Lenovo TB-8505F 8" 32GB Android Tablet
Quicklinx: FKKWWS00 Mfr#: ZA5G0064GB
A tablet for the whole family
Whether it’s for homework, online shopping, or a screen-time treat, the Tab 4 8 is ideal for the whole family. Stylish yet rugged, this smooth-performing tablet has a vibrant 8" display, enhanced audio, and long battery life. Everyone can have their own account and there are optional add-ons aimed specifically for the younger ones.
  • High-end design
    The Tab M8 (2 nd Gen) was made for users who appreciate good style and design. Only 8.15mm thin, with a metal back cover and rounded edges, this tablet feels great in your hands and exudes elegance.
  • Check out the view
    Gone are the days of tablets with tinny sound and grainy video. The Tab M8 (2 nd Gen) brings an IPS HD touchscreen display that uses 82% of the tablet's surface area for seamless visuals, and a Dolby Audio-tuned speaker. This one-two punch of visual and audio pleasure makes streaming your favorite videos and playing mobile games even more enjoyable.
  • Everything you need
    With Android  9 Pie, a quad-core processor, and a battery that provides up to 18 hours of web browsing, the Tab M8 (2 nd  Gen) is your key to nonstop entertainment. Watch videos, check social media, listen to music, and so much more-this tablet delivers.
  • Stare all you want
    The Tab M8 (2 nd  Gen)'s TÜV-certified display cuts back blue light that's potentially damaging to eyesight, especially for growing children. So, you and your family can watch and play for hours on long trips and slow days at home with peace of mind.
Lenovo Tab M8 HD (2nd Gen) ZA5G - tablet - Android 9.0 (Pie) - 32 GB - 8"
Tablet
Operating System
Android 9.0 (Pie)
Display
8" IPS TFT - LED backlight - 1280 x 800 - Multi-Touch
MediaTek Helio A22 (Quad-Core) - 64-bit
Processor Clock Speed
2 GHz
Storage
32 GB Embedded Multi-Chip Package
RAM
2 GB
Supported Flash Memory Cards
microSD
Wireless Connectivity
802.11a/b/g/n/ac, Bluetooth 5.0
Rear Camera
5 Megapixel
Front Camera
2 Megapixel
Radio Tuner Type
FM radio
Battery Run Time
Up to 18 hours
19.91 cm x 0.815 cm x 12.18 cm
305 g
Iron grey
United Kingdom
1-year warranty
Tablet
Operating System
Android 9.0 (Pie)
Display
Resolution
1280 x 800
Colour Gamut
60%
Touchscreen
Multi-Touch
Image Brightness
350 cd/m²
10-point multi-touch, capacitive touch screen, 160° viewing angle
MediaTek Helio A22
2 GHz
Number of Cores
Quad-Core
64-bit Computing
Storage
RAM
2 GB - LPDDR3 SDRAM
microSD
Max Supported Capacity
128 GB
Communications
Security Protocols & Features
Wi-Fi Direct
Rear Camera
Sensor Resolution
5 Megapixel
Front Camera
Sensor Resolution
2 Megapixel
Multimedia
Graphics
IMG GE8300
Supported Digital Audio Standards
Dolby Atmos
Radio Tuner Type
FM radio
Audio
Microphone, speaker
Software
Preloaded Software
Camera, Files, Gmail, YouTube, Google Calendar, Netflix, FM Radio, Google Chrome, Google Maps, Google Photo, Google Duo
Expansion and Connectivity
Expansion Slots
1 x microSD
1 x Micro-USB , 1 x headset mini jack (3.5mm)
Lithium Ion
5100 mAh
Run Time
Up to 18 hours
Standby Time
336 h
Run Time Details
Video playback over Wi-Fi: up to 12 hour(s) , Web browsing: up to 18 hour(s)
Recharge Time
3.3 hour(s)
Iron grey
Case Material
Plastic, metal
Sensors
Accelerometer, ambient light sensor, proximity sensor
Vibrating Alert
Power adapter
RoHS, IP5X
United Kingdom
19.91 cm
0.815 cm
12.18 cm
305 g
Limited warranty - 1 year - pick-up and return
