Unbound performance
Get the raw power you need for all your computing needs with AMD Ryzen 4000 series mobile processors. Whether you're mining data or creating a complex document, these mobile processors are designed to let you do more, faster. And with up to 2TB of dual-SSD storage options, the Lenovo ThinkBook 14 Gen 2 laptop lets you stack up heavy files like high-resolution images, large design files, and more-and load them with ease. -
Cool& connected
Enjoy superior workflow with a range of ports including full-function USB-C, HDMI, and 4-in-1 card reader, which let you expand your device without hassles and multitask seamlessly. The Lenovo ThinkBook 14 Gen 2 laptop also offers impressive thermal performance with Intelligent Cooling. Built with a bigger fan, heat pipes and stronger thermal capacity, your laptop stays cool even when you are running demanding tasks. -
Engineered for today's workplaces
Navigate effortlessly between apps and see your work in sharp resolution on the FHD display with optional touchscreen panel, while TÜV Rheinland certification reduces eyestrain on busy days. You'll also enjoy crystal clear conference calls with Whisper Voice, a new AI-based noise cancellation algorithm that blocks screaming children, barking dogs, home appliances, etc. from your calls while you work remotely. -
Next-gen connectivity
Enjoy the new speedy standard of WiFi 6, which lets you transfer huge files quickly and enjoy smooth online experiences on the busiest of networks. Give productivity a boost with greater bandwidth, stable network connectivity, and lower latency. -
Dressed for work
Stylish on the exterior with a dual-tone mineral gray top cover, the next-gen Lenovo ThinkBook 14 is bold and a pride to be seen with. Its super-compact, slim, and lightweight aluminum chassis gives this laptop robust and sophisticated looks. Get more screen real estate with 5mm-thin bezels and an 85% screen-to-body ratio, giving you an immersive visual experience. And whether you're working from home or in a cafe, its 1.4kg/ 3.08lbs lets you carry this laptop wherever you go quite comfortably. -
Smart security& user-experience
The Lenovo ThinkBook 14 Gen 2 keeps your information secure with hardware and firmware features like Trusted Platform Module (TPM), I/O port access control, self-healing BIOS, secure wipe, and more. A webcam privacy shutter physically blocks the lens so that you can get a bit of personal space during video calls. And to round it all out, smart features boost your experience: Get the most out of visual content with video resolution upscaling, command your microphone with various preset modes. -
WARRANTY UPGRADES
Onsite Service maximizes PC uptime and productivity by providing convenient, fast repair service at your place. In addition, with Tech Install CRU service the installation of all internal Customer Replaceable Unit (CRU) parts will be done on your behalf by a trained technician. 1 -
WARRANTY EXTENSIONS
This fixed-term, fixed-cost service and Sealed Battery warranty extensions help you accurately budget for PC expenses, protect your investment, and lower the cost of ownership over time. 1 -
KEEP YOUR DRIVE
Retain your drive if it should happen to fail, giving you the peace of mind of knowing that your valuable data is secure. 1,2
- Lenovo ThinkBook 14 G2 ARE - 14" - AMD Ryzen 5 - 4500U - 8 GB RAM - 256 GB SSD - UK
- Product Type
- Notebook
- Operating System
- Win 10 Pro 64-bit - English
- Processor
- AMD Ryzen 5 4500U / 2.3 GHz, up to 4 GHz / 8 MB Cache
- Memory
- 8 GB DDR4 (provided memory is soldered)
- Storage
- 256 GB SSD - NVMe
- Display
- 14" LED backlight 1920 x 1080 / Full HD
- Graphics
- AMD Radeon Graphics
- Keyboard
- UK
