14? business laptop, certified Intel Evo with up to vPro Essentials (select models)
Responsive and fast, with all-day battery life
Zero-touch login with optional infrared (IR) camera& Windows Hello
Military-grade durability testing& checks
Redesigned ergonomic keyboard& large display options
Ideal for data collection, creative work,& team collaboration.
Big on performance& productivity
Meet the Lenovo ThinkBook 14 Gen 6 (14? Intel) laptop, a state-of-the-art upgrade for your business. High-performing and ready to increase productivity, this device features 13th Gen Intel Core processors, with the availability of cutting-edge Intel Evo or Intel vPro Essentials platforms. Enjoy the superior bandwidth of dual-channel memory configurations, for faster data transfer speeds and improved performance. An optional higher-capacity battery gives you more productive hours between charges. Take your daily workflow to new heights. -
Feels as great as it looks
Along with the sleek look and feel of the Arctic Grey aluminum chassis, the ThinkBook 14 Gen 6 laptop boasts an upgraded ergonomically redesigned keyboard. The keys are larger than previous generations and include a concave cap that curves to your fingertips- plus, the keys are made from 50% post-consumer recycled plastic. The expanded touchpad feels smooth and easy. And an F9 smart key can be customized to open any frequently used app- or keep the default, which links directly to our Services page. -
Keeps you and your data safe
Rest easy with the protection of the ThinkBook 14 Gen 6 laptop's biometrics-from a fingerprint reader integrated with the power button, to facial recognition software that works with the infrared (IR) camera. ThinkShield, our comprehensive suite of security solutions, ensures your system is protected. Trusted Platform Module (TPM) firmware encrypts your data, and a self-healing BIOS restores critical info should your device ever become corrupted. -
Collaborate smarter
An optional infrared hybrid camera takes videoconferencing to the next level. Enjoy rich, clear images on an even bigger screen (thanks to the 16:10 aspect ratio), with TÜV Rheinland Eyesafe certification to ensure your comfort and safety. With AI-based noise cancellation and Dolby Audio, say good-bye to background noises-people will hear you loud and clear, the same way you'll hear them. And when you don't want to be on camera, the webcam privacy shutter ensures you stay out of sight. -
Link your smartphone to your laptop
With Intel Unison, you can put your laptop at the center of all that you do. Wirelessly connect your phone-either Android or iOS-to your ThinkBook 14 Gen 6. Transfer files quickly and easily, even edit your photos and videos seamlessly on the big screen. Make calls directly from your PC, with full access to your phone's contact list. Plus, get notifications and messages right on your laptop.*Intel Unison solution is currently only available on eligible Intel Evo designs on Windows-based PCs powered by 12 th Gen Intel Core or newer CPU and only pairs with Android- or iOS-based phones; all devices must run a supported OS version. See intel.com/performance-evo for details, including set-up requirements. Results may vary. -
Durable by design
We use the US Department of Defense's MIL-STD 810H standards to create a balance of reliability and durability for our ThinkBook laptops. We test against 26 procedures to ensure they run in extreme conditions. These tests cover harsh variables like Arctic wilderness and desert dust storms, including temperature, pressure, humidity, vibration, and more.
