This thin laptop weighs very light. The ThinkBook 14s Yoga 2 in 1 laptop is conveniently thin and light - and its Intel Core processor means you won't sacrifice performance for portability. Its 360-degree hinge lets you access that power in four flexible modes - laptop, tablet, tent, or stand - while its garaged pen allows for enhanced interaction in any of them. Plus, plenty of memory allow for seamless multitasking and speedy responsiveness.
The ThinkBook 14s Yoga incorporates smarter technology, to make your job easier. With Modern Standby, the laptop wakes in one second and connects in one more. Other smart features include Flip to Boot, Intelligent Cooling, video resolution upscaling, Mode Switch, Whisper Voice and Eye care mode.
Power to breeze through tasks
The ThinkBook 14s Yoga Gen 2 convertible laptop features 12 th Gen Intel Core processors for maximum computing power and long battery life. With an AI-enhanced hybrid architecture, tasks are split among cores optimized for performance or efficiency-you'll breeze through your work. There's even available WiFi 6E*, Intel's fastest yet, for more stable wireless connections and faster speeds.* 6GHz WiFi 6E operation is dependent on the support of the operating system, routers/APs/gateways that support WiFi 6E, along with the regional regulatory certifications and spectrum allocation. -
Four modes for ultimate flexibility
SMBs succeed by adapting to client needs, and there's nothing more flexible than a 2-in-1 laptop like the ThinkBook 14s Yoga. Use it to type and create in laptop mode. Or take advantage of the 360° hinge for tent, stand, and tablet modes. Plus, with Windows 11's Snap groups, you can instantly call up related apps for each mode, from presenting charts to counting inventory. -
Vibrant touchscreen with virtual keyboard
The 14" FHD Dolby Vision display on the ThinkBook 14s Yoga Gen 2 delivers crisp visuals with 100% sRGB colour gamut. The antifingerprint touchscreen accepts multifinger gestures and features a phone-like on-screen keyboard-perfect for tablet use. It's low blue light-certified, too, with protective Corning Gorilla Glass and Lenovo Super Resolution for automatic video upscaling. -
Speedy memory, storage, ports
There's more to a great SMB laptop than fast processors and excellent WiFi. So we also equip the ThinkBook 14s Yoga Gen 2 with up to lots of responsive DDR4 memory for smoother multitasking. Gen 4 SSD storage offers speedier file access than earlier versions. And for connecting monitors and peripherals, the wide selection of ports includes USB-C, Thunderbolt 4, and more. USB port transfer speeds are approximate and depend on many factors, such as processing capability of host/peripheral devices, file attributes, system configuration and operating environments; actual speeds will vary and may be less than expected. -
Security& convenience
Security and convenience features include a power button/fingerprint reader and the ThinkBook Yoga Integrated Smart Pen-simply pulling it from its slot opens the Smart Note app. Glance by Mirametrix can sense your gaze (or if someone's looking from behind). A Service Hot Key provides instant access to Lenovo support services, and built-in noise cancellation improves virtual meetings. -
Portable, durable-and good-looking
Choosing a multimode, convertible laptop already makes you a mobile productivity trend-setter. But the ThinkBook 14s Yoga Gen 2 makes a statement in other ways, too. You can get it in either Mineral Grey or Abyss Blue. It's ultraportable-just 16.9mm/ 0.67" thin-with an 86% screen-to-body ratio. And with metal exteriors on three sides, it's got a durable, premium look and feel.
