Lenovo ThinkCentre M720 Tower Intel Core i7-9700 8GB 1TB Windows 10 Professional 64-bit
Quicklinx: FPSGWS00 Mfr#: 10SQ0069UK
  • Core i7
Powerful and secure, the ThinkCentre M720 Tower lets you multi-task seamlessly and lets your productivity flow. As well as cutting-edge processing, memory, and storage, it comes with advanced data and hardware security as standard. Easy to manage, this performance-enhancing PC is designed to drive your business forward.
  • Real power, real results
    The ThinkCentre M720 Tower is designed to help you get what you need done, quickly and efficiently. It takes everything in its stride - from everyday computing, to high-end graphic design and multitasking, to data-crunching.
  • Send would-be hackers packing
    To help safeguard your data, Smart USB Protection and the Trusted Platform Module (TPM) are hardwired into every ThinkCentre M720. The first enables you to restrict what USB devices can access your PC, while the TPM is the international standard for encrypting data.
  • It pays to be well connected
    When it comes to connecting your computing accessories and smart devices, the ThinkCentre M720 Tower has more than enough ports, including USB-C and USB 3.1 ports. What's more, these high-speed ports are conveniently located in the front for quick, easy access.
  • Easy to use and configure
    If the PC is under the desk or slightly out of reach, you can switch it on remotely with a simple shortcut using the keyboard, Alt + P. The ThinkCentre M720 Tower also has a number of expansion slots, enabling it to be configured as your business needs change.
Lenovo ThinkCentre M720t - tower Core i7 9700 3 GHz - 8 GB - HDD 1 TB - UK
Personal computer - tower
Intel Core i7 (9th Gen) 9700 / 3 GHz (up to 4.7 GHz, (8-core)
Cache Memory
12 MB
Cache Per Processor
12 MB
RAM
8 GB (installed) / 64 GB (max) - DDR4 SDRAM - non-ECC
Storage Controller
SATA (SATA 6Gb/s)
Hard Drive
HDD 1 TB - SATA 6Gb/s - 7200 rpm
Optical Storage
DVD-Writer
Card Reader
7 in 1
Graphics Controller
Intel UHD Graphics 630
1GbE
Keyboard
OS Provided
Windows 10 Pro 64-bit Edition
Software Included
Cyberlink PowerDVD, CyberLink Power2Go, Linkedin, Lenovo ThinkVantage
15 cm x 27.05 cm x 36 cm
7 kg
Manufacturer Selling Program
Lenovo TopSeller
Environmental Standards
ENERGY STAR Qualified
Limited warranty - 3 years - on-site
Personal computer
Product Form Factor
Tower
Built-in Devices
Speaker
Embedded Security
Trusted Platform Module (TPM 2.0) Security Chip
Processor / Chipset
CPU
Clock Speed
3 GHz
Max Turbo Speed
4.7 GHz
Number of Cores
8-core
CPU Qty
1
Max CPU Qty
1
Chipset Type
Intel B360
Cache Memory
Installed Size
12 MB
Cache Per Processor
12 MB
RAM
Installed Size
Effective Memory Speed
2666 MHz
Rated Memory Speed
1333 MHz
DIMM 288-pin
Slots
4 (Total) / 3 (empty)
Unbuffered, dual channel memory architecture
Configuration Features
1 x 8 GB
Hard Drive
HDD
1 x 1 TB
Interface Type
SATA 6Gb/s
Spindle Speed
7200 rpm
Storage Controller
1 x SATA
Controller Interface Type
SATA 6Gb/s
Channel Qty
3
Optical Storage
DVD-Writer - SATA
Card Reader
7 in 1 card reader
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
Video Interfaces
VGA, DisplayPort
Max Monitors Supported
3
Audio Output
High Definition Audio
Input Device
Mouse, keyboard
Keyboard
USB
Localization & Layout
Mouse
Mouse Name
Lenovo Calliope Mouse
USB
Ethernet Controller
Intel I219-V
Wake on LAN (WoL)
Bays
1 (total) / 0 (free) x external 5.25" Slim Line , 1 (total) / 0 (free) x internal 3.5" x 1/3H
Slots
1 (total) / 1 (free) x PCIe 3.0 x16 - half-length, full-height , 2 (total) / 2 (free) x PCIe 3.0 x1 - half-length, full-height , 2 (total) / 2 (free) x M.2 Card
2 x USB 3.1 Gen 2 (2 in front) , 2 x USB 3.1 Gen 1 (2 in front) , 1 x USB-C 3.1 Gen 1 (1 in front) (charging) , 1 x microphone (1 in front) , 1 x headphones/microphone (1 in front) , 4 x USB 2.0 , 1 x serial , 1 x LAN (Gigabit Ethernet) , 1 x VGA , 2 x DisplayPort , 1 x audio line-out
Theft/Intrusion Protection
Security lock slot (cable lock sold separately), padlock loop, chassis intrusion switch
Security Slot Type
Kensington security slot
RoHS, Energy-Related Products (ErP) Lot 3, TUV Rheinland Low Noise Certification
Lenovo TopSeller
Power supply
Power Provided
180 Watt
Efficiency
85%
Operating System / Software
OS Provided
Windows 10 Pro 64-bit Edition English
Software
Sustainability Information
ENERGY STAR Certified
ENERGY STAR Version
6.1
15 cm
27.05 cm
36 cm
7 kg
FPSG Lenovo DisplayPort Adapter - DisplayPort (M) to DisplayPort (F) In Stock £66.79
FPSG Lenovo ThinkPad USB3.0 to Ethernet Adapter In Stock £16.01