- Lenovo ThinkBook 14 G6 IRL - 14" - Intel Core i5 - 1335U - 8 GB RAM - 256 GB SSD - UK
- Product Type
- Notebook
- Operating System
- Win 11 Pro - English
- Processor
- Intel Core i5 (13th Gen) - 1335U / 1.3 GHz, up to 4.6 GHz / 12 MB Cache
- Memory
- 8 GB DDR5 (1 x 8 GB)
- Storage
- 256 GB SSD - NVMe
- Display
- 14" 1920 x 1200 / WUXGA @ 60 Hz
- Graphics
- Intel Iris Xe Graphics
- Keyboard
- UK
- Keyboard Backlight
- Integrated Webcam
- Networking
- 802.11a/b/g/n/ac/ax, Bluetooth 5.1, Gigabit Ethernet
- Security
- Firmware Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader
- Dual tone arctic grey
- 31.35 cm x 22.4 cm x 1.69 cm
- 1.38 kg
- Localisation
- Manufacturer Selling Program
- Lenovo TopSeller
- Environmental Standards
- TCO Certified Notebooks 9, ENERGY STAR Qualified EPEAT Gold, EPEAT Climate+
- Limited warranty - 1 year - pick-up and return
- Product Type
- Notebook
- Operating System
- Windows 11 Pro - English
Processor / Chipset
- CPU
- Intel Core i5 (13th Gen) 1335U / 1.3 GHz
- Max Turbo Speed
- 4.6 GHz
- Number of Cores
- 10-core
- Cache
- 12 MB
- Integrated memory controller
- RAM
- 8 GB (1 x 8 GB)
- Max RAM Supported
- 64 GB
- Technology
- DDR5 SDRAM
- Speed
- 5200 MHz
- Rated Speed
- 2600 MHz
- Form Factor
- SO-DIMM 262-pin
- Slots Qty
- 2
- Empty Slots
- 1
Storage
- Main Storage
- 256 GB SSD M.2 2242 PCIe 4.0 x4 - NVM Express (NVMe)
Display
- 14" - IPS
- Resolution
- 1920 x 1200 (WUXGA)
- V-Sync Rate at Max Res.
- 60 Hz
- Widescreen
- Image Aspect Ratio
- 16:10
- Image Brightness
- 300 cd/m²
- Horizontal Viewing Angle
- +85 / -85
- Vertical Viewing Angle
- +85 / -85
- Colour Gamut
- 45% NTSC
- Anti-glare, Low Blue Light technology
Audio & Video
- Graphics Processor
- Max Monitors Supported
- 3 external monitor(s)
- Video System Features
- Functions as Intel UHD graphics (for single-channel memory)
- Camera
- Yes - 1080p
- Camera Features
- Privacy shutter, Windows Hello, fixed focus, hybrid FHD/IR camera
- Sound
- Stereo speakers, dual array microphone
- Codec
- Realtek ALC3287
- High Definition Audio, Dolby Audio
- Audio Features
- Input: noise-cancellation technology
Input
- Keyboard, touchpad
- Keyboard Layout
- UK
- Spill-resistant, multi-touch touchpad, buttonless touchpad, precision glass touchpad
Communications
- Wireless
- Wireless Controller
- M.2 Card
- Network Interface
- Gigabit Ethernet
- Ethernet Controller
- Intel I219-V
- Wake-on-LAN (WOL), dual stream (2x2)
- Technology
- Lithium polymer
- Capacity
- 45 Wh
AC Adapter
- Input
- AC 100-240 V (50/60 Hz)
- Output
- 65 Watt
Connections & Expansion
- Slots
- 2 x M.2 (PCI Express 4.0 x4) (1 free)
- Interfaces Details
- USB 3.2 Gen 1 , USB 3.2 Gen 1 (Always On) , USB-C 3.2 Gen 2 (supports DisplayPort 1.4 Alt Mode) (Power Delivery 3.0) , USB4 (supports Thunderbolt 4, DisplayPort 1.4 Alt Mode) (Power Delivery 3.0) , HDMI (4K support) , LAN , Headphone/microphone combo jack
- Memory Card Reader
- 4 in 1 (SD Card, MultiMediaCard, SDHC Card, SDXC Card)
Software
- Software Included
- Microsoft Office (Trial)
- Case Material
- Aluminium (top), aluminium (bottom)
- Surface Finish
- Anodising sandblasting
- Security
