Powerful and secure, the ThinkCentre M720 Tower lets you multi-task seamlessly and lets your productivity flow. As well as cutting-edge processing, memory, and storage, it comes with advanced data and hardware security as standard. Easy to manage, this performance-enhancing PC is designed to drive your business forward.
Real power, real results
The ThinkCentre M720 Tower is designed to help you get what you need done, quickly and efficiently. It takes everything in its stride - from everyday computing, to high-end graphic design and multitasking, to data-crunching. -
Send would-be hackers packing
To help safeguard your data, Smart USB Protection and the Trusted Platform Module (TPM) are hardwired into every ThinkCentre M720. The first enables you to restrict what USB devices can access your PC, while the TPM is the international standard for encrypting data. -
It pays to be well connected
When it comes to connecting your computing accessories and smart devices, the ThinkCentre M720 Tower has more than enough ports, including USB-C and USB 3.1 ports. What's more, these high-speed ports are conveniently located in the front for quick, easy access. -
Easy to use and configure
If the PC is under the desk or slightly out of reach, you can switch it on remotely with a simple shortcut using the keyboard, Alt + P. The ThinkCentre M720 Tower also has a number of expansion slots, enabling it to be configured as your business needs change.
- Lenovo ThinkCentre M720t - tower - Core i7 9700 3 GHz - 8 GB - SSD 256 GB - UK
- Personal computer - tower
- Localisation
- Processor
- Intel Core i7 (9th Gen) 9700 / 3 GHz (4.7 GHz) (8-core)
- Processor Socket
- LGA1151 Socket
- Processor Main Features
- Intel Turbo Boost Technology 2, Intel Smart Cache
- Cache Memory
- 12 MB
- Cache Per Processor
- 12 MB
- RAM
- 8 GB (installed) / 64 GB (max) - DDR4 SDRAM - non-ECC
- Storage Controller
- SATA (SATA 6Gb/s)
- Hard Drive
- SSD 256 GB - SATA 6Gb/s - 2.5" - TCG Opal Encryption
- Optical Storage
- DVD-Writer
- Card Reader
- 7 in 1
- Graphics Controller
- Intel UHD Graphics 630
- Networking
- GigE
- Keyboard
- UK
- Power
- AC 120/230 V (50/60 Hz)
- OS Provided
- Windows 10 Pro 64-bit Edition
- Black
- 15 cm x 27.05 cm x 36 cm
- 7 kg
- Manufacturer Selling Program
- TopSeller
- Environmental Standards
- ENERGY STAR Qualified
- Limited warranty - 3 years - on-site
- Personal computer
- Product Form Factor
- Tower
- Built-in Devices
- Speaker
- Embedded Security
- Trusted Platform Module (TPM 2.0) Security Chip
- Black
- Localisation
Processor / Chipset
- CPU
- Clock Speed
- 3 GHz
- Max Turbo Speed
- 4.7 GHz
- Number of Cores
- 8-core
- CPU Qty
- 1
- Max CPU Qty
- 1
- CPU Socket
- LGA1151 Socket
- Chipset Type
- Intel B360
Cache Memory
- Installed Size
- 12 MB
- 12 MB
RAM
- Installed Size
- 8 GB / 64 GB (max)
- Technology
- Effective Memory Speed
- 2666 MHz
- Rated Memory Speed
- 2666 MHz
- Form Factor
- DIMM 288-pin
- Slots
- 4 (Total) / 3 (empty)
- Unbuffered, dual channel memory architecture
- Configuration Features
- 1 x 8 GB
Hard Drive
- SSD - 2.5"
- Capacity
- 1 x 256 GB
- Interface Type
- SATA 6Gb/s
Storage Controller
- 1 x SATA
- Controller Interface Type
- SATA 6Gb/s
- Channel Qty
- 3
Optical Storage
- DVD-Writer - SATA
Card Reader
- 7 in 1 card reader
Monitor
- Monitor Type
- None.
Graphics Controller
- Graphics Processor
- Video Interfaces
- VGA, DisplayPort
- Max Monitors Supported
- 3
Audio Output
- High Definition Audio
Input Device
- Mouse, keyboard
Keyboard
- Keyboard Name
- Lenovo Calliope Keyboard
- Interface
- USB
- Localization & Layout
- UK
Mouse
- Mouse Name
- Lenovo Calliope Mouse
- Interface
- USB
- Ethernet Controller
- Intel I219-V
- Data Link Protocol
- Wake on LAN (WoL)
- Bays
- 1 (total) / 0 (free) x external 5.25" Slim Line , 1 (total) / 0 (free) x internal 3.5" x 1/3H
- Slots
- 1 (total) / 1 (free) x PCIe 3.0 x16 - half-length, full-height , 2 (total) / 2 (free) x PCIe 3.0 x1 - half-length, full-height , 2 (total) / 0 (free) x M.2 Card
- 2 x USB 3.1 Gen 2 (2 in front) , 2 x USB 3.1 Gen 1 (2 in front) , 1 x USB-C 3.1 Gen 1 (1 in front) (charging) , 1 x microphone (1 in front) , 1 x headphones/microphone (1 in front) , 4 x USB 2.0 , 1 x serial , 1 x LAN (Gigabit Ethernet) , 1 x VGA , 2 x DisplayPort , 1 x audio line-out
- Theft/Intrusion Protection
- Security lock slot (cable lock sold separately), padlock loop, chassis intrusion switch
- Security Slot Type
- Kensington security slot
- RoHS, Energy-Related Products (ErP) Lot 3, TUV Rheinland Ultra Low Noise Certification
- TopSeller
- Power supply
- Voltage Required
- Power Provided
- 180 Watt
- Efficiency
- 85%
Operating System / Software
- OS Provided
- Windows 10 Pro 64-bit Edition English
- Software
- Cyberlink PowerDVD, CyberLink Power2Go, Linkedin, Lenovo ThinkVantage
- ENERGY STAR Certified
- ENERGY STAR Version
- 6.1
- 15 cm
- 27.05 cm
- 36 cm
- 7 kg
