Built to perform, the M820z is a mainstream AIO that transcends the realm of productivity. You can experience supreme performance while working on intensive tasks. The versatile connectivity options, compact design, robust security, and easy manageability make this AIO an ideal choice in all business environments.
Unmatched productivity
Experience highly responsive computing and seamlessly switch between multiple tasks. The USB 3.1 ports located on the side enable easy access and faster data transfers. -
Stress-free visuals
With the eye comfort certification and low blue light technology, extended working hours are a breeze. Experience less eye-fatigue with an anti-glare, flicker-free display.
- Lenovo ThinkCentre M820z AIO - all-in-one - Core i7 9700 3 GHz - 8 GB - SSD 256 GB - LED 21.5" - UK
- Personal computer - all-in-one
- Localisation
- Processor
- Intel Core i7 (9th Gen) 9700 / 3 GHz (4.7 GHz) (8-core)
- Cache Memory
- 12 MB
- Cache Per Processor
- 12 MB
- RAM
- 8 GB (installed) / 32 GB (max) - DDR4 SDRAM
- Storage Controller
- SATA
- Hard Drive
- SSD 256 GB - PCI Express - M.2 2280 - NVM Express (NVMe)
- Optical Storage
- DVD-Writer
- Card Reader
- 3 in 1
- Monitor
- 21.5" - LED - 1920 x 1080 (Full HD) - 16:9
- Graphics Controller
- Intel UHD Graphics 630
- Camera
- Audio Output
- Stereo
- Networking
- GigE, 802.11a, 802.11b/g/n, Wi-Fi 5, Bluetooth 4.2
- Keyboard
- UK
- Power
- AC 120/230 V (50/60 Hz)
- OS Provided
- Windows 10 Pro 64-bit Edition
- Software Included
- Cyberlink PowerDVD, CyberLink Power2Go, Lenovo Vantage, Linkedin
- Business black
- 49.1 cm x 25.2 cm x 37.7 cm
- 7.65 kg
- Manufacturer Selling Program
- TopSeller
- Environmental Standards
- ENERGY STAR Qualified
- Limited warranty - 3 years - on-site
- Personal computer
- Product Form Factor
- All-in-one - with UltraFlex III Stand
- Built-in Devices
- Stereo speakers
- Embedded Security
- Trusted Platform Module (TPM 2.0) Security Chip
- Business black
- Localisation
Processor / Chipset
- CPU
- Clock Speed
- 3 GHz
- Max Turbo Speed
- 4.7 GHz
- Number of Cores
- 8-core
- CPU Qty
- 1
- Max CPU Qty
- 1
- Chipset Type
- Intel B360
Cache Memory
- Installed Size
- 12 MB
- 12 MB
RAM
- Installed Size
- 8 GB / 32 GB (max)
- Technology
- DDR4 SDRAM
- Effective Memory Speed
- 2666 MHz
- Rated Memory Speed
- 2666 MHz
- Form Factor
- SO-DIMM 260-pin
- Slots
- 2 (Total) / 1 (empty)
- Dual channel memory architecture
- Configuration Features
- 1 x 8 GB
Hard Drive
- SSD - M.2 2280
- Capacity
- 1 x 256 GB
- Interface Type
- PCI Express
Storage Controller
- 1 x SATA
Optical Storage
- DVD-Writer - SATA
Card Reader
- 3 in 1 card reader
Monitor
- Monitor Type
- LED - IPS
- Diagonal Size
- 21.5"
- Native Resolution
- Widescreen Display
- Image Aspect Ratio
- 16:9
- Image Brightness
- 250 cd/m²
- Image Contrast Ratio
- 1000:1
- Monitor Features
- Anti-glare, Low Blue Light Mode, Wide Viewing Angle, borderless
Graphics Controller
- Graphics Processor
- Video Interfaces
- DisplayPort
Audio Output
- Sound Output Mode
- Stereo
- High Definition Audio, Dolby Audio Premium
- Speakers Included
- 2 x right / left channel
Camera
- Camera
- Resolution
- 1080p
- 180° rotating function, built-in 2 microphones, LED indicator
Input Device
- Mouse, keyboard
Keyboard
- Interface
- USB
- Localization & Layout
- UK
Mouse
- Interface
- USB
- Ethernet Controller
- Realtek RTL8111G
- Wireless LAN Supported
- Wireless NIC
- Intel Dual Band Wireless-AC 8265
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, Bluetooth 4.2
- Wake on LAN (WoL)
- Slots
- 2 (total) / 0 (free) x M.2 Card
- 4 x USB 3.1 Gen 1 (one of them supports SmartPower On) , 1 x LAN (Gigabit Ethernet) , 1 x DisplayPort , 1 x headphones/microphone , 1 x USB 3.1 Gen 2 (Always On) , 1 x USB-C 3.1 Gen 1
- Theft/Intrusion Protection
- Security lock slot (cable lock sold separately), chassis intrusion switch
- Security Slot Type
- Kensington security slot
- VESA Mounting Interface
- 100 x 100 mm
- RoHS, GREENGUARD, TUV Rheinland Low Blue Light Certification, Energy-Related Products (ErP) Lot 3, TUV Rheinland Ultra Low Noise Certification
- TopSeller
- Power supply
- Voltage Required
- Power Provided
- 150 Watt
- Efficiency
- 90%
Operating System / Software
- OS Provided
- Windows 10 Pro 64-bit Edition English
- Software
Sustainability Information
- ENERGY STAR Certified
- ENERGY STAR Version
- 7.0
- 49.1 cm
- 25.2 cm
- 37.7 cm
- 7.65 kg
