Whether you manage a home office or a mid-sized business, the ThinkCentre Edge 72 Small Form Factor desktop is an excellent choice for everyday computing. From its productivity features to its multiple display support - which makes multitasking a breeze - the ThinkCentre Edge 72 helps you keep your business running smoothly and efficiently.
RapidBoot Performance
Lenovo's exclusive RapidBoot HDD Accelerator dramatically reduces startup time by copying and compressing Windows boot files and reloading them to RAM.
Multi-Display Support
ThinkCentre Edge 72 natively supports two independent displays - and permits up to four displays on models with discrete graphics.
System Stability
Proprietary software ensures system stability, simplifies maintenance, makes it easier to recover data when necessary, and manages your passwords.
Hardware Security
The Kensington Lock port makes maintaining asset security a snap.
Enhanced graphics
Enjoy rich screen resolution and vivid graphics - and view data across as many as four screens -with the optional AMD dual-port graphics card.
View Management Utility
Multitask with ease and maximize your productivity with the ThinkCentre Edge 72's View Management Utility. The VMU creates up to four partitions on a single display - it's like using multiple monitors in one.
WiFi, Bluetooth
With 802.11 b/g/n WiFi connectivity and optional Bluetooth® 4.0, you'll be able to connect seamlessly with your network and other devices.
Energy Efficient
Save on energy costs and help the environment with the ThinkCentre Edge 72's Cisco EnergyWise-certified Desktop Power Manager.
Data Transfer
The ThinkCentre Edge 72's 6 USB ports give you plenty of ways to transfer data and connect other devices.
- Lenovo ThinkCentre Edge 72 - SFF - AI Ready - Core i5 3330S 2.7 GHz - 4 GB - HDD 500 GB
- Personal computer - SFF AI Ready - administrator password, hard drive password, power-on password, boot without keyboard or mouse, USB port control, boot sequence control
- Localisation
- Processor
- Intel Core i5 (3rd Gen) 3330S / 2.7 GHz (, up to 3.2 GHz, (Quad-Core)
- Processor Socket
- LGA1155 Socket
- Processor Main Features
- Intel Turbo Boost Technology 2
- Cache Memory
- 6 MB
- Cache Per Processor
- 6 MB
- RAM
- 4 GB (installed) / 16 GB (max) - DDR3 SDRAM - PC3-12800
- Storage Controller
- SATA (SATA 3Gb/s)
- Hard Drive
- HDD 500 GB - SATA 3Gb/s - 7200 rpm
- Optical Storage
- DVD SuperMulti
- Card Reader
- 9 in 1
- Graphics Controller
- Intel HD Graphics 2500
- Audio Output
- Stereo - integrated
- Networking
- 1GbE
- Power
- AC 120/230 V (50/60 Hz)
- OS Provided
- Microsoft Windows 7 Professional 64-bit Edition (downgrade from Windows 8 Pro 64-bit) + Windows 8 Pro 64-bit Licence
- Glossy black
- 33.6 cm x 38.2 cm x 10.1 cm
- 6 kg
- Manufacturer Selling Program
- TopSeller
- Limited warranty - 1 year - on-site - response time: next business day
- Personal computer - AI Ready
- Product Form Factor
- SFF
- Built-in Devices
- Speaker
- Glossy black
- Localisation
Processor / Chipset
- CPU
- Clock Speed
- 2.7 GHz
- Max Turbo Speed
- 3.2 GHz
- Number of Cores
- Quad-Core
- CPU Qty
- 1
- Max CPU Qty
- 1
- CPU Socket
- LGA1155 Socket
- Chipset Type
- Intel H61 Express
Cache Memory
- Installed Size
- 6 MB
- 6 MB
RAM
- Installed Size
- Technology
- DDR3 SDRAM
- Effective Memory Speed
- 1600 MHz
- Rated Memory Speed
- 1600 MHz
- Memory Specification Compliance
- PC3-12800
- Form Factor
- DIMM 240-pin
- Slots
- 2 (Total) / 1 (empty)
- Unbuffered
- Configuration Features
- 1 x 4 GB
Hard Drive
- HDD
- Capacity
- 1 x 500 GB
- Interface Type
- SATA 3Gb/s
- Spindle Speed
- 7200 rpm
Storage Controller
- 1 x SATA - integrated
- Controller Interface Type
- SATA 3Gb/s
- Channel Qty
- 3
Optical Storage
- DVD±RW (±R DL) / DVD-RAM DVD SuperMulti - SATA
Card Reader
- 9 in 1 card reader
Monitor
- Monitor Type
- None.
Graphics Controller
- Integrated
- Graphics Processor
- Video Interfaces
- VGA, DVI
- Max Monitors Supported
- 2
Audio Output
- Integrated
- Sound Output Mode
- Stereo
- High Definition Audio
Input Device
- Mouse, keyboard
Keyboard
- Keyboard Name
- Preferred Pro USB
- Interface
- USB
Mouse
- Technology
- Optical
- Interface
- USB
- Integrated
- Ethernet Controller
- Realtek RTL8111E
- Data Link Protocol
- Wake on LAN (WoL)
- Bays
- 1 (total) / 0 (free) x external 5.25" x 1/2H , 1 (total) / 0 (free) x internal 3.5" x 1/3H , 1 (total) / 0 (free) x external 1.5"
- Slots
- 2 (total) / 1 (free) x DIMM 240-pin , 1 (total) / 0 (free) x CPU , 1 (total) / 1 (free) x PCIe 2.0 x16 - low-profile , 2 (total) / 2 (free) x PCIe 2.0 x1 - low-profile
- 6 x USB 2.0 (2 front, 4 rear) , 2 x microphone (1 front, 1 rear) , 1 x headphones (1 in front) , 1 x LAN (Gigabit Ethernet) , 1 x VGA , 1 x DVI-D , 1 x audio line-in , 1 x audio line-out , 1 x serial , 1 x parallel
- Administrator password, hard drive password, power-on password, boot without keyboard or mouse, USB port control, boot sequence control
- Theft/Intrusion Protection
- Security lock slot (cable lock sold separately), padlock loop
- RoHS
- TopSeller
- Power supply
- Voltage Required
- Power Provided
- 180 Watt
Operating System / Software
- OS Provided
- Microsoft Windows 7 Professional 64-bit Edition (available through downgrade rights from Windows 8 Pro 64-bit) + Windows 8 Pro 64-bit Licence
- 33.6 cm
- 38.2 cm
- 10.1 cm
- 6 kg
