For large businesses (EDU/GOV/PUB etc.) with a need for a high-performance desktop PC, the ThinkCentre M900 provides the latest Intel technology without sacrificing security, stability, manageability and environmental friendliness.
Tiny form factor
ThinkCent?r M900 Tiny is an ultra-small form factor. It offers mounting solutions, including support for standard VESA mounts and Tiny-in-One configurations - which transform your PC into a space-saving modular all-in-one. Tiny desktops fit just about anywhere, while still delivering reliable performance. -
Intel vPro-ready
The M900 Tiny includes vPro technology to make enterprise-level manageability even more convenient and cost-efficient. The built-in management capabilities of vPro allow IT administrators to access your PC remotely, even when the system if powered off, to diagnose and repair systems and automate security patches and updates - ensuring your system is always up and running. -
Stable Image Platform Program
Stable Image Platform Program (SIPP) facilitates the often tricky process of transitioning from one technology generation to the next. -
Multiple monitor support
Maximize productivity with independent display support for up to three monitors. The expanded work area and easier navigation between applications help reduce errors and improve productivity as you extend your desktop across multiple monitors. -
Keyboard power-on support
If you choose to mount this compact unit on the back of your monitor, you can still power on conveniently from the front, by simply pressing Alt+P on a USB-connected keyboard. -
Fast data transfer
Move data between the M900 Tiny and other devices quickly with USB 3.0 - it's extremely fast. -
Variety of I/O support
No matter your port needs, this desktop has you covered, with support for USB 3.0, DisplayPort, VGA, HDMI, LAN, and serial connections.
- Lenovo ThinkCentre M900 - MT - Core i5 6500 3.2 GHz - vPro - 4 GB - HDD 500 GB - UK
- Personal computer - mini tower
- Platform Technology
- Intel vPro Platform
- Localisation
- Processor
- Intel Core i5 (6th Gen) 6500 / 3.2 GHz (, up to 3.6 GHz, (Quad-Core)
- Processor Socket
- LGA1151 Socket
- Processor Main Features
- Intel Turbo Boost Technology 2
- Cache Memory
- 6 MB
- Cache Per Processor
- 6 MB
- RAM
- 4 GB (installed) / 64 GB (max) - DDR4 SDRAM - non-ECC - PC4-17000
- Storage Controller
- SATA (SATA 6Gb/s)
- Hard Drive
- HDD 500 GB - SATA 6Gb/s - 7200 rpm
- Optical Storage
- DVD-Writer
- Graphics Controller
- Intel HD Graphics 530
- Networking
- GigE, 802.11a, 802.11b/g/n, Wi-Fi 5
- Keyboard
- UK
- Power
- AC 120/230 V (50/60 Hz)
- OS Provided
- Microsoft Windows 7 Professional 64-bit Edition (downgrade from Windows 10 Pro 64-bit) + Windows 10 Pro 64-bit Licence
- 17.5 cm x 41.3 cm x 40.62 cm
- 12.5 kg
- Limited warranty - 3 years - on-site
- Personal computer
- Product Form Factor
- Mini tower
- Built-in Devices
- Speaker
- Localisation
Processor / Chipset
- CPU
- Clock Speed
- 3.2 GHz
- Max Turbo Speed
- 3.6 GHz
- Number of Cores
- Quad-Core
- CPU Qty
- 1
- Max CPU Qty
- 1
- CPU Socket
- LGA1151 Socket
- Chipset Type
- Intel Q170
Cache Memory
- Installed Size
- 6 MB
- 6 MB
RAM
- Installed Size
- 4 GB / 64 GB (max)
- Technology
- Effective Memory Speed
- 2133 MHz
- Rated Memory Speed
- 2133 MHz
- Memory Specification Compliance
- PC4-17000
- Form Factor
- DIMM 288-pin
- Slots
- 4 (Total) / 3 (empty)
- Unbuffered
- Configuration Features
- 1 x 4 GB
Hard Drive
- HDD
- Capacity
- 1 x 500 GB
- Interface Type
- SATA 6Gb/s
- Spindle Speed
- 7200 rpm
Storage Controller
- 1 x SATA
- Controller Interface Type
- SATA 6Gb/s
Optical Storage
- DVD-Writer - SATA
Monitor
- Monitor Type
- None.
Graphics Controller
- Graphics Processor
- Video Interfaces
- VGA, DisplayPort
Input Device
- Mouse, keyboard
Keyboard
- Interface
- USB
- Localization & Layout
- UK
Mouse
- Technology
- Optical
- Interface
- USB
- Wireless LAN Supported
- Wireless NIC
- Intel Dual Band Wireless-AC 8260
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
- Bays
- 2 (total) / 1 (free) x external 5.25" x 1/2H , 1 (total) / 0 (free) x internal 3.5" x 1/3H
- Slots
- 4 (total) / 3 (free) x DIMM 288-pin , 1 (total) / 0 (free) x CPU
- 8 x USB 3.0 (2 front, 6 rear) , 1 x VGA , 2 x DisplayPort , 1 x LAN (Gigabit Ethernet) , 1 x serial
- Power supply
- Voltage Required
- Power Provided
- 250 Watt
- Efficiency
- 85%
Operating System / Software
- OS Provided
- Microsoft Windows 7 Professional 64-bit Edition (available through downgrade rights from Windows 10 Pro 64-bit) + Windows 10 Pro 64-bit Licence
- 17.5 cm
- 41.3 cm
- 40.62 cm
- 12.5 kg
C2G 3m DisplayPort Cable with Latches M/M - Black | In Stock | £13.17 |
