovo ThinkPad USB3.0 to Ethernet Adapter In Stock £16.01
FPSQ Kensington Security Cable Lock In Stock £23.55
FPSQ Lenovo ThinkPad Bluetooth Silent Mouse - Right and Left-handed In Stock £23.79
