The ThinkCentre M900z is built for business collaboration with its full-HD 23.8-inch LED display. With a 178-degree wide viewing angle, anti-glare and an optional 10-point multi-touch screen, the Windows 8-certified M93z allows business professionals to easily work together on presentations, demos and other collaborative projects. The M93z also offers optional AMD Radeon HD discrete graphics for advanced 3D graphics and stunning visuals. Equipped with up to 4th-generation Intel Core i7 processor and SSHD, the ThinkCentre M93z packs fast, powerful performance into a compact, space-saving design, and its enhanced toolless design allows quick and simple system service and upgrades. Users can engage in crystal-clear conference calls with Microsoft 1080p Lync-qualified VoIP solutions, powered by Dolby Advanced sound enhancement to deliver a rich audio experience. Intel vPro Technology enables increased manageability and security with speedy data encryption and decryption, protection from unauthorised access and remote management. Not only powerful and manageable, the M93z is among the industry's most environmentally friendly AIOs – its plastic components use more than 40 per cent recycled consumer materials and it meets certifications for energy efficiency and environmental considerations, including EPEAT Gold, UL Environment Gold, Energy Star, TCO Edge, GREENGUARD, Cisco EnergyWise and TUV Green Mark. Optional auto-brightness control for increased energy efficiency and reduced costs.
To Sales/Channel: premium design with the latest technologies and vPro available. It comes with 15 month platform stability and pre-loaded ThinkVantage Technology tools that make PC management simpler while cutting down operating and management costs. Solutions such as Password Manager, TPM support, Chassis Intrusion Switch and cable lock make it very secure. The space-saving, improved toolless stand design and perfect cable management frees up your desk and gives you peace of mind. The green features of M93z not only help your company save power, but also help the planet. Its best-in-class user experience at an affordable price make it a perfect choice for your business.
Rugged and reliable
Tested to MIL-SPEC, this powerful All-in-One desktop is ready to handle even mission critical tasks or activities. -
Versatile connectivity
Enhanced Wi-Fi and easy switching between connected displays - laptop or extended monitor - via a single access point. -
Primed for performance
The Intel Skylake processor with vPro and DDR4 technology delivers enterprise-level performance.
- Lenovo ThinkCentre M900z - all-in-one - Core i5 6500 3.2 GHz - vPro - 4 GB - Hybrid Drive 500 GB - LED 23.8" - UK
- Personal computer - all-in-one
- Platform Technology
- Intel vPro Platform
- Localisation
- Processor
- Intel Core i5 (6th Gen) 6500 / 3.2 GHz (, up to 3.6 GHz, (Quad-Core)
- Processor Main Features
- Intel Turbo Boost Technology 2
- Cache Memory
- 6 MB
- Cache Per Processor
- 6 MB
- RAM
- 4 GB (installed) / 32 GB (max) - DDR4 SDRAM
- Storage Controller
- SATA
- Hard Drive
- Hybrid Drive 500 GB (8 GB cache) - SATA 6Gb/s - 5400 rpm
- Optical Storage
- DVD-Writer
- Card Reader
- 9 in 1
- Monitor
- 23.8" - LED - 1920 x 1080 (Full HD) - 16:9
- Graphics Controller
- Intel HD Graphics 530
- Camera
- Audio Output
- Stereo
- Networking
