Powerful yet compact, the ThinkCentre M720 SFF boasts Intel processing with advanced memory, storage and USB technology, enabling you to multi-task seamlessly. To help safeguard your data and hardware, multiple security features are built in. Easy to manage and configure, this high-performance PC can meet your business needs now and in the future.
Real power, real results
The ThinkCentre M720 SFF is designed to help you get what you need done, quickly and efficiently. Powered by an Intel processor and lightning-fast DDR4 memory, it takes everything in its stride - from everyday computing, to high-end graphic design and multitasking, to data-crunching. -
Go green, save green
With its Energy Star 7.0 and EPEAT Gold rating, the ThinkCentre M720 SFF is proven to be extremely energy efficient. In addition, it also has been rigorously tested.
- Lenovo ThinkCentre M720s - SFF - Core i5 8400 2.8 GHz - 8 GB - SSD 256 GB - UK
- Personal computer - small form factor
- Localisation
- Processor
- Intel Core i5 (8th Gen) 8400 / 2.8 GHz (, up to 4 GHz, (6-core)
- Cache Memory
- 9 MB
- Cache Per Processor
- 9 MB
- RAM
- 8 GB (installed) / 64 GB (max) - DDR4 SDRAM - non-ECC
- Storage Controller
- SATA (SATA 6Gb/s)
- Hard Drive
- SSD 256 GB - SATA 6Gb/s - 2.5" - TCG Opal Encryption
- Optical Storage
- No optical drive
- Card Reader
- 7 in 1
- Graphics Controller
- Intel UHD Graphics 630
- Networking
- 1GbE, 802.11a, 802.11b/g/n, Wi-Fi 5, Bluetooth 4.2
- Keyboard
- UK
- Power
- AC 120/230 V (50/60 Hz)
- OS Provided
- Windows 10 Pro 64-bit Edition
- Software Included
- Cyberlink PowerDVD, CyberLink Power2Go, Linkedin, Lenovo ThinkVantage
- Black
- 9.25 cm x 29.05 cm x 34.35 cm
- 6 kg
- Manufacturer Selling Program
- TopSeller
- Environmental Standards
- ENERGY STAR Qualified
- Limited warranty - 3 years - on-site
- Personal computer
- Product Form Factor
- Small form factor
- Built-in Devices
- Speaker
- Embedded Security
- Trusted Platform Module (TPM 2.0) Security Chip
- Black
- Localisation
Processor / Chipset
- CPU
- Clock Speed
- 2.8 GHz
- Max Turbo Speed
- 4 GHz
- Number of Cores
- 6-core
- CPU Qty
- 1
- Max CPU Qty
- 1
- Chipset Type
- Intel B360
Cache Memory
- Installed Size
- 9 MB
- 9 MB
RAM
- Installed Size
- 8 GB / 64 GB (max)
- Technology
- Effective Memory Speed
- 2666 MHz
- Rated Memory Speed
- 2666 MHz
- Form Factor
- DIMM 288-pin
- Slots
- 4 (Total) / 3 (empty)
- Unbuffered, dual channel memory architecture
- Configuration Features
- 1 x 8 GB
Hard Drive
- SSD - 2.5"
- Capacity
- 1 x 256 GB
- Interface Type
- SATA 6Gb/s
Storage Controller
- 1 x SATA
- Controller Interface Type
- SATA 6Gb/s
- Channel Qty
- 3
Optical Storage
- No optical drive
Card Reader
- 7 in 1 card reader
Monitor
- Monitor Type
- None.
Graphics Controller
- Graphics Processor
- Video Interfaces
- VGA, DisplayPort
- Max Monitors Supported
- 3
Audio Output
- High Definition Audio
Input Device
- Mouse, keyboard
Keyboard
- Interface
- USB
- Localization & Layout
- UK
Mouse
- Interface
- USB
- Ethernet Controller
- Intel I219-V
- Wireless LAN Supported
- Wireless NIC
- Intel Dual Band Wireless-AC 3165
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, Bluetooth 4.2
- Wake on LAN (WoL)
- Bays
- 1 (total) / 1 (free) x external 5.25" Slim Line ¦ 1 (total) / 0 (free) x internal 3.5" x 1/3H
- Slots
- 1 (total) / 1 (free) x PCIe 3.0 x16 - low-profile ¦ 2 (total) / 2 (free) x PCIe 3.0 x1 - low-profile ¦ 2 (total) / 1 (free) x M.2 Card
- 2 x USB 3.1 Gen 2 (2 in front) ¦ 2 x USB 3.1 Gen 1 (2 in front) ¦ 1 x USB-C 3.1 Gen 1 (1 in front) (charging) ¦ 1 x microphone (1 in front) ¦ 1 x headphones/microphone (1 in front) ¦ 4 x USB 2.0 ¦ 1 x serial ¦ 1 x LAN (Gigabit Ethernet) ¦ 1 x VGA ¦ 2 x DisplayPort ¦ 1 x audio line-out
- Theft/Intrusion Protection
- Security lock slot (cable lock sold separately), padlock loop, chassis intrusion switch
- Security Slot Type
- Kensington security slot
- RoHS, Energy-Related Products (ErP) Lot 3
- TopSeller
- Power supply
- Voltage Required
- Power Provided
- 180 Watt
- Efficiency
- 85%
Operating System / Software
- OS Provided
- Software
Sustainability Information
- ENERGY STAR Certified
- ENERGY STAR Version
- 6.1
- 9.25 cm
- 29.05 cm
- 34.35 cm
- 6 kg
