Lenovo ThinkCentre M75q Tiny Ryzen 5 PRO 3400GE 8GB 256GB SSD Windows 10 Professional 64-bit
Quicklinx: FPSCWS00 Mfr#: 11A4000HUK
  • IEEE 802.11n
Lenovo ThinkCentre M75q-1 11A4 - Tiny - Ryzen 5 Pro 3400GE / 3.3 GHz - RAM 8 GB - SSD 256 GB - TCG Opal Encryption, NVMe - Radeon Vega 11 - GigE, Bluetooth 5.0 - WLAN: 802.11ac, Bluetooth 5.0 - Win 10 Pro 64-bit - monitor: none - keyboard: UK
  • IT admin's dream
    With the ThinkCentre M715 Tiny, you can create your own modular all-in-one PC. Insert the Tiny inside the back of the optional ThinkCentre Tiny-in-One (TIO). Keep costs down by choosing to upgrade components separately, and get more use from your assets over time.
  • Packs a big punch
    The ThinkCentre M715 Tiny powers on through convenient keyboard controls to get you up and running almost instantly. The PCIe SSD storage coupled with 3D NAND technology allows you to seamlessly switch between tasks, and handle large files and applications with ease. Its fast-charging USB port enables quick charging and data transmission even when your PC is off.
  • Big on security
    The ThinkCentre M715 Tiny is optimized for protection and security. Armed with the Trusted Platform Module (TPM), this PC encrypts all your data, as well as your passwords. What's more, Smart USB Protection lets you control what devices can connect so you can prevent any data leaks. With the ThinkCentre M715 Tiny, you can keep all your confidential and critical data safe without worry.
  • Tough as it is tiny
    The ThinkCentre M715 Tiny is built to last in any environment. It's tested against military-specification requirements, as well as rigorous quality checks. From enduring arctic temperatures of -4 degrees Fahrenheit, to desert heat of 140 degrees F, this device can more than handle anything from minor bumps to extreme temperatures and dusty conditions.
Lenovo ThinkCentre M75q-1 - tiny - Ryzen 5 Pro 3400GE 3.3 GHz - 8 GB - SSD 256 GB - UK
Personal computer - tiny
AMD Ryzen 5 Pro 3400GE / 3.3 GHz (, up to 4 GHz, (Quad-Core)
Cache Memory
4 MB L3 Cache
Cache Per Processor
4 MB
RAM
8 GB (installed) / 32 GB (max) - DDR4 SDRAM - non-ECC
Storage Controller
SATA (SATA 6Gb/s)
Hard Drive
SSD 256 GB - PCI Express 3.0 x4 - M.2 2280 - TCG Opal Encryption, NVM Express (NVMe)
Optical Storage
No optical drive
Graphics Controller
AMD Radeon Vega 11
GigE, 802.11a, 802.11b/g/n, Wi-Fi 5, Bluetooth 5.0
Keyboard
OS Provided
Windows 10 Pro 64-bit Edition
17.9 cm x 18.29 cm x 3.45 cm
1.32 kg
Manufacturer Selling Program
TopSeller
Environmental Standards
ENERGY STAR Qualified EPEAT Silver
Limited warranty - 3 years - on-site
Personal computer
Product Form Factor
Tiny
Built-in Devices
Speaker
Embedded Security
Trusted Platform Module (TPM 2.0) Security Chip
Processor / Chipset
CPU
Clock Speed
3.3 GHz
Max Turbo Speed
4 GHz
Number of Cores
Quad-Core
CPU Qty
1
Max CPU Qty
1
L2 cache
2 MB
Chipset Type
AMD B300
Cache Memory
Installed Size
L3 Cache - 4 MB
Cache Per Processor
4 MB
RAM
Installed Size
8 GB / 32 GB (max)
Effective Memory Speed
2666 MHz
Rated Memory Speed
2666 MHz
SO-DIMM 260-pin
Slots
2 (Total) / 1 (empty)
Dual channel memory architecture
Configuration Features
1 x 8 GB
Hard Drive
SSD - M.2 2280
1 x 256 GB
Interface Type
PCI Express 3.0 x4
Storage Controller
1 x SATA
Controller Interface Type
SATA 6Gb/s
Channel Qty
1
Optical Storage
No optical drive
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
AMD Radeon Vega 11
Video Interfaces
HDMI, DisplayPort
Audio Output
High Definition Audio
Input Device
Mouse, keyboard
Keyboard
USB
Localization & Layout
Mouse
Mouse Name
Lenovo Calliope Mouse
USB
Ethernet Controller
Realtek RTL8111EPV-CG
Wireless LAN Supported
Wireless NIC
Realtek RTL8822CE
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, Bluetooth 5.0
Wake on LAN (WoL)
DASH 1.1
Bays
1 (total) / 1 (free) x internal 2.5"
Slots
2 (total) / 0 (free) x M.2 Card
2 x USB 3.1 Gen 1 (1 front, 1 rear) (one of them is Always On and fast-charging) , 1 x USB-C 3.1 Gen 1 (1 in front) , 1 x microphone (1 in front) , 1 x headphones/microphone (1 in front) , 3 x USB 2.0 , 1 x LAN (Gigabit Ethernet) , 2 x DisplayPort , 1 x HDMI
VESA mounting kit, adapter cage
Theft/Intrusion Protection
Security lock slot (cable lock sold separately), chassis intrusion switch, tool-less chassis access
Security Slot Type
Kensington security slot
VESA Mounting Interface
100 x 100 mm, 75 x 75 mm
RoHS, Energy-Related Products (ErP) Lot 3
TopSeller
Power adapter
Power Provided
65 Watt
Efficiency
88%
Operating System / Software
OS Provided
Windows 10 Pro 64-bit Edition English
Sustainability Information
EPEAT Compliant
EPEAT Silver
ENERGY STAR Certified
ENERGY STAR Version
7.1
17.9 cm
18.29 cm
3.45 cm
1.32 kg
Monitors (4)
FPSC Lenovo ThinkVision T24d 24" 1920x1080 VGA HDMI DisplayPort IPS LED Monitor In Stock £202.02
FPSC Lenovo ThinkVision T27p-10 27" 3840x2160 HDMI DisplayPort USB-C IPS LED Monitor In Stock £454.54
FPSC Lenovo ThinkVision P27h-20 27" 2560x1440 6ms HDMI DisplayPort IPS LED Monitor In Stock £336.70
FPSC Lenovo ThinkVision T27q-20 27" 2560x1440 4ms HDMI DisplayPort IPS LED Monitor In Stock £321.24
Keyboards and Mice (2)
FPSC Lenovo Professional Wireless Keyboard In Stock £54.36
FPSC Lenovo Essential Wired Keyboard and Mouse Combo - UK English In Stock £25.39
Other bundles (6)
FPSC Lenovo ThinkPad USB 3.0 Secure HDD-500GB In Stock £143.11
FPSC Lenovo HDMI to VGA Monitor Adapter In Stock £23.20
FPSC Lenovo USB3.0 To VGA/HDMI Adapter In Stock £63.85
FPSC Lenovo 2m HDMI Cable In Stock £17.02
FPSC Lenovo ThinkPad USB3.0 to Ethernet Adapter In Stock £16.07
FPSC Kensington Security Cable Lock In Stock £23.65