- GigE, 802.11a, 802.11b/g/n, Wi-Fi 5, Bluetooth 4.1
- Keyboard
- UK
- Power
- AC 120/230 V (50/60 Hz)
- OS Provided
- Microsoft Windows 7 Professional 64-bit Edition (downgrade from Windows 10 Pro 64-bit) + Windows 10 Pro 64-bit Licence
- Software Included
- ThinkVantage Rescue and Recovery, Adobe Reader, ThinkVantage System Update, Lenovo Message Center Plus, Lenovo Solution Center, Password Manager, McAfee LiveSafe (30 days trial), Lenovo Desktop Power Manager, SHAREit, REACHit, Lenovo Bluetooth Lock, PowerDVD Create
- Business black
- 58.4 cm x 25.3 cm x 50.5 cm
- 9.4 kg
- Manufacturer Selling Program
- TopSeller
- Environmental Standards
- ENERGY STAR Qualified
- Limited warranty - 3 years - on-site
- Personal computer
- Product Form Factor
- All-in-one - with UltraFlex II Stand
- Built-in Devices
- Stereo speakers
- Embedded Security
- Trusted Platform Module (TPM 1.2) Security Chip
- Business black
- Localisation
Processor / Chipset
- CPU
- Clock Speed
- 3.2 GHz
- Max Turbo Speed
- 3.6 GHz
- Number of Cores
- Quad-Core
- CPU Qty
- 1
- Max CPU Qty
- 1
- Chipset Type
- Intel Q170
Cache Memory
- Installed Size
- 6 MB
- 6 MB
RAM
- Installed Size
- 4 GB / 32 GB (max)
- Technology
- DDR4 SDRAM
- Effective Memory Speed
- 2133 MHz
- Form Factor
- SO-DIMM 260-pin
- Slots
- 2 (Total) / 1 (empty)
- Configuration Features
- 1 x 4 GB
Hard Drive
- Hybrid Drive
- Capacity
- 1 x 500 GB (8 GB cache)
- Interface Type
- SATA 6Gb/s
- Spindle Speed
- 5400 rpm
Storage Controller
- 1 x SATA
Optical Storage
- DVD-Writer - SATA
Card Reader
- 9 in 1 card reader
Monitor
- Monitor Type
- LED - MVA
- Diagonal Size
- 23.8"
- Native Resolution
- Widescreen Display
- Image Aspect Ratio
- 16:9
- Image Brightness
- 250 cd/m²
- Image Contrast Ratio
- 1000:1
- Monitor Features
- Anti-glare
Graphics Controller
- Graphics Processor
- Video Interfaces
- DisplayPort
Audio Output
- Sound Output Mode
- Stereo
- High Definition Audio
- Speakers Included
- 2 x right / left channel
Camera
- Camera
- Resolution (MP)
- 2 Megapixel
- Resolution
- 1080p
- Built-in 2 microphones
Input Device
- Mouse, keyboard
Keyboard
- Interface
- USB
- Localization & Layout
- UK
Mouse
- Technology
- Optical
- Interface
- USB
- Ethernet Controller
- Intel I219-LM
- Wireless LAN Supported
- Wireless NIC
- Intel Dual Band Wireless-AC 8260
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, Bluetooth 4.1
- Wake on LAN (WoL)
- Slots
- 2 (total) / 1 (free) x SO-DIMM 260-pin , 1 (total) / 0 (free) x M.2 Card
- 6 x USB 3.0 (2 front, 4 rear) , 1 x headphones/microphone (1 in front) , 1 x DisplayPort input/output combo , 1 x LAN (Gigabit Ethernet)
- Theft/Intrusion Protection
- Security lock slot (cable lock sold separately), chassis intrusion switch
- VESA Mounting Interface
- 100 x 100 mm
- RoHS, GREENGUARD, TUV GM, UL Environmental SPC Gold, Energy-Related Products (ErP) Lot 3
- TopSeller
- Power supply
- Voltage Required
- Power Provided
- 150 Watt
- Efficiency
- 85%
Operating System / Software
- OS Provided
- Microsoft Windows 7 Professional 64-bit Edition (available through downgrade rights from Windows 10 Pro 64-bit) + Windows 10 Pro 64-bit Licence
- Software
Sustainability Information
- ENERGY STAR Certified
- ENERGY STAR Version
- 6.1
- 58.4 cm
- 25.3 cm
- 50.5 cm
- 9.4 kg
C2G 3m DisplayPort Cable with Latches M/M - Black | In Stock | £13.17 |
