The Lenovo Tab M7 is a tablet that will make your eyes widely open. It is amazingly designed with up to 90% full metal back cover. The whole part is built with craftsmanship for both premium and comfort in holding. Every single detail is refined to make you be proud of and standout of the others. More than that, Lenovo Tab M7 is a feast for your eyes with uncompromised vivid display, equipped with brighter nits and rich color saturation. Lenovo Tab M7 is optimized with Android Pie and is a great device to be used for fast browsing and video watching.
Premium design& loaded with features
Don't sacrifice aesthetics for affordability. The Tab M7 (2 nd Gen) looks great and packs plenty of entertaining features. And with the latest Android Pie OS, this tablet gves you access to all of your favorite apps available on the Google Play store. You'll also enjoy the TÜV-certified display that cuts back on harmful levels of blue light, so you can look at this tablet all day without hurting your eyes. -
Connection has never been so seamless-or so smart
Lenovo Connect features LTE connectivity across Europe and USA with private connection encryption and authentication. The Lenovo Connect SIM Card includes a 5GB per month x 1 month subscription to Lenovo Connect*. The Service consists in providing prepaid cellular Data Plans (allowance of data valid for a certain duration) to enable connecting your Device to the Internet (the"Data Plans"). You can jump online whenever, wherever. More data plans are available with competitive rates.The SIM card and the Services are provided by Truphone.* Disclaimer:- Must be activated within 90 days of purchasing the Lenovo Connect SIM Card; Valid for 30 days immediately following activation;- Valid only in the European Union, Iceland, Norway, Switzerland, United Kingdom and United States;- Once monthly data limit is reached, data connectivity will halt till next month; unused data will not roll over to remaining months;- Any data plan will be provided by Truphone under the Truphone terms and conditions. Activate Your Data Plan Carefully snap the correct size of SIM out and place it in your device. Go to Settings > Network& Internet > Mobile network. First, enable"Data roaming". Then, go to Advanced > Access point names. See if the below APN has been correctly set up. If not,- Add APN: net.truphone.com- Select'More' and'Save Make sure your device is connected to Wi-Fi and visit aoacwap.lenovoconnect.com Tap the icon'Upload ICCID Code' to upload the ICCID Code on your SIM Activate the data plan and enjoy it Truphone's Terms and Conditions must be accepted during the data activation process Please check Lenovo Connect SIM accessory via support.lenovo.com for Frequently Asked Questions and Customer Service Contacts
- Lenovo TB-7305F ZA55 - tablet - Android 9.0 (Pie) Go Edition - 16 GB - 7"
- Product Type
- Tablet
- Operating System
- Display
- 7" IPS TFT - LED backlight - 1024 x 600 - Multi-Touch
- Processor
- MediaTek MT8321 (Quad-Core)
- Processor Clock Speed
- 1.3 GHz
- Storage
- 16 GB eMMC
- RAM
- 1 GB
- Supported Flash Memory Cards
- microSD
- Wireless Connectivity
- 802.11b/g/n, Bluetooth 4.0
- Rear Camera
- 2 Megapixel
- Front Camera
- 2 Megapixel
- Navigation System
- GPS
- Battery Run Time
- Up to 10 hours
- 10.285 cm x 0.825 cm x 17.633 cm
- 236.9 g
- Onyx black
- Localisation
- United Kingdom
- 1-year warranty
- Product Type
- Tablet
- Operating System
Display
- Resolution
- 1024 x 600
- Colour Gamut
- 50% NTSC
- Touchscreen
- Multi-Touch
- Image Brightness
- 350 cd/m²
- 5-point multi-touch
- Processor
- MediaTek MT8321
- 1.3 GHz
- Number of Cores
- Quad-Core
- Storage
- 16 GB eMMC
- RAM
- 1 GB - LPDDR3 SDRAM
- microSD
- Max Supported Capacity
- 128 GB
Communications
- Wi-Fi Direct
Rear Camera
- Sensor Resolution
- 2 Megapixel
Front Camera
- Sensor Resolution
- 2 Megapixel
Navigation System
- Receiver
- GPS
Multimedia
- Graphics
- ARM Mali-400 GPU
- Supported Digital Audio Standards
- Dolby Atmos
- Audio
- Microphone, speaker
Software
- Preloaded Software
- Calendar, Camera, Weather, Google Chrome, Google Photo, Gmail Go, Google Maps Go, Google Duo, YouTube Go, Google GO, Tablet Manager
Expansion and Connectivity
- Expansion Slots
- 1 x microSD
- 1 x Micro-USB , 1 x headset mini jack (3.5mm)
- Technology
- Lithium Ion
- Capacity
- 3500 mAh
- Run Time
- Up to 10 hours
- Run Time Details
- Video playback: up to 10 hour(s) , Web browsing: up to 10 hour(s)
- Recharge Time
- 3.3 hour(s)
- Onyx black
- Case Material
- Plastic, metal
- Sensors
- Accelerometer
- Vibrating Alert
- Included Accessories
- Power adapter
- RoHS
- Localisation
- United Kingdom
- 10.285 cm
- 0.825 cm
- 17.633 cm
- 236.9 g
- Limited warranty - replacement - 1 year
