It's a small PC, but you can use it to get big things done. Solid specs including powerful processing, large memory and multiple storage options make the ThinkCentre M630e Tiny a compact powerhouse. The ThinkCentre ecosystem gives you extraordinary flexibility. Easy-to-install accessories let you attach your M630e Tiny to a projector, a wall, or the underside of a desk. You can also create your own modular AIO with a ThinkCentre Tiny-in-One monitor. Added benefit: you can save on costs by upgrading the display and the M630e Tiny on separate schedules.
The ThinkCentre M630e Tiny helps you keep your business data safe with security features like Smart USB Protection, which prevents malware from entering your system through the USB ports. A menu of I/O ports give you high-speed connectivity to peripherals for easy multitasking. And a USB-C data port makes it a snap to share information quickly. IT admins will love the Smart Power On feature, which enables remote device manageability with a simple keyboard shortcut.
Big on performance
It's a small PC, but you can use it to get big things done. Solid specs including powerful processing, large memory and multiple storage options make the ThinkCentre M630e Tiny a compact powerhouse. -
Tiny by design
The ThinkCentre ecosystem gives you extraordinary flexibility. Easy-to-install accessories let you attach your M630e Tiny to a projector, a wall, or the underside of a desk. You can also create your own modular AIO with a ThinkCentre Tiny-in-One monitor. Added benefit: you can save on costs by upgrading the display and the M630e Tiny on separate schedules. -
Robust security
The ThinkCentre M630e Tiny helps you keep your business data safe with security features like Smart USB Protection, which prevents malware from entering your system through the USB ports. -
Versatile connectivity
- Lenovo ThinkCentre M630e - tiny - Core i5 8265U 1.6 GHz - 8 GB - SSD 256 GB - UK
- Personal computer - tiny
- Localisation
- Processor
- Intel Core i5 (8th Gen) 8265U / 1.6 GHz (3.9 GHz) (Quad-Core)
- Cache Memory
- 6 MB
- Cache Per Processor
- 6 MB
- RAM
- 8 GB (installed) / 16 GB (max) - DDR4 SDRAM - non-ECC
- Storage Controller
- SATA (SATA 6Gb/s)
- Hard Drive
- SSD 256 GB - PCI Express 3.0 x4 - M.2 2280 - TCG Opal Encryption, NVM Express (NVMe)
- Optical Storage
- No optical drive
- Graphics Controller
- Intel UHD Graphics 620
- Networking
- GigE, 802.11a, 802.11b/g/n, 802.11ac, Bluetooth 4.2
- Keyboard
- UK
- Power
- AC 120/230 V (50/60 Hz)
- OS Provided
- Windows 10 Pro 64-bit Edition
- Black
- 17.9 cm x 18.29 cm x 3.45 cm
- 1.32 kg
- Manufacturer Selling Program
- TopSeller
- Environmental Standards
- ENERGY STAR Qualified
- Limited warranty - 1 year - on-site
- Personal computer
- Product Form Factor
- Tiny
- Built-in Devices
- Speaker
- Embedded Security
- Firmware Trusted Platform Module (TPM 2.0) Security Chip
- Black
- Localisation
Processor / Chipset
- CPU
- Clock Speed
- 1.6 GHz
- Max Turbo Speed
- 3.9 GHz
- Number of Cores
- Quad-Core
- CPU Qty
- 1
- Max CPU Qty
- 1
Cache Memory
- Installed Size
- 6 MB
- 6 MB
RAM
- Installed Size
- 8 GB / 16 GB (max)
- Technology
- Effective Memory Speed
- 2400 MHz
- Rated Memory Speed
- 2666 MHz
- Form Factor
- SO-DIMM 260-pin
- Slots
- 1 (Total) / 0 (empty)
- Configuration Features
- 1 x 8 GB
Hard Drive
- SSD - M.2 2280
- Capacity
- 1 x 256 GB
- Interface Type
Storage Controller
- 1 x SATA
- Controller Interface Type
- SATA 6Gb/s
- Channel Qty
- 1
Optical Storage
- No optical drive
Monitor
- Monitor Type
- None.
Graphics Controller
- Graphics Processor
- Video Interfaces
- HDMI, DisplayPort
- Max Monitors Supported
- 2
Input Device
- Mouse, keyboard
Keyboard
- Keyboard Name
- Lenovo Calliope Keyboard
- Interface
- USB
- Localization & Layout
- UK
Mouse
- Mouse Name
- Lenovo Calliope Mouse
- Interface
- USB
- Ethernet Controller
- Realtek RTL8111HN-CG
- Wireless LAN Supported
- Wireless NIC
- Intel Dual Band Wireless-AC 3165
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, Bluetooth 4.2
- Bays
- 1 (total) / 1 (free) x internal 2.5"
- Slots
- 2 (total) / 0 (free) x M.2 Card
- 3 x USB 3.1 Gen 1 (1 front, 2 rear) , 1 x USB-C 3.1 Gen 1 (1 in front) , 1 x microphone (1 in front) , 1 x headphones/microphone (1 in front) , 2 x USB 2.0 , 1 x LAN (Gigabit Ethernet) , 1 x DisplayPort , 1 x HDMI
- Theft/Intrusion Protection
- Security lock slot (cable lock sold separately), chassis intrusion switch
- Security Slot Type
- Kensington security slot
- RoHS, WEEE, REACH, Energy-Related Products (ErP) Lot 3
- TopSeller
- Power adapter
- Voltage Required
- Power Provided
- 65 Watt
- Efficiency
- 88%
Operating System / Software
- OS Provided
- Windows 10 Pro 64-bit Edition English
- Software
- Lenovo Vantage, Linkedin
- ENERGY STAR Certified
- ENERGY STAR Version
- 7.0
- 17.9 cm
- 18.29 cm
- 3.45 cm
- 1.32 kg
Warranties (2)
Lenovo On-Site Repair Extended Service Agreement 3 Years | In Stock | £25.81 |
Lenovo ePac On-site Repair Extended Service Agreement 5 Years On-Site | In Stock | £63.11 |
Monitors (4)
Lenovo ThinkVision T24d 24" 1920x1080 VGA HDMI DisplayPort IPS LED Monitor | In Stock | £202.47 |
Lenovo ThinkVision T27p-10 27" 3840x2160 HDMI DisplayPort USB-C IPS LED Monitor | In Stock | £454.54 |
Lenovo ThinkVision P27h-20 27" 2560x1440 6ms HDMI DisplayPort IPS LED Monitor | In Stock | £336.70 |
Lenovo ThinkVision T27q-20 27" 2560x1440 4ms HDMI DisplayPort IPS LED Monitor | In Stock | £312.68 |
Keyboards and Mice (3)
Lenovo Professional Wireless Keyboard | In Stock | £54.36 |
Lenovo Essential Wired Keyboard and Mouse Combo - UK English | In Stock | £25.39 |
Lenovo ThinkPad Bluetooth Silent Mouse - Right and Left-handed | In Stock | £23.88 |
Other bundles (6)
Lenovo HDMI to VGA Monitor Adapter | In Stock | £23.20 |
Lenovo 2m HDMI Cable | In Stock | £17.02 |
Lenovo ThinkPad USB3.0 to Ethernet Adapter | In Stock | £16.07 |
Kensington Security Cable Lock | In Stock | £23.65 |
Lenovo 100 Headset on ear wired - USB black for IdeaPad 3 ThinkCe | In Stock | £34.84 |
Lenovo Thinkvision MC50 Monitor Webcam | In Stock | £53.85 |