- Lenovo ThinkBook 14s Yoga G2 IAP - 14" - Intel Core i7 - 1255U - 16 GB RAM - 512 GB SSD - UK
- Product Type
- Notebook - flip design
- Operating System
- Win 11 Pro - English
- Processor
- Intel Core i7 (12th Gen) - 1255U / 1.7 GHz, up to 4.7 GHz / 12 MB Cache
- Memory
- 16 GB DDR4 (1 x 8 GB + 8 GB (soldered))
- Storage
- 512 GB SSD - NVMe
- Display
- 14" LED backlight touchscreen 1920 x 1080 / Full HD
- Graphics
- Intel Iris Xe Graphics
- Input Device
- Digitizer, digital pen
- Keyboard
- UK
- Keyboard Backlight
- Integrated Webcam
- Networking
- 802.11a/b/g/n/ac/ax, Bluetooth 5.2
- Battery
- Up to 10.5 hours
- Security
- Discrete Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader
- Dual tone abyss blue
- 32 cm x 21.6 cm x 1.69 cm
- 1.5 kg
- Localisation
- Manufacturer Selling Program
- Lenovo TopSeller
- Environmental Standards
- ENERGY STAR Qualified EPEAT Gold
- Base warranty - 1 year - pick-up and return , Extended warranty - 1 year - on-site
- Bundled Services
- 1 Year Lenovo Premier Support
- Product Type
- Operating System
- Windows 11 Pro - English
Processor / Chipset
- CPU
- Intel Core i7 (12th Gen) 1255U / 1.7 GHz
- Max Turbo Speed
- 4.7 GHz
- Number of Cores
- 10-core
- Cache
- 12 MB
- Integrated memory controller
- RAM
- 16 GB (1 x 8 GB + 8 GB (soldered))
- Max RAM Supported
- 16 GB
- Technology
- DDR4 SDRAM
- Speed
- 3200 MHz
- Rated Speed
- 1600 MHz
- Form Factor
- SO-DIMM 260-pin
- Slots Qty
- 1
- Empty Slots
- 0
Storage
- Main Storage
- 512 GB SSD M.2 2242 PCIe 4.0 x4 - NVM Express (NVMe)
Display
- 14" - IPS
- LCD Backlight Technology
- LED backlight
- Touchscreen
- Yes (10-point multi-touch)
- Resolution
- 1920 x 1080 (Full HD)
- Widescreen
- Image Aspect Ratio
- 16:9
- Image Brightness
- 300 cd/m²
- Colour Gamut
- 100% sRGB
- Glossy, Corning Gorilla glass, anti-fingerprint, capacitive touch screen, 170° viewing angle, Glass Panel, Dolby Vision
Audio & Video
- Graphics Processor
- Max Monitors Supported
- 3 external monitor(s)
- Camera
- Yes - 1080p
- Camera Features
- Privacy shutter, fixed focus
- Sound
- Stereo speakers, dual array microphone
- Codec
- Realtek ALC3287
- High Definition Audio, Dolby Audio
- Audio Features
- Output: noise-cancellation technology, Harman audio technology
Input
- Keyboard, digitizer, touchpad, digital pen
- Keyboard Layout
- UK
- Spill-resistant, multi-touch touchpad, buttonless touchpad, precision touchpad
Communications
- Wireless
- Wireless Controller
- M.2 Card
- Dual stream (2x2)
- Technology
- Lithium polymer
- Capacity
- 60 Wh
- Run Time
- Up to 10.5 hours
- Battery Run Time
- Local video (1080p) playback time (150 nits): up to 10.5 hours
AC Adapter
- Input
- AC 100-240 V (50/60 Hz)
- Output
- 65 Watt
Connections & Expansion
- Slots
- 2 x M.2 Card (1 free)
- Interfaces Details
- USB 3.2 Gen 1 , USB 3.2 Gen 1 (Always On) , USB-C 3.2 Gen 2 (supports DisplayPort 1.4 Alt Mode) (Power Delivery 3.0) , USB4 (supports Thunderbolt 4, DisplayPort 1.4 Alt Mode) (Power Delivery 3.0) , HDMI , Headphone/microphone combo jack
- Memory Card Reader
- Yes (microSD)
Software
- Software Included
- Microsoft Office (Trial)
- Case Material
- Aluminium (top), aluminium (bottom)
- Surface Finish
- Anodising sandblasting
- Security
- Administrator password, hard drive password, power-on password, MIL-STD-810H tested, self-healing BIOS
- Theft/Intrusion Protection
- Security Slot Type
- Kensington nano security slot
- Included Accessories
- USB-C power adapter, ThinkBook Yoga Integrated Smart Pen
- RoHS, FSC, Energy-Related Products (ErP) Lot 3, TUV Rheinland Low Blue Light (Software Solution)
- Localization
- Lenovo TopSeller
- 1.5 kg
Sustainability Information
- EPEAT Compliant
- EPEAT Gold
- ENERGY STAR Certified
- Bundled Services
- 5 °C
- 35 °C
- 8 - 95%
Essential Accessories (2)
Get more from your purchase from one of our essential accessories
Lenovo 65W Standard AC Adapter USB-C | In Stock | £28.46 |
Lenovo USB-C 65W AC Adapter AC 100-240 V 65Watt for ThinkPad A275 | In Stock | £29.48 |
Other bundles (7)
Lenovo USB Soundbar for Display | In Stock | £29.96 |
Lenovo HDMI to VGA Monitor Adapter | In Stock | £23.12 |
Lenovo Essential Wireless Keyboard and Mouse Combo - UK English 166 | In Stock | £27.12 |
Lenovo Professional Wireless Keyboard | In Stock | £52.98 |
Lenovo ThinkPad USB3.0 to Ethernet Adapter | In Stock | £16.03 |
Lenovo ThinkPad Bluetooth Silent Mouse - Right and Left-handed | In Stock | £23.81 |
Lenovo ThinkVision T24t-20 23.8" 4ms HDMI DisplayPort USB-C IPS LED Monitor | In Stock | £189.67 |
