Multiple monitor display
Maximize productivity with independent display support for up to three monitors. The expanded work area and easier navigation between applications helps reduce errors and improve productivity as you extend your desktop across multiple monitors.
Green leadership
Lenovo Desktop Power Manager enables professional-level power monitoring, putting you in control of saving energy and keeping costs down. Plus, with ratings like ENERGY STAR 6.1, ULE Gold, EPEAT Gold, and 85% efficiency with 80+ Platinum power supply unit (PSU), you can feel good about helping the planet and your bottom line.
Lenovo solution center
Lenovo Solution Center provides access to a simplified dashboard that reflects total system health. This hardware diagnostic tool allows quick access to frequently used system management tools, including backup and restore, antivirus and firewall settings, system/software updates, internet connections, and service and support. Drastically speed migration time with ThinkVantage System Migration Assistant. Spend less time manually searching for drivers and software updates with ThinkVantage System Update.
Fast data transfer
Move data between the M700 SFF and other devices quickly with USB 3.0 - it's up to 10 times faster than previous USB technologies, and is backward-compatible.
More dust-resistant than ever
ThinkCentre PCs are designed with best-in-class dust resistance and thermal management; yet still, Lenovo engineers wanted to do even more for Lenovo next generation desktops. They added the option for ThinkCentre Dust Shield, filters that reduce internal dust and dirt filtration by up to 57% - this feature further improves reliability without impacting thermals or acoustics. Plus, the filters are easily removable and washable for long-term use. Extend the life of your ThinkCentre M700.
- Lenovo ThinkCentre M700 - SFF Core i3 6100 3.7 GHz - 4 GB - HDD 500 GB - UK
- Personal computer - SFF
- Localisation
- Processor
- Intel Core i3 (6th Gen) 6100 / 3.7 GHz (Dual-Core)
- Processor Socket
- LGA1151 Socket
- Processor Main Features
- Hyper-Threading Technology
- Cache Memory
- 3 MB
- Cache Per Processor
- 3 MB
- RAM
- 4 GB (installed) / 32 GB (max) - DDR4 SDRAM
- Storage Controller
- SATA (SATA 6Gb/s)
- Hard Drive
- HDD 500 GB - SATA 6Gb/s - 7200 rpm
- Optical Storage
- DVD SuperMulti
- Card Reader
- 9 in 1
- Graphics Controller
- Intel HD Graphics 530
- Audio Output
- Stereo
- Networking
- 1GbE
- Keyboard
- UK
- Power
- AC 120/230 V (50/60 Hz)
- OS Provided
- Microsoft Windows 7 Professional 64-bit Edition (downgrade from Windows 10 Pro 64-bit) + Windows 10 Pro 64-bit Licence
- Software Included
- ThinkVantage Rescue and Recovery, Adobe Reader, ThinkVantage System Update, Lenovo Message Center Plus, ThinkVantage Tools, Lenovo Solution Center, Password Manager, McAfee LiveSafe (30 days trial), Lenovo Desktop Power Manager, SHAREit, REACHit, PowerDVD Create
- Black
- 33.8 cm x 35.7 cm x 8.8 cm
- 5.6 kg
- Manufacturer Selling Program
- TopSeller
- Environmental Standards
- ENERGY STAR Qualified
- Limited warranty - 3 years - on-site
- Personal computer
- Product Form Factor
- SFF
- Embedded Security
- Trusted Platform Module (TPM 1.2) Security Chip
- Black
- Localisation
Processor / Chipset
- CPU
- Clock Speed
- 3.7 GHz
- Number of Cores
- Dual-Core
- CPU Qty
- 1
- Max CPU Qty
- 1
- CPU Socket
- LGA1151 Socket
- Chipset Type
- Intel H110 Express
Cache Memory
- Installed Size
- 3 MB
- 3 MB
RAM
- Installed Size
- Technology
- DDR4 SDRAM
- Effective Memory Speed
- 2133 MHz
- Rated Memory Speed
- 1067 MHz
- Form Factor
- DIMM 288-pin
- Slots
- 2 (Total) / 1 (empty)
- Unbuffered
- Configuration Features
- 1 x 4 GB
Hard Drive
- HDD
- Capacity
- 1 x 500 GB
- Interface Type
- SATA 6Gb/s
- Spindle Speed
- 7200 rpm
Storage Controller
- 1 x SATA
- Controller Interface Type
- SATA 6Gb/s
- Channel Qty
- 3
Optical Storage
- DVD±RW (±R DL) / DVD-RAM DVD SuperMulti - SATA
Card Reader
- 9 in 1 card reader
Monitor
- Monitor Type
- None.
Graphics Controller
- Graphics Processor
- Video Interfaces
- VGA, DisplayPort
- Max Monitors Supported
- 2
Audio Output
- Sound Output Mode
- Stereo
- High Definition Audio
Input Device
- Mouse, keyboard
Keyboard
- Interface
- USB
- Localization & Layout
- UK
Mouse
- Technology
- Optical
- Interface
- USB
- Ethernet Controller
- Realtek RTL8111GN
- Data Link Protocol
- Wake on LAN (WoL)
- Bays
- 1 (total) / 0 (free) x external 5.25" x 1/6H (Slim Line) , 1 (total) / 0 (free) x internal 3.5" x 1/3H , 1 (total) / 0 (free) x external
- Slots
- 2 (total) / 1 (free) x DIMM 288-pin , 1 (total) / 0 (free) x CPU , 1 (total) / 1 (free) x PCIe 3.0 x16 - low-profile , 2 (total) / 2 (free) x PCIe 2.0 x1 - low-profile
- 4 x USB 3.0 (2 front, 2 rear) , 2 x microphone (1 front, 1 rear) , 1 x headphones (1 in front) , 2 x USB 2.0 , 1 x serial , 1 x LAN (Gigabit Ethernet) , 1 x VGA , 1 x DisplayPort , 1 x PS/2 keyboard , 1 x PS/2 mouse , 1 x audio line-in , 1 x audio line-out , 1 x parallel
- Theft/Intrusion Protection
- Security lock slot (cable lock sold separately), padlock loop, chassis intrusion switch
- RoHS, GREENGUARD, Energy-Related Products (ErP) Lot 3
- TopSeller
- Power supply
- Voltage Required
- Power Provided
- 210 Watt
- Efficiency
- 85%
Operating System / Software
- OS Provided
- Microsoft Windows 7 Professional 64-bit Edition (available through downgrade rights from Windows 10 Pro 64-bit) + Windows 10 Pro 64-bit Licence
- Software
Sustainability Information
- ENERGY STAR Certified
- ENERGY STAR Version
- 6.0
- 33.8 cm
- 35.7 cm
- 8.8 cm
- 5.6 kg
C2G 2m USB 2.0 A/B Cable - Black | In Stock | £4.20 |
C2G 2m DisplayPort Male to HD Male Adapter Cable - Black | In Stock | £17.25 |
C2G 3m DisplayPort Cable with Latches M/M - Black | In Stock | £13.78 |
C2G 20cm DisplayPort Male to HDMI Female Adapter Converter Black | In Stock | £16.49 |
