Lenovo ThinkCentre M910Z AIO i5-7400 4GB 500GB 23.8" Win 10 Pro
Quicklinx: D11TWS00 Mfr#: 10NS000BUK
Operating System: Windows 10 Pro 64-bit Edition
Processor Type: Core i5
Processor Model: I5-7400
Installed Memory: 4GB
Hard Drive Capacity: 500GB
  • Core i5
£815.90 ex VAT
£979.08 inc VAT
Lenovo ThinkCentre M910z AIO is built for enterprise. M910z AIO enables you carry out intensive task with ease. Plus built-in data security - these easy-to-use machines keep your workforce on task, and improve productivity.
  • Easy remote management
    With Intel vPro you can remotely access your fleet of desktops - saving time and hassle on desk-side visits, and cutting down management costs.
  • Reliable and secure
    Smart USB Protection prevents data from being transferred from USB ports while still allowing you to connect peripheral devices - so your data stays confidential. Plus, you can lock the inbuilt privacy camera with the flick of a switch for your peace of mind and privacy.
  • Twice as easy to service
    Taking off the back cover, stand, and want to remove HDD, memory, all you need is your hand without tools. Toolless design makes repairing and replacing easier than ever.
Lenovo ThinkCentre M910z - all-in-one - Core i5 7400 3 GHz - 4 GB - 500 GB - LED 23.8"
Personal computer - all-in-one
1 x Intel Core i5 (7th Gen) 7400 / 3 GHz (3.5 GHz) (Quad-Core)
Processor Main Features
Intel Turbo Boost Technology 2
Cache Memory
6 MB
Cache Per Processor
6 MB
RAM
4 GB (installed) / 32 GB (max) - DDR4 SDRAM
Storage Controller
SATA
Hard Drive
1 x 500 GB - SATA 6Gb/s - 7200 rpm
Optical Storage
DVD-Writer
Card Reader
9 in 1
Monitor
23.8" - LED - 1920 x 1080 (Full HD) - 16:9
Graphics Controller
Intel HD Graphics 630
Camera
GigE, 802.11ac, Bluetooth 4.1
OS Provided
Business black
58.4 cm x 24.5 cm x 45.8 cm
8.8 kg
Manufacturer Selling Program
TopSeller
Environmental Standards
ENERGY STAR Qualified
Limited warranty - 3 years - on-site
Personal computer
Product Form Factor
All-in-one - with Basic Stand
Built-in Devices
Stereo speakers
Embedded Security
Trusted Platform Module (TPM 2.0) Security Chip
Business black
Processor / Chipset
CPU
Max Turbo Speed
3.5 GHz
Number of Cores
Quad-Core
CPU Qty
1
Max CPU Qty
1
Chipset Type
Intel Q270
Cache Memory
Installed Size
6 MB
Cache Per Processor
6 MB
RAM
Installed Size
4 GB / 32 GB (max)
DDR4 SDRAM
Effective Memory Speed
2400 MHz
Rated Memory Speed
2400 MHz
SO-DIMM 260-pin
Slots
2 (Total) / 1 (empty)
Configuration Features
1 x 4 GB
Hard Drive
HDD
1 x 500 GB
Interface Type
SATA 6Gb/s
Spindle Speed
7200 rpm
Storage Controller
1 x SATA
Optical Storage
DVD-Writer - SATA
Card Reader
9 in 1 card reader
Monitor
Monitor Type
LED
Diagonal Size
23.8"
Native Resolution
Widescreen Display
Image Aspect Ratio
16:9
Image Brightness
250 cd/m²
Image Contrast Ratio
1000:1
Monitor Features
Anti-glare, Low Blue Light Mode, Wide Viewing Angle
Graphics Controller
Graphics Processor
Video Interfaces
DisplayPort
Audio Output
High Definition Audio, Dolby Audio
Speakers Included
2 x right / left channel
Camera
Camera
Resolution (MP)
2 Megapixel
Resolution
1080p
Built-in 2 microphones, LED indicator
Input Device
Mouse, keyboard
Keyboard
USB
Mouse
USB
Ethernet Controller
Intel I219-LM
Wireless LAN Supported
Wireless NIC
Intel Dual Band Wireless-AC 8265
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11ac, Bluetooth 4.1
Wake on LAN (WoL)
Slots
2 (total) / 1 (free) x SO-DIMM 260-pin , 2 (total) / 1 (free) x M.2 Card
6 x USB 3.1 Gen 1 (2 front, 4 rear) (one of them is Always On and fast-charging) , 1 x headphones/microphone (1 in front) , 1 x LAN (Gigabit Ethernet) , 1 x DisplayPort input/output combo
Theft/Intrusion Protection
Security lock slot (cable lock sold separately), chassis intrusion switch
Security Slot Type
Kensington security slot
VESA Mounting Interface
100 x 100 mm
RoHS, GREENGUARD, UL Environmental SPC Gold, Energy-Related Products (ErP) Lot 3
TopSeller
Power supply
Nominal Voltage
Power Provided
150 Watt
Efficiency
85%
Operating System / Software
OS Provided
ENERGY STAR Certified
ENERGY STAR Version
6.1
58.4 cm
24.5 cm
45.8 cm
8.8 kg
Lenovo ThinkCentre M910Z AIO i5-7400 4GB 500GB 23.8 Bundle deal on Lenovo ThinkCentre M910Z AIO i5-7400 4GB 500GB 23.8" Win 10 Pro
£1,002.36
saving £8.33
£915.66
D11T Lenovo Microsaver Security Cable Lock In Stock £23.87
D11T Lenovo Optical 3-button W/Mouse USB In Stock £13.60
Storage Type: HDD
Optical Storage: DVD-Writer
Display Size: 23.8"
Brand: Lenovo
Price Range Ex VAT: 750 - 1000
