Lenovo ThinkCentre M910Z AIO i7-7700 8GB 256GB SSD Win 10 Pro
Quicklinx: D11SWS00 Mfr#: 10NR0014UK
  • IEEE 802.11n
  • Core i7
Lenovo ThinkCentre M910z AIO is built for enterprise. M910z AIO enables you carry out intensive task with ease. Plus built-in data security - these easy-to-use machines keep your workforce on task, and improve productivity.
  • Easy remote management
    With Intel vPro you can remotely access your fleet of desktops - saving time and hassle on desk-side visits, and cutting down management costs.
  • Reliable and secure
    Smart USB Protection prevents data from being transferred from USB ports while still allowing you to connect peripheral devices - so your data stays confidential. Plus, you can lock the inbuilt privacy camera with the flick of a switch for your peace of mind and privacy.
  • Twice as easy to service
    Taking off the back cover, stand, and want to remove HDD, memory, all you need is your hand without tools. Toolless design makes repairing and replacing easier than ever
Lenovo ThinkCentre M910z - all-in-one Core i7 7700 3.6 GHz - vPro - 8 GB - SSD 256 GB - LED 23.8" - UK
Personal computer - all-in-one
Platform Technology
Intel vPro Platform
Intel Core i7 (7th Gen) 7700 / 3.6 GHz (up to 4.2 GHz, (Quad-Core)
Processor Socket
LGA1151 Socket
Processor Main Features
Hyper-Threading Technology, Intel Turbo Boost Technology 2, Intel Smart Cache
Cache Memory
8 MB
Cache Per Processor
8 MB
RAM
8 GB (installed) / 32 GB (max) - DDR4 SDRAM - non-ECC
Storage Controller
SATA (SATA 6Gb/s)
Hard Drive
SSD 256 GB - PCI Express 3.0 x4 - M.2 - TCG Opal Encryption, NVM Express (NVMe)
Optical Storage
DVD-Writer
Card Reader
9 in 1
Monitor
23.8" - LED - 1920 x 1080 (Full HD) - 16:9 - touchscreen
Graphics Controller
Intel HD Graphics 630
Camera
1GbE, 802.11a, 802.11b/g/n, Wi-Fi 5, Bluetooth 4.1
Keyboard
OS Provided
Windows 10 Pro 64-bit Edition
Business black
58.4 cm x 25.3 cm x 50.5 cm
10.3 kg
Manufacturer Selling Program
TopSeller
Environmental Standards
ENERGY STAR Qualified
Limited warranty - 3 years - on-site
Platform Technology
Intel vPro Platform
Personal computer
Product Form Factor
All-in-one - with UltraFlex II Stand
Built-in Devices
Stereo speakers
Embedded Security
Trusted Platform Module (TPM 2.0) Security Chip
Business black
Processor / Chipset
CPU
Clock Speed
3.6 GHz
Max Turbo Speed
4.2 GHz
Number of Cores
Quad-Core
CPU Qty
1
Max CPU Qty
1
CPU Socket
LGA1151 Socket
Chipset Type
Intel Q270
Cache Memory
Installed Size
8 MB
Cache Per Processor
8 MB
RAM
Installed Size
Effective Memory Speed
2400 MHz
Rated Memory Speed
1200 MHz
SO-DIMM 260-pin
Slots
2 (Total) / 1 (empty)
Unbuffered, dual channel memory architecture
Configuration Features
1 x 8 GB
Hard Drive
SSD - M.2
1 x 256 GB
Interface Type
PCI Express 3.0 x4
Storage Controller
1 x SATA
Controller Interface Type
SATA 6Gb/s
Optical Storage
DVD-Writer - SATA
Card Reader
9 in 1 card reader
Monitor
Monitor Type
LED
Touchscreen
Yes (10-point multi-touch)
Diagonal Size
23.8"
Native Resolution
Widescreen Display
Image Aspect Ratio
16:9
Image Brightness
250 cd/m²
Image Contrast Ratio
1000:1
Monitor Features
Anti-glare, Projected Capacitive Touch (PCT) technology, Low Blue Light Mode, Wide Viewing Angle
Graphics Controller
Graphics Processor
Video Interfaces
DisplayPort
Audio Output
High Definition Audio, Dolby Audio
Speakers Included
2 x right / left channel
Camera
Camera
Resolution (MP)
2 Megapixel
Resolution
1080p
Built-in 2 microphones, LED indicator
Input Device
Mouse, keyboard
Keyboard
USB
Localization & Layout
Mouse
USB
Ethernet Controller
Intel I219-LM
Wireless LAN Supported
Wireless NIC
Intel Dual Band Wireless-AC 8265
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, Bluetooth 4.1
Wake on LAN (WoL)
Slots
2 (total) / 0 (free) x M.2 Card
6 x USB 3.1 Gen 1 (2 front, 4 rear) (one of them is Always On and fast-charging) , 1 x headphones/microphone (1 in front) , 1 x LAN (Gigabit Ethernet) , 1 x DisplayPort input/output combo
Theft/Intrusion Protection
Security lock slot (cable lock sold separately), chassis intrusion switch
Security Slot Type
Kensington security slot
VESA Mounting Interface
100 x 100 mm
RoHS, GREENGUARD, UL Environmental SPC Gold, Energy-Related Products (ErP) Lot 3
TopSeller
Power supply
Power Provided
150 Watt
Efficiency
85%
Operating System / Software
OS Provided
Sustainability Information
ENERGY STAR Certified
ENERGY STAR Version
6.1
58.4 cm
25.3 cm
50.5 cm
10.3 kg
