Lenovo ThinkCentre M800 Core i5-6500 4GB 500GB Windows 7 Pro
Quicklinx: CFJCWS00 Mfr#: 10FW000VUK
  • Core i5
  • Microsoft Windows 7 Professional 64-bit Edition
For large businesses (EDU/GOV/PUB etc.) with a need for a high-performance desktop PC, the ThinkCentre M800 provides the latest Intel technology without sacrificing security, stability, manageability and environmental friendliness.
  • Powerful processors
    Powerful processors deliver fast performance and nimble responsiveness. This feature-packed processor with built-in security is ready to take on your productivity, creativity, and entertainment needs without lagging. What's more, the processor helps expand the capabilities of the OS, giving you rich features to enhance your work or entertainment.
  • Platform stability
    The M800 SFF desktop features Intel Stable Image Platform Program (SIPP), and boasts a full 27-month life cycle with no planned hardware changes affecting the preloaded software image. Image stability for long-term deployment helps to reduce transition, qualification, and testing costs - ensuring savings for your business.
  • Multiple monitor display
    The M800 SFF desktop features Intel Stable Image Platform Program (SIPP), and boasts a full 27-month life cycle with no planned hardware changes affecting the preloaded software image. Image stability for long-term deployment helps to reduce transition, qualification, and testing costs - ensuring savings for your business. Multiple Monitor Display Maximize productivity with independent display support for up to two monitors. The expanded work area and easier navigation between applications helps improve productivity as you extend your desktop.
  • Solid security
    M800 desktops include some of the best security tools available in the industry. Disable USB ports to help prevent data theft and network security risks against unauthorized use of storage devices. The Trusted Platform Module (TPM) encrypts data and key information, like passwords and digital certificates, further securing applications, electronic transactions, and online communication. The M800 desktop also includes a chassis intrusion switch, which alerts against any unauthorized access attempts. Additional physical security through cable lock and Absolute Computrace Support.
  • Tool-less expandability
    Upgrades are a cinch for IT staff, with convenient tool-free access to the hardware within the M800. This is especially beneficial when working with multiple desktops.
  • Advanced thermal design
    The Intelligent Cooling Engine (ICE) 3.0 is designed to provide a balance between thermals and acoustics, which helps increase the life of the desktop. With two optimized settings, you choose the performance mode that best suits your work environment, prioritizing temperature or sound. Plus, ICE 3.0 allows for working in hotter temperatures, and enables system monitoring with thermal alerts, helping prevent damage from overheating.
Lenovo ThinkCentre M800 - tower Core i5 6500 3.2 GHz - 4 GB - HDD 500 GB - UK
Personal computer - tower
Intel Core i5 (6th Gen) 6500 / 3.2 GHz (up to 3.6 GHz, (Quad-Core)
Processor Socket
LGA1151 Socket
Processor Main Features
Intel Turbo Boost Technology 2
Cache Memory
6 MB
Cache Per Processor
6 MB
RAM
4 GB (installed) / 64 GB (max) - DDR4 SDRAM
Storage Controller
SATA (SATA 6Gb/s)
Hard Drive
HDD 500 GB - SATA 6Gb/s - 7200 rpm
Optical Storage
DVD SuperMulti
Graphics Controller
Intel HD Graphics 530
Audio Output
Stereo
1GbE
Keyboard
OS Provided
Microsoft Windows 7 Professional 64-bit Edition (downgrade from Windows 10 Pro 64-bit) + Windows 10 Pro 64-bit Licence
17.5 cm x 41.3 cm x 40.6 cm
12.5 kg
Manufacturer Selling Program
TopSeller
International warranty - 3 years - on-site
Personal computer
Product Form Factor
Tower
Built-in Devices
Speaker
Embedded Security
Trusted Platform Module (TPM 1.2) Security Chip
Processor / Chipset
CPU
Clock Speed
3.2 GHz
Max Turbo Speed
3.6 GHz
Number of Cores
Quad-Core
CPU Qty
1
Max CPU Qty
1
CPU Socket
LGA1151 Socket
Chipset Type
Intel Q150
Cache Memory
Installed Size
6 MB
Cache Per Processor
6 MB
RAM
Installed Size
DDR4 SDRAM
Effective Memory Speed
2133 MHz
Rated Memory Speed
1067 MHz
DIMM 288-pin
Slots
4 (Total) / 3 (empty)
Unbuffered, dual channel memory architecture
Configuration Features
1 x 4 GB
Hard Drive
HDD
1 x 500 GB
Interface Type
SATA 6Gb/s
Spindle Speed
7200 rpm
Storage Controller
1 x SATA
Controller Interface Type
SATA 6Gb/s
Optical Storage
DVD±RW (±R DL) / DVD-RAM DVD SuperMulti - SATA
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
Video Interfaces
VGA, DisplayPort
Audio Output
Sound Output Mode
Stereo
High Definition Audio
Input Device
Mouse, keyboard
Keyboard
Keyboard Name
Preferred Pro USB
USB
Localization & Layout
Mouse
Optical
USB
Ethernet Controller
Intel I219-LM
Wake on LAN (WoL)
Bays
2 (total) / 1 (free) x external 5.25" x 1/2H , 1 (total) / 0 (free) x internal 3.5" x 1/3H
Slots
4 (total) / 3 (free) x DIMM 288-pin , 1 (total) / 0 (free) x CPU , 1 (total) / 1 (free) x PCIe 3.0 x16 - half-length, full-height , 1 (total) / 1 (free) x PCIe 3.0 x16 - half-length, full-height (x4 mode) , 1 (total) / 1 (free) x PCIe 3.0 x1 - half-length, full-height
6 x USB 3.0 (2 front, 4 rear) , 1 x VGA , 2 x microphone (1 front, 1 rear) , 1 x headphones (1 in front) , 1 x serial , 1 x LAN (Gigabit Ethernet) , 1 x audio line-in , 2 x DisplayPort , 1 x audio line-out , 2 x USB 2.0
Theft/Intrusion Protection
Security lock slot (cable lock sold separately), padlock loop
TopSeller
Power supply
Power Provided
250 Watt
Efficiency
85%
Operating System / Software
OS Provided
Microsoft Windows 7 Professional 64-bit Edition (available through downgrade rights from Windows 10 Pro 64-bit) + Windows 10 Pro 64-bit Licence
17.5 cm
41.3 cm
40.6 cm
12.5 kg