- Keyboard Backlight
- Integrated Webcam
- Networking
- 802.11a/b/g/n/ac/ax, Bluetooth 5.1, Gigabit Ethernet
- Battery
- Up to 7.5 hours
- Security
- Firmware Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader
- Mineral grey
- 32.3 cm x 21.8 cm x 1.79 cm
- 1.4 kg
- Localisation
- Manufacturer Selling Program
- Lenovo TopSeller
- Environmental Standards
- ENERGY STAR Qualified
- Limited warranty - 1 year - pick-up and return
- Product Type
- Notebook
- Operating System
- Windows 10 Pro 64-bit Edition - English
Processor / Chipset
- CPU
- Max Turbo Speed
- 4 GHz
- Number of Cores
- 6-core
- Cache
- L3 - 8 MB
- 64-bit Computing
- Integrated memory controller
- RAM
- 8 GB (provided memory is soldered)
- Max RAM Supported
- 40 GB
- Technology
- DDR4 SDRAM
- Speed
- 3200 MHz
- Rated Speed
- 1600 MHz
- Form Factor
- SO-DIMM 260-pin
- Slots Qty
- 1
- Empty Slots
- 1
Storage
- Main Storage
- 256 GB SSD M.2 2242 PCIe 3.0 x4 - NVM Express (NVMe)
Display
- 14" - IPS
- LCD Backlight Technology
- LED backlight
- Resolution
- 1920 x 1080 (Full HD)
- Widescreen
- Image Aspect Ratio
- 16:9
- Image Brightness
- 250 cd/m²
- Colour Gamut
- 45% NTSC
- Anti-glare, 170° viewing angle
Audio & Video
- Graphics Processor
- AMD Radeon Graphics - up to
- Camera
- Yes - 720p
- Camera Features
- ThinkShutter camera privacy
- Sound
- Stereo speakers, dual array microphone
- Codec
- Realtek ALC3287
- High Definition Audio, Dolby Audio
Input
- Keyboard, touchpad
- Keyboard Layout
- UK
- Spill-resistant, multi-touch touchpad, buttonless touchpad, precision touchpad
Communications
- Wireless
- Wireless Controller
- Intel Wi-Fi 6 AX 200 - M.2 Card
- Network Interface
- Gigabit Ethernet
- Dual stream (2x2)
- Technology
- Lithium Ion
- Capacity
- 45 Wh
- Run Time
- Up to 7.5 hours
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 65 Watt
Connections & Expansion
- Interfaces Details
- 2 x USB-C 3.2 Gen 2 (supports DisplayPort 1.4 Alt Mode) (Power Delivery 3.0) , USB 3.2 Gen 1 , USB 3.2 Gen 1 (Always On) , HDMI , LAN , Headphone/microphone combo jack
- Memory Card Reader
- 4 in 1 (SD Card, MultiMediaCard, SDHC Card, SDXC Card)
Software
- Software Included
- Microsoft Office (30 days trial)
- Mineral grey
- Case Material
- Aluminum
- Security
- Administrator password, hard drive password, power-on password, Rapid Charge Pro
- Theft/Intrusion Protection
- Security Slot Type
- Kensington nano security slot
- Included Accessories
- USB-C power adapter
- RoHS, TUV Rheinland Low Blue Light Certification, Energy-Related Products (ErP) Lot 3
- Localization
- Lenovo TopSeller
- 1.4 kg
Sustainability Information
- TCO Certified
- ENERGY STAR Certified
Essential Accessories (2)
Get more from your purchase from one of our essential accessories
Lenovo 3M 14.0W Privacy Filter | In Stock | £37.80 |
Lenovo ThinkPad Hybrid USB-C with USB-A Dock - Do | In Stock | £192.93 |
Warranty Packs (2)
Protect your investment by taking out one of our great value warranty packs
Lenovo Extend your ThinkPad Warranty from 1 Yr Depot to 3 Yr Depot | In Stock | £74.59 |
Lenovo ePac On-site Repair Extended Service Agreement 3 Years | In Stock | £73.14 |
Other bundles (8)
Lenovo HDMI to VGA Monitor Adapter | In Stock | £23.14 |
Lenovo 2m HDMI Cable | In Stock | £16.97 |
Lenovo Essential Wireless Keyboard and Mouse Combo - UK English 166 | In Stock | £27.12 |
Lenovo Professional Wireless Keyboard | In Stock | £52.99 |
Lenovo ThinkPad USB3.0 to Ethernet Adapter | In Stock | £16.03 |
Lenovo ThinkVision T27q-20 27" 2560x1440 4ms HDMI DisplayPort IPS LED Monitor | In Stock | £312.36 |
Lenovo ThinkPad Bluetooth Silent Mouse - Right and Left-handed | In Stock | £23.81 |
Lenovo Thinkvision MC50 Monitor Webcam | In Stock | £52.49 |