- Administrator password, hard drive password, power-on password, MIL-STD-810H tested, Rapid Charge Pro, self-healing BIOS
- Theft/Intrusion Protection
- Security Slot Type
- Kensington nano security slot
- Included Accessories
- USB-C power adapter
- RoHS, Energy-Related Products (ErP) Lot 6, FSC, Energy-Related Products (ErP) Lot 26, TUV Rheinland Low Blue Light (Software Solution)
- Localization
- Lenovo TopSeller
- 1.38 kg
Sustainability Information
- TCO Certified
- - TCO Certified Notebooks 9
- EPEAT Compliant
- EPEAT Gold
- EPEAT Climate+
- ENERGY STAR Certified
- 5 °C
- 35 °C
- 8 - 95%
Essential Accessories (14)
Get more from your purchase from one of our essential accessories
Lenovo ThinkPad Hybrid USB-C with USB-A Dock - Do | In Stock | £192.81 |
Lenovo 65W USB-C DC Travel Adapter | In Stock | £41.22 |
Lenovo ThinkPad Basic Topload - Notebook carrying case - 15 | In Stock | £13.44 |
Lenovo ThinkPad Universal USB-C Dock UK | In Stock | £141.26 |
Lenovo ThinkPad Thunderbolt 4 Workstation Dock - UK/HK/SGP/MYS | In Stock | £312.73 |
Lenovo ThinkPad Universal Thunderbolt 4 Dock | In Stock | £250.42 |
Lenovo ThinkPad Universal USB-C Smart Dock -UK | In Stock | £233.96 |
Lenovo Casual Toploader T210 - Notebook carrying case 15.6" Black | In Stock | £15.54 |
Lenovo ThinkPad Universal Thunderbolt 4 Smart Dock | In Stock | £302.48 |
Lenovo TP ESSENTIAL CASE 16-INCH BACKPACK | In Stock | £29.45 |
Lenovo LENOVO 2-IN-1 LAPTOP STAND | In Stock | £29.52 |
Lenovo LThinkPad Universal USB-C Dock - Docking station - USB-C - H | In Stock | £150.53 |
Lenovo ThinkPad Essential 16 INCH Topload (Eco) | In Stock | £25.92 |
Lenovo CASE_BO LENOVO SELECT 14-INCH SLEEVE | In Stock | £17.71 |
Warranty Packs (6)
Protect your investment by taking out one of our great value warranty packs
Lenovo Extend your ThinkPad Warranty from 1 Yr Depot to 3 Yr Depot | In Stock | £74.59 |
Lenovo ePac On-site Repair Extended Service Agreement 3 Years | In Stock | £73.14 |
Lenovo Onsite Upgrade - extended service agreement - 4 years - on-site | In Stock | £202.81 |
Lenovo TS Electronic Warranty, Upgrade from a 1YR Depot to a | In Stock | £12.31 |
Lenovo Warranty 3YR Onsite | In Stock | £75.64 |
Lenovo 1Y Premier Support NBD | In Stock | £52.84 |
Other bundles (14)
Lenovo HDMI to VGA Monitor Adapter | In Stock | £22.97 |
Lenovo 2m HDMI Cable | In Stock | £16.94 |
Lenovo Professional Wireless Keyboard | In Stock | £52.98 |
Lenovo ThinkPad USB3.0 to Ethernet Adapter | In Stock | £16.01 |
Lenovo Essential Compact Wireless Mouse | In Stock | £13.76 |
Lenovo USB-C To USB-C Cable - 2m | In Stock | £31.47 |
Lenovo Hybrid USB-C to USB-C Cable with USB-A Adaptor 1m | In Stock | £23.23 |
Lenovo ThinkPad Bluetooth Silent Mouse - Right and Left-handed | In Stock | £23.78 |
Lenovo Stereo 3.5mm Headset | In Stock | £18.05 |
Lenovo USB-C Cable 1M | In Stock | £15.73 |
Lenovo Thinkvision MC50 Monitor Webcam | In Stock | £52.48 |
Lenovo ThinkPad Essential Wireless Mouse | In Stock | £13.44 |
Lenovo Lenovo Essential Wired Combo - Keyboard and mouse set - USB | In Stock | £20.02 |
Lenovo Lenovo - Headset - on-ear - Bluetooth - wireless - USB-A via | In Stock | £69.39 |
